phil65
13:52:21.841 T:15872 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.KeyError'>
Error Contents: ('result',)
File "E:\Kodi\Kodi Krypton\portable_data\addons\script.extendedinfo\plugin.py", line 134, in <module>
Main()
File "E:\Kodi\Kodi Krypton\portable_data\addons\script.extendedinfo\plugin.py", line 31, in __init__
listitems = process.start_info_actions(info, self.params)
File "E:\Kodi\Kodi Krypton\portable_data\addons\script.extendedinfo\resources\lib\process.py", line 250, in start_info_actions
return local_db.get_similar_movies(params["dbid"])
File "E:\Kodi\Kodi Krypton\portable_data\addons\script.module.kodi65\lib\kodi65\localdb.py", line 91, in get_similar_movies
if "moviedetails" not in movie['result']:
KeyError: ('result',)
13:52:21.877 T:15872 WARNING: CPythonInvoker(62, E:\Kodi\Kodi Krypton\portable_data\addons\script.extendedinfo\plugin.py): the python script "E:\Kodi\Kodi Krypton\portable_data\addons\script.extendedinfo\plugin.py" has left several classes in memory that we couldn't clean up. The classes include: class XBMCAddon::xbmcgui::DialogBusy
13:52:21.893 T:10128 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://script.extendedinfo/?info=similarlocalmovies&&dbid=23
The similarlocalmovies feature is broken
Extendedinfo script error on Leia skin
Please your help
the scrips seem to be broken.
found a problem in line 800 of TheMovieDB.py commented the line
#"lists": sort_lists(handle_lists(info["lists"]["results"])),
and it works again, i think.
someone who update the script is need.
thanks
(2018-05-21, 09:33)peppe_sr Wrote: [ -> ]the scrips seem to be broken.
thanks
What's the problem in line 800?
(2018-05-21, 23:58)arzaz Wrote: [ -> ] (2018-05-21, 09:33)peppe_sr Wrote: [ -> ]the scrips seem to be broken.
thanks
this is the
error into the log. it is not my kodi. it is from a friend that found and solved using the comment #.
(2018-05-21, 23:58)arzaz Wrote: [ -> ]What's the problem in line 800?
The problem is that TMDb seems to have taken movie-lists out of their api.
Depending on the version you are using, the location of the code that needs to be changed might vary.
So to fix EIS' functioning, you need to open up ~/addons/script.extendedinfo/resources/lib/TheMovieDB.py with a text editor.
Then search for "def extended_movie_info" and in that function change the line that deals with lists from:
python:
"lists": handle_misc(response["lists"]["results"]),
to:
python:
"lists": handle_misc(response["lists"]["results"]) if "lists" in response else ,
(2018-05-22, 08:47)Quihico Wrote: [ -> ] (2018-05-21, 23:58)arzaz Wrote: [ -> ]What's the problem in line 800?
python:
to:
python:
Hello, you have an old version, that code does not exist.
(2018-05-22, 09:15)vania70 Wrote: [ -> ] Hello, you have an old version, that code does not exist.
for latest version, from:
python:
to:
python:
"lists": sort_lists(handle_lists(info["lists"]["results"])) if "lists" in info else [],
or comment out that line as you suggested
Hi, was hoping someone could help me. I'm a bit new to all this. I'm trying to get the extended info to open when I hit a key-mapped button instead of the native info on the skin I use. I was just wondering if someone new what I could type exactly <key id="61656">info</key> instead of info to get the extended info to come up pertaining to the movie that is highlighted.
Many thanks
Ryan F
Hello guys, I have a touchscreen related question.
I was able to navigate TV shows (Seasons/Episodes), but what I cannot do is scroll down past the first 20 or so items of the movie or tv show (all) browser. Aka load the next page. Is there any workaround for that?
I would also like to change the number of items displayed in one page or even better on a widget.
Is it possible?
Thanks for your assistance, folks.
If I could put a "Next Page" button on there somehow it would be awesome. That and access to the left sidebar is the only thing that makes this not usable on touch devices.
The extendedinfo script is showing an error when adding a show to sickrage... the status message is that the tmdb id hasn't been passed along....
I tried both iterations of the sickrage for xbmc/kodi... each throwing back the response..
Other Question: what is the best code to insert in the ratings submission component... I'd like to be able to at minimum send the imdb_id and rating to an external file.. So once I am at the PC a batch script can be run that would throw up the imdb pages for rating sub... still working on a php/curl routine that would do it from the ei scipt...
