Full Version: Imon LCD only works once sometimes twice with LCDd.conf
I am using XBMCbuntu with Frodo. I have a case with an inbuilt Imon LCD 15c2;0038. Its working nicely, but only until the next boot. I then have to change my LCDd.conf script from
Device=/dev/lcd1 to Device=/dev/lcd0
or vice versa. After reloading lcdproc (and sometimes also restarting XBMC) it starts working again, until the next reboot. Sometimes its the second reboot either.
What doesn´t happen is that it starts working without having the LCDd.conf changed.
What is this strange behaviour coming from?
How can I prevent the LCD Device from being reconfigured from 0 to 1?
I hope someone here comes out with an idea.
Thx in advance
Carsten
can you send a version of lcdproc.
i have nox live 2 with imon LCD, i have install frodo 12, and then install lcdproc, edit LCDd.conf but in my display shows nothing
version lcdeproc 0.5.5-2
i see in official page 0.5.6 imonlcd
Soundgraph iMON LCD, requires Linux kernel module.
I installed lcdproc by using
sudo apt-get install lcdproc
in terminal. That should get you the newest Version of it.
Is there an entry regarding lcdproc in your xbmc.log?
Carsten
this is how I also installed lcdproc, but i try to install xbmcbuntu an then upgrade, and the last step will install lcdproc.
