2013-03-23, 23:45
2013-03-24, 18:03
Overwhelmed by the responses, but, I guess I had figured as much :-)
I have built 12.1. Not sure who maintains the Wiki article here: http://wiki.xbmc.org/index.php?title=HOW...nux_CentOS, it was a big help. Thanks!
Here are a couple notes on my experience building on Fedora Core 18:
Had to also install:
yum install taglib-devel libplist-devel
(the second because I enabled AirPlay support)
From the libraries list, yum couldn't find hal hal-devel hal-libs, otherwise found everything else in the repos I have configured.
There was one compile issue, I took a easy route out:
ln -s /usr/include/samba-4.0/libsmbclient.h <SRC>/xbmc/filesystem
The configure line I used was:
./configure --prefix=/opt/xbmc/xbmc-12.1 --enable-pulse --enable-airplay
Shash
Shash
2013-04-01, 15:40
I have been doing some fedora builds. Here is the thread.
http://forum.xbmc.org/showthread.php?tid=154578
2013-04-04, 01:43
(2013-04-01, 15:40)brianf21 Wrote: [ -> ]I have been doing some fedora builds. Here is the thread.
That's great, somehow never found this when I searched. Would be great if you could build the RPM for 12.1 stable, others may benefit.
2013-04-19, 13:16
To be able to suspend from xbmc i also had to install:
sudo yum install dbus-glib-devel
before compiling.
before compiling.
