Full Version: script.extendedinfo
(2015-03-09, 22:13)Walt74 Wrote: [ -> ]
(2015-03-09, 21:35)phil65 Wrote: [ -> ]
(2015-03-09, 19:51)Walt74 Wrote: [ -> ]Hello Phil,
i am having full kodi lock-ups when trying to use the script.extendedinfo i captured a debug log, its python related, but way above my head.
see http://pastebin.com/kPcgtpyg
could you have a look at it ?
use latest GIT and upload another debug log please.
As requested, i am using the latest GIT version. Same result a Full kodi lock-up after an error message. See the debug.log http://pastebin.com/0hLcTpwt
Let me know if you want me to try stuff.
PIL does not import correctly. not sure if that is an Apple problem in general or just on your local installation.
(2015-03-09, 22:09)phil65 Wrote: [ -> ]
(2015-03-09, 22:04)sualfred Wrote: [ -> ]Thx, but as you said, experimental and I get script errors ^^.
Whatever... would be just a nice to have for me to run it directly.
debug log?
My fault, it's working. Typo Tongue
(2015-03-09, 22:19)phil65 Wrote: [ -> ]
(2015-03-09, 21:35)phil65 Wrote: [ -> ]use latest GIT and upload another debug log please.
Phil, just tested it on a macbook. On kodi 14.1 no problems, Updated to 14.2 beta and the same problem occurs as above.
Do i have to move the bug report to the kodi 14.2 beta or osx section ? Or is it still correct here.
(2015-03-09, 18:03)phil65 Wrote: [ -> ]
(2015-03-08, 04:24)jurialmunkey Wrote: [ -> ]Bit of a feature request. I'm wondering if its a possibility with info=directormovies to also have a property with the director's biography in it? Additionally, is there any chance of having Plot for themoviedb content - e.g. incinemas, directormovies, similarmovies, popularmovies etc.
I'm currently using a custom window using these and the plot would be really useful.
Plot for themoviedb is not possible, would need one JSON call for every single movie.
Also, director biography would only be possible with one additional API call. Will put that on my to-do list.
Shame about the plot, but excellent re: bio -- will be really useful.
(2015-03-06, 02:04)jurialmunkey Wrote: [ -> ]I've also noticed that if a video is playing and the extended info dialog is launched from a container filled by extendedinfo (e.g. moviedb incinemas) then it will stop the now playing video. I'm guessing this is a left over from launching youtube trailers by default?
That one should be fixed now on GIT. Could you verify?
(2015-03-11, 03:20)phil65 Wrote: [ -> ]
All seems to be working fine Smile
Tested with a few different ones -- incinemas, upcoming, directormovies, similarmovies -- all with no problems. Additionally, the issue with the extendedinfo dialog covering youtube trailers when launched from plugin filled containers also appears to be fixed now.
(2015-03-11, 05:31)jurialmunkey Wrote: [ -> ]
Ok, good to hear, was probably related to it. Waiting for more bug reports, my list is getting short. Wink (apart from episode area, that´s still WIP)
It seems the last couple of Isengard nightlies have broken the ability to play youtubes or trailers. Not sure if it is temporary
or if a code change for this script would be needed to fix. No problems with any nightly from 3/9/2015 and back.
Easy to confirm with newest nightly but if you need more info I'll try to help further.
PHP Code:
04:05:19 T:6904  NOTICE: -->Python Interpreter Initialized<--
04:05:19 T:6904  NOTICEversion 2.0.5 started
04
:05:19 T:6904  NOTICEscript.module.youtube.dlyoutube_dl core version2014.12.17.2
04
:05:19 T:6904   ERROR:C:\Users\Woodside\AppData\Roaming\Kodi\addons\script.module.youtube.dl\lib\YDStreamExtractor.py:360UserWarningExternal use of disableDASHVideo() is deprecatedIt is now handled by module settings
                                              warnings
.warn("External use of disableDASHVideo() is deprecated. It is now handled by module settings")
04:05:19 T:6904   ERROR: [debugEncodingslocale cp1252fs mbcsout missing (instance), pref cp1252
04
:05:19 T:6904  NOTICE: .
