(2016-04-12, 00:40)phil65 Wrote: [ -> ]"directormovies" and "writermovies" were merged into "personmovies".
The music part may be broken for bit longer. I did a major major code refactoring which needs some time to get all small bits right.
Krypton is still pre-alpha, so I think that´s fine.
Hello Phil,
Sorry I have been away from the forum for a while. Coming back to your answer, as I am experimenting with Krypton, would you recommend to use the git version of the script? Can I simply checkout the master branch and use it inside ~/.kodi/addons ??
Pierre
Only if you feel adventurous. Latest GIT version also needs a new dependency (script.module.kodi65) which is available on my GitHub.
(2016-04-26, 15:31)phil65 Wrote: [ -> ]Only if you feel adventurous. Latest GIT version also needs a new dependency (script.module.kodi65) which is available on my GitHub.
Well I am asking because "personmovies" is apparently not defined in version 5.1.0, which is the latest version I got when installing from repo.
I can see you have a "krypton" branch on your git, would that be less adventurous?
krypton branch is obselete, master branch is krypton now.
Might be that 5.1.0 still uses directormovies/writermovies, not 100% sure when I changed that.
hello, I'm on jarvis 16.1 and Extended Info 4.6.2. I'm getting the "extended info: could not find valid content type" error when selecting a movie or shoe detail view in the Aeon Nox Silvo Mod skin. Here's the debug log:
http://xbmclogs.com/pmzpehflj
Thanks for your help.
(2016-04-26, 22:47)taylormia Wrote: [ -> ]hello, I'm on jarvis 16.1 and Extended Info 4.6.2. I'm getting the "extended info: could not find valid content type" error when selecting a movie or shoe detail view in the Aeon Nox Silvo Mod skin. Here's the debug log:
The error originates from the youtube add-on. Search the forums for that error message and you'll find some more info about it.
(2016-04-27, 13:03)Jeroen Wrote: [ -> ] (2016-04-26, 22:47)taylormia Wrote: [ -> ]hello, I'm on jarvis 16.1 and Extended Info 4.6.2. I'm getting the "extended info: could not find valid content type" error when selecting a movie or shoe detail view in the Aeon Nox Silvo Mod skin. Here's the debug log:
I have searched the forums for this error message and can find no posts discussing the youtube add-on. I have also updated to the latest youtube addon 5.1.20.6 with the same error. Can you expand on why you believe the error is related to the youtube addon? Thanks.
(2016-04-27, 15:34)taylormia Wrote: [ -> ] (2016-04-27, 13:03)Jeroen Wrote: [ -> ] (2016-04-26, 22:47)taylormia Wrote: [ -> ]hello, I'm on jarvis 16.1 and Extended Info 4.6.2. I'm getting the "extended info: could not find valid content type" error when selecting a movie or shoe detail view in the Aeon Nox Silvo Mod skin. Here's the debug log:
No, nothing to do with youtube. The skin is calling "openinfodialog" instead of "extendedinfo".
I checked and I see now what I thought about was a different, somewhat similar, error message:
"Exception in ContentProvider. Unknown kind"
That one had to do with YouTube and I got it mixed up, sorry.
(2016-04-27, 15:36)phil65 Wrote: [ -> ] (2016-04-27, 15:34)taylormia Wrote: [ -> ] (2016-04-27, 13:03)Jeroen Wrote: [ -> ]The error originates from the youtube add-on. Search the forums for that error message and you'll find some more info about it.
Thanks phil65!! I have posted in the Aeon Nox 5 Silvo skin thread and will hopefully get a response.
Hey Phil,
I'm running Aeon Nox Silvo on Krypton and getting continual errors when I press info on any movie. Probably a skin error, but here is a debug log anyways, just to be sure.
Thanks for your time!
http://xbmclogs.com/psyoy9ney
(2016-04-27, 20:04)Magoo32 Wrote: [ -> ] (2016-04-27, 15:36)phil65 Wrote: [ -> ] (2016-04-27, 15:34)taylormia Wrote: [ -> ]I have searched the forums for this error message and can find no posts discussing the youtube add-on. I have also updated to the latest youtube addon 5.1.20.6 with the same error. Can you expand on why you believe the error is related to the youtube addon? Thanks.
Hey Phil,
Was not aware "openinfodialog" was deprecated. Will push the changes to Git in the next few minutes.
