Full Version: Frodo Art work not downloading. log pasted below
Hello All,
I have recently discover XBMC a week ago and what an awsome mediacenter!
I have spent a lot of hours setting up my synology to work with XBMC. I have xbmc
pointing to mySql. Mysql have created the video and music databases successfully.
Being im a newbie to XBMC i still have a lot to learn about its different functionalities.
One of the things i have been trying to solve for many hours is getting the fanart to
work. I have paste my log here. I hope someone can help me on this.
Thx
11:30:20 T:2936 NOTICE: -----------------------------------------------------------------------
11:30:20 T:2936 NOTICE: Starting XBMC (12.1 Git:20130317-0d373cc), Platform: Windows 7 64-bit, build 7600. Built on Mar 17 2013 (compiler 1600)
11:30:20 T:2936 NOTICE: Intel® Core™2 Duo CPU T9400 @ 2.53GHz
11:30:20 T:2936 NOTICE: Desktop Resolution: 1920x1200 32Bit at 60Hz
11:30:20 T:2936 NOTICE: Running with administrator rights
11:30:20 T:2936 NOTICE: Aero is enabled
11:30:20 T:2936 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\XBMC
11:30:20 T:2936 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\XBMC
11:30:20 T:2936 NOTICE: special://masterprofile/ is mapped to: C:\Users\Phibenet\AppData\Roaming\XBMC\userdata
11:30:20 T:2936 NOTICE: special://home/ is mapped to: C:\Users\Phibenet\AppData\Roaming\XBMC\
11:30:20 T:2936 NOTICE: special://temp/ is mapped to: C:\Users\Phibenet\AppData\Roaming\XBMC\cache
11:30:20 T:2936 NOTICE: The executable running is: C:\Program Files (x86)\XBMC\XBMC.exe
11:30:20 T:2936 NOTICE: Local hostname: Phibenet-PC
11:30:20 T:2936 NOTICE: Log File is located: C:\Users\Phibenet\AppData\Roaming\XBMC\xbmc.log
11:30:20 T:2936 NOTICE: Found 2 Lists of Devices
11:30:20 T:2936 NOTICE: Enumerated DirectSound devices:
11:30:20 T:2936 NOTICE: Device 1
11:30:20 T:2936 NOTICE: m_deviceName : {FBBBD37F-A9D1-4A9D-9124-B142E4DCCD74}
11:30:20 T:2936 NOTICE: m_displayName : Speakers - Speakers (High Definition Audio Device)
11:30:20 T:2936 NOTICE: m_displayNameExtra: DirectSound: Speakers (High Definition Audio Device)
11:30:20 T:2936 NOTICE: m_deviceType : AE_DEVTYPE_PCM
11:30:20 T:2936 NOTICE: m_channels : FL,FR
11:30:20 T:2936 NOTICE: m_sampleRates : 44100
11:30:20 T:2936 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_AC3
11:30:20 T:2936 NOTICE: Device 2
11:30:20 T:2936 NOTICE: m_deviceName : {2B7E2A8E-51B7-4DB6-BDE8-685600A7999D}
11:30:20 T:2936 NOTICE: m_displayName : SPDIF - Digital Audio (S/PDIF) (High Definition Audio Device)
11:30:20 T:2936 NOTICE: m_displayNameExtra: DirectSound: Digital Audio (S/PDIF) (High Definition Audio Device)
11:30:20 T:2936 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
11:30:20 T:2936 NOTICE: Device 3
11:30:20 T:2936 NOTICE: m_deviceName : {70C48EDC-A6A2-413E-87EE-BC43573D2F5C}
11:30:20 T:2936 NOTICE: m_displayName : HDMI - Digital Audio (HDMI) (2- High Definition Audio Device)
11:30:20 T:2936 NOTICE: m_displayNameExtra: DirectSound: Digital Audio (HDMI) (2- High Definition Audio Device)
11:30:20 T:2936 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
11:30:20 T:2936 NOTICE: m_sampleRates : 48000
11:30:20 T:2936 NOTICE: Enumerated WASAPI devices:
11:30:20 T:2936 NOTICE: m_displayNameExtra: WASAPI: Digital Audio (S/PDIF) (High Definition Audio Device)
11:30:20 T:2936 NOTICE: m_sampleRates : 192000,96000,88200,48000,44100
11:30:20 T:2936 NOTICE: m_dataFormats : AE_FMT_DTS,AE_FMT_AC3,AE_FMT_AAC,AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
11:30:20 T:2936 NOTICE: m_displayNameExtra: WASAPI: Digital Audio (HDMI) (2- High Definition Audio Device)
11:30:20 T:2936 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
11:30:20 T:2936 NOTICE: m_displayNameExtra: WASAPI: Speakers (High Definition Audio Device)
11:30:20 T:2936 NOTICE: m_sampleRates : 192000,96000,48000,44100
11:30:20 T:2936 NOTICE: m_dataFormats : AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
11:30:20 T:2936 NOTICE: load settings...
