(2014-12-30, 00:25)phil65 Wrote: [ -> ]try again.
That did it - love a one line fix..
phil,
I discovered another bug. $INFO[Window.Property(actor.Deathage)] does not return a value. Nor does the call for Top250. The first call is likely related to the age "Unavailable" problem.
they both donĀ“t exist and are only mentioned in readme because I copy and pasted that part of the documentation from old metadata actors script. The documentation is useless concerning the dialogs for now, look in reference implementation instead. (you will see that I dont use deathage and top250 there)
The script can now also be accessed from Programs section now btw. It will start with the MovieDB Browse Dialog (as seen in the video) without any filters.
(2014-12-31, 02:06)phil65 Wrote: [ -> ]Actual progress:
That's really cool! Looks super slick!
Phil,
This is amazing! You have opened up hours of discovery in TMDB! Thank you!
Regards,
Bart
hello! I installed extendedinfo on helix (skin aeon shednox) and unfortunately, I have no data that appears...
Did I miss something in config? Note that I have not been able to install the script from the zip but I had to unpack and paste it in the addon folder because of a problem with the structure of the addon ...
(2014-12-31, 10:48)Warner306 Wrote: [ -> ]It took me a short time to discover this.
Oh no, the super-clever Warner306 is back.
Say welcome to my ignore list.
(2014-12-31, 17:13)phil65 Wrote: [ -> ] (2014-12-31, 10:48)Warner306 Wrote: [ -> ]It took me a short time to discover this.
It was a joke, phil. I'm not trying to be a pain.
I can remove the photo if it bothers you.
This looks fantastic.
Any plans for implementing this for TV Shows via thetvdb as well?
(2015-01-01, 20:53)cd492 Wrote: [ -> ] (2014-12-31, 02:06)phil65 Wrote: [ -> ]Actual progress:
nope, in comparison to moviedb API the thetvdb API completely sucks.
tv from moviedb is already integrated.
ANDing and ORing is possible now, too.
Wow, just tested the latest bit's. This is really starting to come to gether.
TMDb get ready
16:08:22 T:3740 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.TypeError'>
Error Contents: unsupported operand type(s) for +: 'NoneType' and 'str'
File "C:\Users\Wes\AppData\Roaming\Kodi\addons\script.extendedinfo-master\default.py", line 56, in <module>
Main()
File "C:\Users\Wes\AppData\Roaming\Kodi\addons\script.extendedinfo-master\default.py", line 22, in __init__
self.control = StartInfoActions(self.infos, self.params)
File "C:\Users\Wes\AppData\Roaming\Kodi\addons\script.extendedinfo-master\resources\lib\process.py", line 196, in StartInfoActions
data = GetTrendingShows(), "TrendingShows"
File "C:\Users\Wes\AppData\Roaming\Kodi\addons\script.extendedinfo-master\resources\lib\Trakt.py", line 145, in GetTrendingShows
return HandleTraktTVShowResult(results)
File "C:\Users\Wes\AppData\Roaming\Kodi\addons\script.extendedinfo-master\resources\lib\Trakt.py", line 120, in HandleTraktTVShowResult
'Label2': tvshow["air_day"] + " " + tvshow["air_time"],
TypeError: unsupported operand type(s) for +: 'NoneType' and 'str'
16:08:22 T:3784 NOTICE: finished
Is this an issue with the skin im using or something that changed with the latest Trakt update?
