Full Version: script.extendedinfo
(2017-10-27, 15:42)Credo79 Wrote: [ -> ]Any update or fix for script.extendedinfo?  For Android?
script.extendedinfo now working with 17.6 RC1 nightly build  Smile
http://mirrors.kodi.tv/nightlies/android/arm/Krypton/
I had kodi 17.5.1 Installed but i cant install this version 17.6 I dont know why?
Yes finally it works again. @Credo79 just deinstall 17.5.1 and install the nightly.
(2017-11-05, 15:02)nomox22 Wrote: [ -> ]Yes finally it works again. @Credo79 just deinstall 17.5.1 and install the nightly.
Do i have to uninstall Kodi 17.5.1. Then I loose all my settings? Why cant I Just update it?
(2017-11-05, 20:17)Credo79 Wrote: [ -> ]
1) Backup your kodi using the Backup add-on. make sure you have all the boxes ticked shown below
2) Uninstall kodi 7.5.1
3) Turn off auto update in the google store
4) Install kodi 7.6
5) Restore kodi using Backup Image
Thanks I will try Smile
(2017-11-02, 23:45)Blurayx Wrote: [ -> ]
Dont work I going back17.3 thanks for is is working for you im using android on minix u9 why are you saying its work but it is not working. Sad
(2017-11-07, 00:02)Credo79 Wrote: [ -> ]
I can assure you extendedinfo is working normally on my Nvidia Shield TV, shield tablet and Fire HD tablet.
What would I possibly gain from lying about it working? I hope someone else can verify extendedinfo works with 17.6 RC1
Nvidia Shield TV
Update:
I did a fresh install(17.6 RC1) on my Fire HD tablet.extendedinfo works
(2017-11-07, 02:50)Blurayx Wrote: [ -> ]
(2017-11-02, 23:45)Blurayx Wrote: [ -> ]script.extendedinfo now working with 17.6 RC1 nightly build  Smile
Nvidia Shield TV
Update:
I did a fresh install(17.6 RC1) on my Fire HD table. extendedinfo works
Thank you very Much it is working Sorry It was My fault, It is workig Great Thanks again Smile
(2017-11-07, 16:57)Credo79 Wrote: [ -> ]
(2017-11-07, 00:02)Credo79 Wrote: [ -> ]Dont work I going back17.3 thanks for is is working for you im using android on minix u9 why are you saying its work but it is not working. Sad
Nvidia Shield TV
Update:
I did a fresh install(17.6 RC1) on my Fire HD tablet. extendedinfo works
No problem!!
Great to hear it’s working  Smile
I use SPMC 17.4 on the Nvidia Shield
edit error
Yippie, 17.6 fixes this!
(2017-07-28, 12:48)Guilouz Wrote: [ -> ]
(2017-07-28, 11:52)fred_gaou Wrote: [ -> ]
(2017-04-02, 13:46)AnthonyB Wrote: [ -> ]Seems that ExtendedInfo 5.60 doesn't support HEVC/x.265 video codec.
I've raised an issue at the GitHub - https://github.com/phil65/script.extendedinfo/issues/61
+1 for that. Issue still open.
Just x265 png file missing :
 I've searched through your various GitHub repositories to find those missing icons (i.e. HEVS / x.265) but cannot find them anywhere. Where can I find them? which addon/script? Thanks!
Not nagging or anything, but is phil (or anyone else) still working on this script?.
I've submitted an issue on github in October (an another one older) with no answer yet.
If it's abandoned then i will remove the support for things that is not working or broken.
Cheers
Nessus
