phil65. noticing constant crashing of the script using any of the 5.+ releases on just about any skin. This happen mainly when selecting a actor thumbnail from within the main Kodi interface. I can run extended info by running the addon directly without a crash.
Dropping back to 4.6+ version fixes the problem.
Hopefully pertinent info pasted below:
12:02:50 T:1184 ERROR: Couldn't load font name: Font-MusicOSD(robotocondensed-regular.ttf), trying to substitute arial.ttf
12:02:50 T:1184 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
12:02:50 T:1184 WARNING: Skin has invalid include: mainmenu-position-and-appearance
12:02:50 T:1184 WARNING: Previous line repeats 1 times.
12:02:50 T:1184 WARNING: Trying to add unsupported control type 1
12:02:50 T:1184 WARNING: Previous line repeats 30 times.
12:02:50 T:1184 NOTICE: initialize done
12:02:50 T:1184 NOTICE: Running the application...
12:02:50 T:1184 NOTICE: CWebServer[8080]: Started
12:02:50 T:1184 NOTICE: starting upnp client
12:02:50 T:6720 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
12:02:50 T:6720 NOTICE: UDP: Listening on port 9777
12:02:51 T:6036 NOTICE: Skin Helper Service --> skin helper service version 1.0.90 started
12:02:51 T:6036 NOTICE: Skin Helper Service --> WebService - start helper webservice on port 52307
12:02:51 T:6872 ERROR: CImageLoader:
oWork - Direct texture file loading failed for resource://resource.images.studios.coloured/
12:02:51 T:5304 WARNING: XFILE::CDirectoryFactory::Create - unsupported protocol(androidapp) in androidapp://sources/apps/
12:02:54 T:5304 ERROR: XFILE::CDirectory::GetDirectory - Error getting pvr://channels/tv/All channels/
12:02:54 T:5304 ERROR: XFILE::CDirectory::GetDirectory - Error getting pvr://channels/radio/All channels/
12:03:02 T:1184 ERROR: PlayMedia could not play media: plugin://script.extendedinfo/?info=extendedinfo&&id=269149
12:03:02 T:4072 WARNING: CSkinInfo: failed to load skin settings
12:03:02 T:4072 ERROR: EXCEPTION: argument "text" for method "textviewer" must be unicode or str
12:03:02 T:4072 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.TypeError'>
Error Contents: argument "text" for method "textviewer" must be unicode or str
File "C:\Program Files\Kodi\portable_data\addons\script.extendedinfo\plugin.py", line 157, in <module>
Main()
File "C:\Program Files\Kodi\portable_data\addons\script.extendedinfo\plugin.py", line 32, in __init__
listitems = process.start_info_actions(info, self.params)
File "C:\Program Files\Kodi\portable_data\addons\script.extendedinfo\resources\lib\process.py", line 348, in start_info_actions
name=params.get("name"))
File "C:\Program Files\Kodi\portable_data\addons\script.extendedinfo\resources\lib\WindowManager.py", line 69, in open_movie_info
self.open_infodialog(dialog)
File "C:\Program Files\Kodi\portable_data\addons\script.extendedinfo\resources\lib\WindowManager.py", line 213, in open_infodialog
self.open_dialog(dialog)
File "C:\Program Files\Kodi\portable_data\addons\script.extendedinfo\resources\lib\WindowManager.py", line 222, in open_dialog
utils.check_version()
File "C:\Program Files\Kodi\portable_data\addons\script.module.kodi65\lib\kodi65\utils.py", line 81, in check_version
text=read_from_file(addon.CHANGELOG, True))
TypeError: argument "text" for method "textviewer" must be unicode or str
12:03:17 T:1184 NOTICE: Storing total System Uptime
12:03:17 T:1184 NOTICE: Saving settings
12:03:17 T:1184 NOTICE: Saving skin settings
12:03:17 T:1184 NOTICE: stop all
12:03:17 T:1184 NOTICE: stop player
12:03:17 T:1184 NOTICE: ES: Stopping event server
12:03:17 T:1184 NOTICE: stopping upnp
12:03:17 T:1184 NOTICE: CWebServer[8080]: Stopped
12:03:17 T:6720 NOTICE: ES: UDP Event server stopped
12:03:17 T:1184 FATAL: C:\Program Files\Kodi\addons\peripheral.joystick\peripheral.joystick.dll is a system dll and should never be released
12:03:17 T:1184 NOTICE: clean cached files!
12:03:17 T:6036 NOTICE: Skin Helper Service --> Shutdown requested !
12:03:17 T:6036 NOTICE: Skin Helper Service --> BackgroundsUpdater - stop called
12:03:17 T:6036 NOTICE: Skin Helper Service --> ListItemMonitor - stop called
12:03:17 T:6036 NOTICE: Skin Helper Service --> WebService - stop called
12:03:17 T:6036 NOTICE: Skin Helper Service --> skin helper service version 1.0.90 stopped
12:03:18 T:1184 NOTICE: closing down remote control service
12:03:19 T:1184 NOTICE: stopped
12:03:19 T:1184 NOTICE: destroy
12:03:19 T:1184 NOTICE: unload skin
12:03:20 T:1184 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
12:03:20 T:1184 NOTICE: unload sections
12:03:20 T:1184 NOTICE: special://profile/ is mapped to: special://masterprofile/
12:03:20 T:1184 NOTICE: application stopped...
12:03:20 T:1184 FATAL: /libcurl.dll is a system dll and should never be released
12:03:20 T:1184 FATAL: /cpluff.dll is a system dll and should never be released
12:03:20 T:1184 FATAL: /libcec.dll is a system dll and should never be released
