2013-03-26, 15:32
I just found a way to stream to airport express using the nightlies with new upnp 'play using' feature. You need to install an app for dbpoweramp called 'air upnp' which picks up airport express’ on your network then broadcasts them as upnp devices which xbmc then shows under 'play using'. It doesn’t actually show in xbmc that its playing but you can control it and basically works. Not perfect but a great step forward! I really hope that in the future we are able to get a full multi room experience from this
Air upnp:
http://forum.dbpoweramp.com/showthread.p...P-devices)
Air upnp:
