2016-06-28, 07:28
Phil, just wondering where the slideshow controls are defined now? I see there isn't a separate skin file for slideshow anymore. Thanks!
<content limit="20">plugin://script.extendedinfo?info=youtubesearchvideos&&id=$INFO[ListItem.Title]</content>
00:24:56 T:123145562202112 DEBUG: script.extendedinfo: version 5.5.1 started
00:24:56 T:123145562202112 ERROR: /Applications/Kodi.app/Contents/Libraries/lib/python2.7/urllib.py:1299: UnicodeWarning: Unicode equal comparison failed to convert both arguments to Unicode - interpreting them as being unequal
00:24:56 T:123145562202112 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.KeyError'>
Error Contents: (u'\xe9',)
File "/Users/Cyril/Library/Application Support/Kodi/addons/script.extendedinfo/plugin.py", line 157, in <module>
Main()
File "/Users/Cyril/Library/Application Support/Kodi/addons/script.extendedinfo/plugin.py", line 32, in __init__
listitems = process.start_info_actions(info, self.params)
File "/Users/Cyril/Library/Application Support/Kodi/addons/script.extendedinfo/resources/lib/process.py", line 35, in start_info_actions
params["artist_mbid"] = utils.fetch_musicbrainz_id(params["artistname"])
File "/Users/Cyril/Library/Application Support/Kodi/addons/script.module.kodi65/lib/kodi65/utils.py", line 392, in fetch_musicbrainz_id
url = '&query=artist:%s' % urllib.quote_plus(artist)
File "/Users/Shared/jenkins/workspace/OSX-64/tools/depends/xbmc-depends/macosx10.10_x86_64-target/lib/python2.7/urllib.py", line 1306, in quote_plus
File "/Users/Shared/jenkins/workspace/OSX-64/tools/depends/xbmc-depends/macosx10.10_x86_64-target/lib/python2.7/urllib.py", line 1299, in quote
KeyError: (u'\xe9',)
00:24:56 T:140736312627968 DEBUG: ------ Window Init (DialogNotification.xml) ------
14:31:06 T:140397650073344 DEBUG: script.extendedinfo: version 5.5.1 started
14:31:06 T:140397650073344 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Contents: ('artists',)
File "/home/kodi/.kodi/addons/script.extendedinfo-master/plugin.py", line 157, in <module>
Main()
File "/home/kodi/.kodi/addons/script.extendedinfo-master/plugin.py", line 32, in __init__
File "/home/kodi/.kodi/addons/script.extendedinfo-master/resources/lib/process.py", line 35, in start_info_actions
File "/home/kodi/.kodi/addons/script.module.kodi65/lib/kodi65/utils.py", line 396, in fetch_musicbrainz_id
if results and len(results["artists"]) > 0:
KeyError: ('artists',)
14:31:06 T:140400980916608 DEBUG: ------ Window Init (DialogNotification.xml) ------
14:31:06 T:140397650073344 INFO: Python script stopped
14:31:06 T:140397650073344 DEBUG: Thread LanguageInvoker 140397650073344 terminating
14:31:06 T:140398269798144 DEBUG: CWebServer[8080]: request received for /jsonrpc
14:31:06 T:140398982850304 ERROR: GetDirectory - Error getting plugin://script.extendedinfo/?info=discography&&artistname=Chicago
(2016-07-29, 04:10)_Andy_ Wrote: [ -> ]@mattmartinolc yes, there is a solution. Don't install and use banned crappy add-ons like Exodus. No help in this forum.
(2016-07-29, 04:55)mattmartinolc Wrote: [ -> ](2016-07-29, 04:10)_Andy_ Wrote: [ -> ]@mattmartinolc yes, there is a solution. Don't install and use banned crappy add-ons like Exodus. No help in this forum.
ah what do you use?
11:16:31 256.727692 T:140218661332736 ERROR: GetDirectory - Error getting plugin://script.extendedinfo/?info=similartvshows&&dbid=375
11:16:48 273.643280 T:140217387890432 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.AttributeError'>
Error Contents: 'module' object has no attribute 'ACTION_SHOW_CODEC'
File "/storage/.kodi/addons/script.extendedinfo/default.py", line 8, in <module>
from resources.lib import process
File "/storage/.kodi/addons/script.extendedinfo/resources/lib/process.py", line 16, in <module>
import Trakt
File "/storage/.kodi/addons/script.extendedinfo/resources/lib/Trakt.py", line 9, in <module>
from kodi65 import addon
File "/storage/.kodi/addons/script.module.kodi65/lib/kodi65/__init__.py", line 8, in <module>
from actionhandler import ActionHandler
File "/storage/.kodi/addons/script.module.kodi65/lib/kodi65/actionhandler.py", line 37, in <module>
"codecinfo": xbmcgui.ACTION_SHOW_CODEC,
AttributeError: 'module' object has no attribute 'ACTION_SHOW_CODEC'
change
for
"codecinfo": xbmcgui.ACTION_PLAYER_DEBUG,
