(2016-09-05, 01:21)Short Wrote: [ -> ]I been receiving this error on kodi 17 from extended info here's my debug log
https://paste.ubuntu.com/23134828
An update for script.module.t9.search should be available today or tomorrow, then this should be fixed.
Any way I can change the font color in the script? It's not
readable with the skin i'm using. I figured out it changes when I edit the Defaults.xml colors, but that changes the entire skin.. Let me know if this is possible. Thanks!
Hey Phil,
I'm not sure if you are already aware of it, but the current available repo version of ExtendedInfo (5.5.1) crashs Kodi during the download/installation.
Nothing is written in the debug log but I can confirm this issue on 2 Win10 devices (Krypton).
(2016-09-08, 21:00)sualfred Wrote: [ -> ]Hey Phil,
I have the same issue with my Nvidia shield,iMac,windows10 and Amazon HD Fire.(Krypton)
yeah i have introduced a circular dependency which kodi cannot deal with, will get fixed.
Sorry for the hassle.
Phill is this button working for krypton version
Force nativ appearance, I can use script-ExtendedInfo Script-DialogVideoInfo.xml from skin mq6 or mq7
(always open your dialog) version="5.5.1
Edit i didnt know that you change in
script-script.extendedinfo-DialogVideoInfo.xml
now is working...sorry
Angelinas, need rename for
script-script.extendedinfo-DialogInfo
Im noticing that if the movie being viewed within Extended Info is in my library, the play button does not work. I have to back out of the Extended Info screen and select play from the main info screen. Kodi 17 Beta using the Plex Kodi Connect add one (works like Emby for Kodi) but Ive tried it with a stand alone install (local library) and it doesn't work either.
Anyone else see this?
Am I just missing it or is there not a way for me to add a upnp source? Thanks.
Oops, wrong thread. Can someone delete this please.
Hello !!!
I have an error message when kodi start concerning Script.extendedinfo.
21:43:39 T:9140 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.AttributeError'>
Error Contents: 'module' object has no attribute 'ACTION_PLAYER_DEBUG'
File "C:\Kodi\16\portable_data\addons\script.extendedinfo\plugin.py", line 12, in <module>
from resources.lib import process
File "C:\Kodi\16\portable_data\addons\script.extendedinfo\resources\lib\process.py", line 16, in <module>
import Trakt
File "C:\Kodi\16\portable_data\addons\script.extendedinfo\resources\lib\Trakt.py", line 9, in <module>
from kodi65 import addon
File "C:\Kodi\16\portable_data\addons\script.module.kodi65\lib\kodi65\__init__.py", line 8, in <module>
from actionhandler import ActionHandler
File "C:\Kodi\16\portable_data\addons\script.module.kodi65\lib\kodi65\actionhandler.py", line 37, in <module>
"playerdebug": xbmcgui.ACTION_PLAYER_DEBUG,
AttributeError: 'module' object has no attribute 'ACTION_PLAYER_DEBUG'
21:43:39 T:10124 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://script.extendedinfo/?info=topratedmovies
21:43:39 T:8096 NOTICE: script.tv.show.next.aired: ### getting series & episode info for #248835 - Once Upon a Time
21:43:41 T:4088 NOTICE: script.module.youtube.dl: youtube_dl core version: 2016.06.27
21:43:41 T:4088 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
import Trakt
I use kodi 16.1 with theme madnox. I update regulary scrip.extendedinfo, script.module.kodi65, script.module.t9.search and lot of others with github application.
Thx for your help !!!
PS i'm French !!!!
Github master branches are for krypton (v17). That´s why you get those errors.
