Phil, I want to use the old way to fill a list with youtube videos.
With the code below I get the thumbnail in my list okay, but the onclick to play the video doesn't work.
I have tried several different ways for errrr the last 2 hours but I can't seem to get the videos to play.
Do I have the correct format?... Thanks
PHP Code:
<item>
<thumb>$INFO[Window(Home).Property(YoutubeSearch.1.Thumb)]</thumb>
<onclick>PlayMedia($INFO[Window(Home).Property(YoutubeSearch.1.FilenameAndPath])</onclick>
</item>
property with youtube plugin path is named ".Play" (see YouTube.Py)
(2014-11-05, 00:02)phil65 Wrote: [ -> ]property with youtube plugin path is named ".Play" (see YouTube.Py)
ahhhh... Should have looked there but I didn't even think about it. thanks
Hi
i am using version 0.2 of extendedscript now. I would like to update that , but somehow i get an error when installing the new version : add on does not have the correct structure.
all i do is download the zip from the github and install.
I use Aeon MQ5.
What am i doing wrong ?
(2014-11-05, 20:53)DrPepper Wrote: [ -> ]Hi
I use Aeon MQ5.
Doesnt matter since the newest script version wont work with that skin.
Also pay attention to the subforum description: "GUI skin development and xml coding,
for skinners only."
You wouldn't consider changing the maxResults from 20 to 50 in these 2 sections of Youtube.py would you?
PHP Code:
def GetYoutubeSearchVideos(search_string="", hd="", orderby="relevance"):
results = []
if hd and not hd == "false":
hd_string = "&hd=true"
else:
hd_string = ""
search_string = urllib.quote(search_string.replace('"', ''))
base_url = 'https://www.googleapis.com/youtube/v3/search?part=id%2Csnippet&maxResults=20&type=video'
url = '&q=%s&order=%s&key=%s%s' % (search_string, orderby, youtube_key2, hd_string)
results = Get_JSON_response(base_url + url, 0.5)
if results:
return HandleYouTubeVideoResults(results["items"])
else:
return []
def GetYoutubePlaylistVideos(playlistid=""):
base_url = 'https://www.googleapis.com/youtube/v3/playlistItems?part=id%2Csnippet&maxResults=20'
url = '&playlistId=%s&key=%s' % (playlistid, youtube_key2)
# prettyprint(results)
if results:
else:
return []
phil,
When using this script on osx I am getting the following error (and trending shows do not load). Script works fine on my windows pc.
08:35:55 T:2965180416 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.OSError'>
Error Contents: (2, 'No such file or directory', '/Users/livingroommac/Library/Application Support/Kodi/userdata/addon_data/script.extendedinfo\\c2hvd3MvdHJlbmRpbmcuanNvbi83YjIyODFmMGQ0NDFhYjFiZjRmZGMzOWZkNmNjY2YxNQ==.txt')
File "/Users/livingroommac/Library/Application Support/Kodi/addons/script.extendedinfo-master/default.py", line 586, in <module>
Main()
File "/Users/livingroommac/Library/Application Support/Kodi/addons/script.extendedinfo-master/default.py", line 43, in __init__
self._StartInfoActions()
File "/Users/livingroommac/Library/Application Support/Kodi/addons/script.extendedinfo-master/default.py", line 268, in _StartInfoActions
passDataToSkin('TrendingShows', GetTrendingShows(), self.prop_prefix, self.window, self.control, self.handle)
File "/Users/livingroommac/Library/Application Support/Kodi/addons/script.extendedinfo-master/Trakt.py", line 131, in GetTrendingShows
results = Get_JSON_response(base_url, url)
File "/Users/livingroommac/Library/Application Support/Kodi/addons/script.extendedinfo-master/Utils.py", line 442, in Get_JSON_response
if xbmcvfs.exists(path) and ((time.time() - os.path.getmtime(path)) < cache_seconds):
File "/Users/Shared/jenkins/workspace/OSX-32/tools/depends/xbmc-depends/macosx10.8_i386-target/lib/python2.6/genericpath.py", line 54, in getmtime
OSError: (2, 'No such file or directory', '/Users/livingroommac/Library/Application Support/Kodi/userdata/addon_data/script.extendedinfo\\c2hvd3MvdHJlbmRpbmcuanNvbi83YjIyODFmMGQ0NDFhYjFiZjRmZGMzOWZkNmNjY2YxNQ==.txt')
you dont use my newest version so I cant give any support.
Sorry for that didn't delete the old folder one before pasting in the new. All is now working. Thanks.
Came across another error that requires a shutdown to escape from.
json file...
http://pastebin.com/6sL9sbjc
PHP Code:
10:01:01 T:472 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.TypeError'>
Error Contents: unsupported operand type(s) for +=: 'NoneType' and 'unicode'
File "C:\Users\Woodside\AppData\Roaming\Kodi\addons\script.extendedinfo-master\default.py", line 586, in <module>
Main()
File "C:\Users\Woodside\AppData\Roaming\Kodi\addons\script.extendedinfo-master\default.py", line 43, in __init__
File "C:\Users\Woodside\AppData\Roaming\Kodi\addons\script.extendedinfo-master\default.py", line 100, in _StartInfoActions
passDataToSkin('Discography', GetDiscography(self.ArtistName), self.prop_prefix, self.window, self.control, self.handle)
File "C:\Users\Woodside\AppData\Roaming\Kodi\addons\script.extendedinfo-master\resources\lib\TheAudioDB.py", line 163, in GetDiscography
return HandleAudioDBAlbumResult(results)
File "C:\Users\Woodside\AppData\Roaming\Kodi\addons\script.extendedinfo-master\resources\lib\TheAudioDB.py", line 28, in HandleAudioDBAlbumResult
Description += "[CR][CR][B]REVIEW:[/B][CR][CR]" + album["strReview"]
TypeError: unsupported operand type(s) for +=: 'NoneType' and 'unicode'
-->End of Python script error report<--[
(2014-11-08, 05:29)phil65 Wrote: [ -> ]try again.
you da man!... works great
Hi Phil
Is it possible to add in these list's a YouTube search action on click:
Quote:Top Music Artists: info=topartists
Shows appearing on TV: info=airingshows
Shows premiering on TV: info=premiereshows
Trending TV Shows: info=trendingshows
Near Concerts: info=nearevents
Concerts for Venue: info=venueevents
Also it will be great if is possible when you click a TV Show item that it's in the local library, to go to the root of that item. If not then do a YouTube search.
Cheers
Nessus
