(2016-01-16, 15:27)Gade Wrote: [ -> ]Hi Phil.
Do you mean script.module.autocompletion?
I can't quite seem to find the other one in the repo, although it's listed at your Github.
sorry, there was some delay. should be available now. (plugin.program.autocompletion)
(2016-01-26, 22:06)n1ckn88 Wrote: [ -> ]Hi,
Is there a way to open up extendedinfo script mod as you load a profile or enter Kodi- not as you access it through a shortcut (list view starting upcoming movies. etc...) the actual way the program launches?
thanks
nick
"extendedinfo script mod" probably refers to that piracy crap with obfuscated code, right?
(2015-12-19, 12:20)Quihico Wrote: [ -> ] (2015-12-18, 02:54)Mr. V Wrote: [ -> ]I am having some issues with rotten tomato widgets. They are not returning the posters.
in ~/script.extendedinfo/resources/lib/RottenTomatoes.py
change line 24 from:
poster = "http://" + item["posters"]["original"].replace("tmb", "ori")[64:]
to:
poster = "http://content6.flixster.com/" + item["posters"]["original"][93:]
This worked perfect for me. Thanks for the post. It's strange that such a simple fix hasn't been added to the latest update?
(2016-02-01, 02:47)Raze Wrote: [ -> ] (2015-12-19, 12:20)Quihico Wrote: [ -> ] (2015-12-18, 02:54)Mr. V Wrote: [ -> ]I am having some issues with rotten tomato widgets. They are not returning the posters.
to:
Never mind. Just saw there is now version 4.0.1
Check this error please :
12:33:42 T:123145303990272 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.SyntaxError'>
Error Contents: ('invalid syntax', ('/Users/Cyril/Library/Application Support/Kodi/addons/script.extendedinfo/resources/lib/LastFM.py', 252, 22, ' params = {k: v for k, v in params.items() if v}\n'))
File "/Users/Cyril/Library/Application Support/Kodi/addons/script.extendedinfo/plugin.py", line 10, in <module>
from resources.lib.process import start_info_actions
File "/Users/Cyril/Library/Application Support/Kodi/addons/script.extendedinfo/resources/lib/process.py", line 6, in <module>
import LastFM
SyntaxError: ('invalid syntax', ('/Users/Cyril/Library/Application Support/Kodi/addons/script.extendedinfo/resources/lib/LastFM.py', 252, 22, ' params = {k: v for k, v in params.items() if v}\n'))
12:33:42 T:123145318555648 ERROR: GetDirectory - Error getting plugin://script.extendedinfo/?info=directormovies&&director=Jon Favreau
12:33:54 T:123145303453696 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
File "/Users/Cyril/Library/Application Support/Kodi/addons/script.extendedinfo/default.py", line 8, in <module>
import LastFM
Error with last git build, ok with Kodi repo build.
COMPLETE debug log, please.
I can't install extendedinfo anymore. It says: not compatible. Trying to install your version from github says: dependencies don't match, make contact with add-on author. Can you help me to fix this?
Kodi 15.2 Git:20151019-02e7013
Windows 10
I'm trying to install extendedinfo script on a raspberry pi 2, but all I'm getting is dependencies not met, Any ideas what should i do?
How did you try to install?
Also, always provide a
debug log (wiki)
(2016-02-07, 18:16)taliezin Wrote: [ -> ]I can't install extendedinfo anymore. It says: not compatible. Trying to install your version from github says: dependencies don't match, make contact with add-on author. Can you help me to fix this?
Windows 10
Kodi 15.2 is not compatible with latest master (>=16.0), use "helix" branch instead.
(2016-02-11, 19:33)phil65 Wrote: [ -> ]How did you try to install?
Also, always provide a debug log (wiki)
Need a lil help here phil getting errors on startup as well as when I try to run the script for extended movie info
Here is my debug log:http://xbmclogs.com/psrc0yx6x
Thanks in Advance
(2016-01-26, 22:08)phil65 Wrote: [ -> ] (2016-01-16, 15:27)Gade Wrote: [ -> ]Hi Phil.
Hey Phil,
I'm not sure why, but my skin is still call extendedinfo script, instead of the new plugin.
11:00:22 T:1860 ERROR: Unable to find plugin script.extendedinfo
11:00:22 T:1860 ERROR: PlayMedia could not play media: plugin://script.extendedinfo/?info=selectautocomplete&&id=target
I removed extendedinfo from my addon folder, and still, the autocomplete feature is keep asking for extendedinfo to be installed.
so I search "extendedinfo" in my whole kodi folder, and find those:
Kodi\addons\script.module.autocompletion\lib\AutoCompletion.py
PHP Code:
"path": "plugin://script.extendedinfo/?info=selectautocomplete&&id=%s" % search_str}
"path": "plugin://script.extendedinfo/?info=selectautocomplete&&id=%s" % line}
b.t.w, this is my dialogkeyboard file:
http://pastebin.com/imn0Sxne
