2013-03-25, 20:19
Hi
Following Error and no solution:
http://forum.xbmc.org/showthread.php?tid...pid1371682
I have a Problem.
Initial Setup where i have configured the XBMC. (12.0 RC1)
- Video Lib
- Music Adons (Radio)
Here is everything OK and all the Stations that i have under "my Stations" are running perfect.
- Welle1 Salzburg
- Technobase FM
- FFH Rock Over Germany
Now i have updated the XBMC to 12.1
Problem:
- if i start FFH Rock Over German hangs the complete XBMC / no audioplaybay (No Response from the Application)
- the other Stations run correctly
Now i installed the actual nighlie (13.0): same Problem
Downgraded to 12.0: same Problem
Downgrade to 12.0 RC1: FFH Digital Rock is working perfect
OS: Win7 x64 SP1 all Updates /
Intel E8400 Asus P45Q-E
Avast Antivirus
I'v tried to delete the Radio Addon Folder (C:\Users\USERNAME\AppData\Roaming\XBMC\addons\plugin.audio.radio_de) and install the addon again: no change
Has anybody a idea whats the problem?
thanks
I have a Problem.
- Video Lib
- Welle1 Salzburg
- Technobase FM
Problem:
Avast Antivirus
thanks
