Full Version: Problem adding playlist to home screen menu
I am trying to add a smart playlist to the home screen menu (I use Frodo and confluence skin). In my Home.xml (in the installation path: C:\Program Files (x86)\XBMC\addons\skin.confluence\720p) I have added the following:
<item id="13">
<label>MyPlaylist</label>
<onclick>XBMC.ActivateWindow(VideoLibrary,"%APPDATA%\XBMC\userdata\playlists\video\MyPlaylist.xsp",return)</onclick>
<icon>-</icon>
<thumb>-</thumb>
<visible></visible>
</item>
When I open XBMC I can see the MyPlaylist as a home screen menu but when I click on it it is empty (just a black window). When I select favourites and enter my playlist it is working as it should.
Does anyone know how I can make this work?
Best regards, Moorstream
If you open Favourites.xml in the userdate folder you can see what the correct link is to that favourite.
Thank you Kibje. It worked Smile
