18:16:23 T:13628 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <class 'simplejson.scanner.JSONDecodeError'>
Error Contents: Expecting value: line 1 column 1 (char 0)
File "C:\Program Files (x86)\XBMC 13\portable_data\addons\script.extendedinfo-master\default.py", line 899, in <module>
Main()
File "C:\Program Files (x86)\XBMC 13\portable_data\addons\script.extendedinfo-master\default.py", line 75, in __init__
self._StartInfoActions()
File "C:\Program Files (x86)\XBMC 13\portable_data\addons\script.extendedinfo-master\default.py", line 333, in _StartInfoActions
passDataToSkin('ArtistEvents', GetEvents(self.Artist_mbid), self.prop_prefix)
File "C:\Program Files (x86)\XBMC 13\portable_data\addons\script.extendedinfo-master\OnlineMusicInfo.py", line 138, in GetEvents
results = GetLastFMData(url)
File "C:\Program Files (x86)\XBMC 13\portable_data\addons\script.extendedinfo-master\OnlineMusicInfo.py", line 154, in GetLastFMData
results = json.loads(response)
File "C:\Program Files (x86)\XBMC 13\portable_data\addons\script.module.simplejson\lib\simplejson\__init__.py", line 488, in loads
return _default_decoder.decode(s)
File "C:\Program Files (x86)\XBMC 13\portable_data\addons\script.module.simplejson\lib\simplejson\decoder.py", line 370, in decode
obj, end = self.raw_decode(s)
File "C:\Program Files (x86)\XBMC 13\portable_data\addons\script.module.simplejson\lib\simplejson\decoder.py", line 389, in raw_decode
return self.scan_once(s, idx=_w(s, idx).end())
File "C:\Program Files (x86)\XBMC 13\portable_data\addons\script.module.simplejson\lib\simplejson\scanner.py", line 119, in scan_once
return _scan_once(string, idx)
File "C:\Program Files (x86)\XBMC 13\portable_data\addons\script.module.simplejson\lib\simplejson\scanner.py", line 84, in _scan_once
raise JSONDecodeError(errmsg, string, idx)
JSONDecodeError: Expecting value: line 1 column 1 (char 0)
18:17:47 T:1300 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Main()
18:31:00 T:6740 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Main()