11:30:20 T:2936 NOTICE: special://profile/ is mapped to: special://masterprofile/
11:30:20 T:2936 NOTICE: loading special://masterprofile/guisettings.xml
11:30:20 T:2936 NOTICE: Getting hardware information now...
11:30:20 T:2936 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
11:30:20 T:2936 NOTICE: Loaded playercorefactory configuration
11:30:20 T:2936 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
11:30:20 T:2936 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
11:30:20 T:2936 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
11:30:20 T:2936 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
11:30:20 T:2936 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<videodatabase>
<type>mysql</type>
<host>192.168.1.241</host>
<port>3306</port>
<user>xbmc</user>
<pass>xbmc</pass>
<name>xbmc_video</name>
</videodatabase>
<musicdatabase>
<type>mysql</type>
<port>3306</port>
<user>xbmc</user>
<pass>xbmc</pass>
<name>xbmc_music</name>
</musicdatabase>
<pathsubstitution>
<substitute>
<from>special://masterprofile/Thumbnails/</from>
<to>smb://192.168.1.241/xbmc_Thumbs/</to>
</substitute>
</pathsubstitution>
</advancedsettings>
11:30:20 T:2936 WARNING: VIDEO database configuration is experimental.
11:30:20 T:2936 NOTICE: Default DVD Player: dvdplayer
11:30:20 T:2936 NOTICE: Default Video Player: dvdplayer
11:30:20 T:2936 NOTICE: Default Audio Player: paplayer
11:30:20 T:2936 NOTICE: Disabled debug logging due to GUI setting. Level 0.
11:30:20 T:2936 NOTICE: Log level changed to 0
11:30:20 T:2936 NOTICE: Loading media sources from special://masterprofile/sources.xml
11:30:21 T:2112 NOTICE: Thread CSoftAE start, auto delete: false
11:30:21 T:2936 NOTICE: Running database version Addons15
11:30:23 T:2740 NOTICE: Thread XBMC Peripherals start, auto delete: false
11:30:23 T:880 NOTICE: Previous line repeats 1 times.
11:30:23 T:880 NOTICE: Thread CRemoteControl start, auto delete: false
11:30:23 T:2936 NOTICE: Found screen: Generic PnP Monitor on NVIDIA GeForce 9650M GT, adapter 0.
11:30:23 T:2936 NOTICE: Primary mode: 1920x1200 @ 60.00 - Full Screen
11:30:23 T:2936 NOTICE: Additional mode: 640x480 @ 60.00 - Full Screen
11:30:23 T:2936 NOTICE: Previous line repeats 2 times.
11:30:23 T:2936 NOTICE: Additional mode: 720x480 @ 60.00 - Full Screen
11:30:23 T:2936 NOTICE: Additional mode: 720x576 @ 60.00 - Full Screen
11:30:23 T:2936 NOTICE: Additional mode: 800x600 @ 60.00 - Full Screen
11:30:23 T:2936 NOTICE: Additional mode: 1024x768 @ 60.00 - Full Screen
11:30:23 T:2936 NOTICE: Additional mode: 1152x864 @ 60.00 - Full Screen
11:30:23 T:2936 NOTICE: Additional mode: 1280x720 @ 60.00 - Full Screen
11:30:23 T:2936 NOTICE: Additional mode: 1280x960 @ 60.00 - Full Screen
11:30:23 T:2936 NOTICE: Additional mode: 1280x1024 @ 60.00 - Full Screen
11:30:23 T:2936 NOTICE: Additional mode: 1400x1050 @ 60.00 - Full Screen
11:30:23 T:2936 NOTICE: Additional mode: 1600x1024 @ 60.00 - Full Screen
11:30:23 T:2936 NOTICE: Additional mode: 1600x1200 @ 60.00 - Full Screen
11:30:23 T:2936 NOTICE: Additional mode: 1920x1080 @ 60.00 - Full Screen
11:30:23 T:2936 NOTICE: Additional mode: 1920x1200 @ 60.00 - Full Screen
11:30:23 T:2936 NOTICE: Checking resolution 16
11:30:24 T:2936 NOTICE: Running database version Addons15
11:30:24 T:2936 NOTICE: Running database version ViewModes4
11:30:24 T:2936 NOTICE: Running database version Textures13
11:30:24 T:2936 NOTICE: Running database version xbmc_music32
11:30:24 T:2936 NOTICE: Running database version xbmc_video75
11:30:24 T:2936 NOTICE: Running database version TV22
11:30:24 T:2936 NOTICE: Running database version Epg7
11:30:24 T:2936 NOTICE: initializing playlistplayer
11:30:24 T:2936 NOTICE: DONE initializing playlistplayer
11:30:27 T:2032 NOTICE: Thread XBPyThread start, auto delete: false
11:30:27 T:2032 NOTICE: Previous line repeats 4 times.
11:30:27 T:2032 NOTICE: -->Python Interpreter Initialized<--
11:30:27 T:3976 NOTICE: Thread Jobworker start, auto delete: true
11:30:27 T:2936 NOTICE: CApplication::UpdateLibraries - Starting video library startup scan
11:30:27 T:3536 NOTICE: Thread CVideoInfoScanner start, auto delete: false
11:30:27 T:2936 NOTICE: initialize done
11:30:27 T:1144 NOTICE: Thread XBPyThread start, auto delete: false
11:30:27 T:2936 NOTICE: Running the application...
11:30:27 T:2936 NOTICE: ES: Starting event server
11:30:27 T:3124 NOTICE: Thread CEventServer start, auto delete: false
11:30:27 T:3124 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
11:30:27 T:3124 NOTICE: UDP: Listening on port 9777
11:30:27 T:1672 NOTICE: Thread CTCPServer start, auto delete: false
11:30:27 T:3536 NOTICE: VideoInfoScanner: Starting scan ..
11:30:27 T:3536 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:00
11:30:28 T:3260 NOTICE: Thread CRssReader start, auto delete: false
11:30:28 T:3876 NOTICE: Thread Jobworker start, auto delete: true
11:30:28 T:1916 NOTICE: -->Python Interpreter Initialized<--
11:30:28 T:1352 NOTICE: -->Python Interpreter Initialized<--
11:30:28 T:3592 NOTICE: -->Python Interpreter Initialized<--
11:30:28 T:2392 NOTICE: -->Python Interpreter Initialized<--
11:30:28 T:2032 NOTICE: service.libraryautoupdate: Update Library Service starting...
