(2014-12-22, 00:33)phil65 Wrote: [ -> ] (2014-12-22, 00:07)steved Wrote: [ -> ]Hi Phil. excuse my ignorance but brand new to this XBMC. pulling my hair out i am on open elec xbmc 13.
I have tried to install extendedinfo script. it appears to install but is then not shown in programs. I read earlier that you said this i not a programs. However the YouTube vids i have seen all have it in programs.
if not there where should i look for it? I have no idea if it has been installed.
thanks.
it´s listed under helper add-ons since several weeks.
Ok lost me there. Helper add-ons? Not sure what/where you mean?
add-ons --> helper add-ons. (only visible in helix i think)
vielen Dank. I looked just about everywhere! or not.
I shall have a look there now
thanks once again
just had a look. still no closer. where is "Helper" add-ons?
I looked in both skins and still no closer.
thanks
(2014-12-22, 00:42)phil65 Wrote: [ -> ]add-ons --> helper add-ons. (only visible in helix i think)
I am still running Gotham.
(2014-12-22, 01:07)rmilyard Wrote: [ -> ] (2014-12-22, 00:42)phil65 Wrote: [ -> ]add-ons --> helper add-ons. (only visible in helix i think)
then you cant see it. doesnt really matter.
(2014-12-22, 01:10)phil65 Wrote: [ -> ] (2014-12-22, 01:07)rmilyard Wrote: [ -> ] (2014-12-22, 00:42)phil65 Wrote: [ -> ]add-ons --> helper add-ons. (only visible in helix i think)
Any hints? I have downloaded the zip from github which done in the past. Installed from .zip within xbmc and it doesn't seem to work. When I check the /appdata/roaming/xbmc/addon folder I see it but doesn't work.
(2014-12-22, 01:13)rmilyard Wrote: [ -> ] (2014-12-22, 01:10)phil65 Wrote: [ -> ] (2014-12-22, 01:07)rmilyard Wrote: [ -> ]I am still running Gotham.
what makes you think that it does not work? because you are unable to browse to settings --> add-ons --> helper addons?
(2014-12-22, 01:16)phil65 Wrote: [ -> ] (2014-12-22, 01:13)rmilyard Wrote: [ -> ] (2014-12-22, 01:10)phil65 Wrote: [ -> ]then you cant see it. doesnt really matter.
I am running 5 PCs. 2 are running version 0.5.0 of script and seem to work. When I view movie collections with the 0.5.0 version using Aero MQ5 skin I get the extended info on the info. IE: Blu rays in collection etc.
Using one from github I do not.
(2014-12-22, 01:28)rmilyard Wrote: [ -> ] (2014-12-22, 01:16)phil65 Wrote: [ -> ] (2014-12-22, 01:13)rmilyard Wrote: [ -> ]Any hints? I have downloaded the zip from github which done in the past. Installed from .zip within xbmc and it doesn't seem to work. When I check the /appdata/roaming/xbmc/addon folder I see it but doesn't work.
that´s because MQ5 is outdated and not maintained.
(2014-12-22, 01:32)phil65 Wrote: [ -> ] (2014-12-22, 01:28)rmilyard Wrote: [ -> ] (2014-12-22, 01:16)phil65 Wrote: [ -> ]what makes you think that it does not work? because you are unable to browse to settings --> add-ons --> helper addons?
Also found 0.0.2 and works. Hmmmm...
So saying MQ5 is outdated. Interested. What are people using now instead?
(2014-12-22, 01:36)rmilyard Wrote: [ -> ] (2014-12-22, 01:32)phil65 Wrote: [ -> ] (2014-12-22, 01:28)rmilyard Wrote: [ -> ]I am running 5 PCs. 2 are running version 0.5.0 of script and seem to work. When I view movie collections with the 0.5.0 version using Aero MQ5 skin I get the extended info on the info. IE: Blu rays in collection etc.
not part of this thread. (this is devs only in general)
phil,
I will preface this by saying I have never taken a class in computer science but have done the odd modification of .xml since using Kodi.
As you can see below, I have an almost complete DialogVideoInfo modeled for Aeon Nox 5. I have, however, run into a few issues. I 'm not sure if the issues are related to bad code or conflicts with the way extendedinfo functions.
Here is a sample screenshot of where I'm at:
Movie Set View:
The second pic includes a roadmap of my current issues. Basically, I used three togglebuttons to hide six panels with content in each panel:
Plot/Cast,
Trailers/Movie Set and
Recommended/YouTube.
Recommended Movies:
My outstanding issues are as follows:
- Studio icons won't load. As you can see, I can get the text, but the icon won't load despite having the correct path.
- Panels 350 & 1150 won't return any calls. Panel 350 is supposed to call YouTube videos. Panel 1150 calls a list of Trailers. I read the extendedinfo documentation and it appears these call may be different, but I couldn't understand how to correct the syntax.
Panel ID's:- Plot - 800 (working)
- Cast - 1000 (working)
- Trailers - 1150 (not working)
- Movie Set - 250 (working)
- Recommended - 150 (working)
- YouTube - 350 (not working)
Any further instruction would be welcome.
Sorry, I can only point to the reference implementation for now. Do it like it is done there. This is a constant WIP atm so creating documentation does not make too much sense.
(2014-12-22, 06:09)phil65 Wrote: [ -> ]Sorry, I can only point to the reference implementation for now. Do it like it is done there. This is a constant WIP atm so creating documentation does not make too much sense.
You are too fast. A forum member directed me to the the issue with the <ondown> issue. He says the studio icon issue is related to its multi-call of studio names not matching the corresponding .png. Example: studio1/studio2/studio3, etc. The pictures above display this.
The YouTube and Trailer sections remain unsolved.
