Full Version: XBMC on HiMedia Qxx, Please help!
I tried XBMC nonneon on my Himedia Q5 and Q10 with Hi3716C
It was ok first then when I installed Netflix addon and some more addons the XBMC stopped to work.
After restart it just black window when trying to start XBMC.
Tried to reinstall but it not start. Box works nice with other apps but some problem with XBMC.
No warning during reinstalling but simply not working after reinstall either.
What shall I do?
Please help
Thank you!
(2013-03-26, 13:34)dimon Wrote: [ -> ]Hi,
What shall I do?
Please help
Thank you!
You try re install new firmware. Last time I buy Himedia Q10 and meet same problem
What shall I do?
Please help
Thank you!
please let us know if q5 is able to decode 720 and 1080p movis whit outh frame skipping .
please be sure that you clean an remove old instalation before re instaling..
also be sure that you selected the no neon version of the apk
here it is the latest firmware for the Q5 1.1.1 ( 2012-12-27)
http://v.himedia-tech.cn/Q5/111/update.zip