11:30:28 T:2032 NOTICE: service.libraryautoupdate: update timers
11:30:28 T:3656 NOTICE: Thread XBPyThread start, auto delete: false
11:30:28 T:1144 NOTICE: -->Python Interpreter Initialized<--
11:30:29 T:3656 NOTICE: -->Python Interpreter Initialized<--
11:30:29 T:1540 NOTICE: Thread CFileCache start, auto delete: false
11:30:29 T:2392 NOTICE: Artwork Downloader: ## Service - Run at startup: False
11:30:29 T:2392 NOTICE: Artwork Downloader: ## Service - Delayed startup: minutes
11:30:29 T:2392 NOTICE: Artwork Downloader: ## Service - Run as service: False
11:30:29 T:2392 NOTICE: Artwork Downloader: ## Service - Time: :00
11:30:30 T:1144 NOTICE: StorageServer Module loaded RUN
11:30:30 T:1144 NOTICE: StorageClient-2.5.0 Starting server
11:30:30 T:1144 NOTICE: StorageServer-2.5.0 Storage Server starting C:\Users\Phibenet\AppData\Roaming\XBMC\userdata\addon_data\script.common.plugin.cache\commoncache.db
11:30:30 T:2032 NOTICE: service.libraryautoupdate: Starting network check
11:30:31 T:2032 NOTICE: service.libraryautoupdate: Update Video Library
11:30:31 T:2032 NOTICE: service.libraryautoupdate: Starting network check
11:30:31 T:2348 NOTICE: Thread CVideoInfoScanner start, auto delete: false
11:30:31 T:3116 NOTICE: Thread Jobworker start, auto delete: true
11:30:31 T:2032 NOTICE: service.libraryautoupdate: Update Specific Path 1
11:30:31 T:2348 NOTICE: VideoInfoScanner: Starting scan ..
11:30:31 T:2348 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:00
11:30:32 T:2032 NOTICE: service.libraryautoupdate: update timers
11:30:34 T:4004 NOTICE: Thread CFileCache start, auto delete: false
11:30:40 T:1600 NOTICE: Thread Background Loader start, auto delete: false
11:30:40 T:2936 NOTICE: Previous line repeats 1 times.
11:30:40 T:2936 ERROR: Python script "script.tvtunes" does not exist
11:30:44 T:3976 ERROR: XFILE::CDirectory::GetDirectory - Error getting videodb://1/extrafanart/
11:33:51 T:700 NOTICE: Thread Jobworker start, auto delete: true
11:33:58 T:2936 NOTICE: Storing total System Uptime
11:33:58 T:2936 NOTICE: Saving settings
11:33:58 T:2936 NOTICE: stop all
11:33:58 T:2936 NOTICE: ES: Stopping event server
11:33:58 T:2936 NOTICE: stopping zeroconf publishing
11:33:59 T:3124 NOTICE: ES: UDP Event server stopped
11:33:59 T:2936 NOTICE: stop sap announcement listener
11:33:59 T:2936 NOTICE: clean cached files!
11:33:59 T:2936 NOTICE: unload skin
11:34:00 T:2032 WARNING: The python script "C:\Users\Phibenet\AppData\Roaming\XBMC\addons\service.libraryautoupdate\default.py" has left several classes in memory that we couldn't clean up. The classes include: Monitor
11:34:00 T:3592 WARNING: The python script "C:\Users\Phibenet\AppData\Roaming\XBMC\addons\service.skin.widgets\default.py" has left several classes in memory that we couldn't clean up. The classes include: Window,Monitor,Player
11:34:00 T:1144 NOTICE: StorageServer-2.5.0 Closed down
11:34:00 T:2936 NOTICE: stop python
11:34:00 T:2936 NOTICE: stopped
11:34:00 T:2936 NOTICE: destroy
11:34:00 T:2936 NOTICE: closing down remote control service
11:34:00 T:2936 NOTICE: unload sections
11:34:01 T:2936 NOTICE: destroy
11:34:01 T:2936 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
11:34:01 T:2936 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
11:34:01 T:2936 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
11:34:01 T:2936 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
11:34:01 T:2936 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
11:34:01 T:2936 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
11:34:01 T:2936 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
11:34:01 T:2936 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
11:34:01 T:2936 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
11:34:01 T:2936 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
11:34:01 T:2936 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
11:34:01 T:2936 NOTICE: closing down remote control service
11:34:01 T:2936 NOTICE: unload sections
11:34:01 T:2936 NOTICE: application stopped...
