Full Version: Boot splash logo issue with XBMC + Ubuntu server
Hi all
I'm writing you because I have only one open issue left on my HTPC system running ubuntu server + XBMC
The HTPC is nVidia based, I'm running drivers rev 310.
I've followed the istruction on http://wiki.xbmc.org/index.php?title=HOW...oot_Splash but when enabling the boot logo (yes I did the handoff modification of 10_linux) I have conflicts with the nvidia driver when uxlaunch tries to load XBMC
This is my dmesg output
Quote:[ 24.876647] NVRM: The NVIDIA probe routine was not called for 1 device(s).
[ 24.876660] NVRM: This can occur when a driver such as nouveau, rivafb,
[ 24.876660] NVRM: nvidiafb, or rivatv was loaded and obtained ownership of
[ 24.876660] NVRM: the NVIDIA device(s).
[ 24.876673] NVRM: Try unloading the conflicting kernel module (and/or
[ 24.876673] NVRM: reconfigure your kernel without the conflicting
[ 24.876673] NVRM: driver(s)), then try loading the NVIDIA kernel module
[ 24.876673] NVRM: again.
[ 24.876685] NVRM: No NVIDIA graphics adapter probed!
[ 24.942774] NVRM: The NVIDIA probe routine was not called for 1 device(s).
[ 24.942787] NVRM: This can occur when a driver such as nouveau, rivafb,rup
[ 24.942787] NVRM: nvidiafb, or rivatv was loaded and obtained ownership of
[ 24.942787] NVRM: the NVIDIA device(s).
[ 24.942796] NVRM: Try unloading the conflicting kernel module (and/or
[ 24.942796] NVRM: reconfigure your kernel without the conflicting
[ 24.942796] NVRM: driver(s)), then try loading the NVIDIA kernel module
[ 24.942796] NVRM: again.
[ 24.942804] NVRM: No NVIDIA graphics adapter probed!
[ 27.267003] UDF-fs: Partition marked readonly; forcing readonly mount
[ 27.355581] UDF-fs: INFO Mounting volume 'Biancaneve', timestamp 2012/11/03 09:27 (103c)
[ 38.180943] uxlaunch (683): /proc/1551/oom_adj is deprecated, please use /proc/1551/oom_score_adj instead.
[ 40.198188] init: uxlaunch main process (661) killed by KILL signal
I think that something more shall be done around the grub init.d scripts or the uxlaunch one, to do a proper handover of the nvidia framebuffer, or maybe use a different framebuffer at all in grub?
Thanks in advance for the help
Bye
Just disable all framebuffers when you use nvidia - so sorry for the highres splash :-)
Well
It's not what I want. I know that disabling everything it works, actually it is what I did, but I'd like to find a solution.
Then if the solution doesn't exist, it is another matter Smile
If I recall correctly, there are two X launcher/method that you can select when installing uxlaunch. Maybe the other one is better?