04:05:19 T:6904   ERROR: [debugyoutube-dl version 2014.12.17.2
04
04:05:19 T:6904   ERROR: [debugPython version 2.7.8 Windows-7-6.1.7601-SP1
04
04:05:19 T:6904   ERROR: [debugexe versionsnone
04
04:05:19 T:6904   ERROR: [debugProxy map: {}
04:05:19 T:6904  NOTICE: .
04:05:22 T:6904  NOTICEscript.module.youtube.dlQuality1
04
:05:22 T:6904  NOTICEscript.module.youtube.dl: [Rihanna And Kanye West And Paul McCartney FourFiveSecondsUsing Preferred Format22 (1280x720)
04:05:22 T:6904  NOTICEfinished
04
:05:22 T:4896   ERRORdll_fputs emulated function failed
04
:05:22 T:4896  NOTICEDVDPlayerOpeninghttps://r5---sn-8xgp1vo-uv5e.googlevideo.com/videoplayback?fexp=907263%2C927622%2C934954%2C9406843%2C9407751%2C9407817%2C940925%2C942645%2C942901%2C943606%2C943917%2C948124%2C951703%2C952302%2C952612%2C952901%2C955301%2C957201%2C959701%2C962720&mm=31&key=yt5&id=o-AEAkFOYwXcNz-z6uzwKRMSRmcqupi0iVfzEW-90b1MY7&gcr=us&dur=191.796&source=youtube&ms=au&requiressl=yes&ip=173.51.207.251&pl=18&mv=m&ratebypass=yes&initcwndbps=1567500&ipbits=0&mt=1426071794&itag=22&expire=1426093514&sparams=dur%2Cgcr%2Cid%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Cmime%2Cmm%2Cms%2Cmv%2Cpl%2Cratebypass%2Crequiressl%2Csource%2Cupn%2Cexpire&upn=lyv1obfglt8&sver=3&mime=video%2Fmp4&signature=F546F1F2EBD1166EE86D862825A895D59C3B6806.261231CD47B646BBF6DF8FEA194EABF745257135|User-Agent=Mozilla%2F5.0+%28X11%3B+Linux+x86_64%3B+rv%3A10.0%29+Gecko%2F20100101+Firefox%2F10.0+%28Chrome%29
04:05:22 T:4896 WARNINGCDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
04
:05:22 T:2020  NOTICEThread DVDPlayer startauto deletefalse
04
:05:22 T:2020  NOTICECreating InputStream
04
:05:22 T:2020   ERRORdll_fputs emulated function failed
04
:05:22 T:2020   ERRORPrevious line repeats 1 times.
04:05:22 T:2020   ERRORCCurlFile::FillBuffer Failed with socket error:Unknown error
04
:05:22 T:2020   ERRORCCurlFile::CReadState::Connectdidn't get any data from stream.
04:05:22 T:2020   ERROR: XFILE::CFileCache::Open - failed to open source <https://r5---sn-8xgp1vo-uv5e.googlevideo.com/videoplayback?fexp=907263%2C927622%2C934954%2C9406843%2C9407751%2C9407817%2C940925%2C942645%2C942901%2C943606%2C943917%2C948124%2C951703%2C952302%2C952612%2C952901%2C955301%2C957201%2C959701%2C962720&mm=31&key=yt5&id=o-AEAkFOYwXcNz-z6uzwKRMSRmcqupi0iVfzEW-90b1MY7&gcr=us&dur=191.796&source=youtube&ms=au&requiressl=yes&ip=173.51.207.251&pl=18&mv=m&ratebypass=yes&initcwndbps=1567500&ipbits=0&mt=1426071794&itag=22&expire=1426093514&sparams=dur%2Cgcr%2Cid%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Cmime%2Cmm%2Cms%2Cmv%2Cpl%2Cratebypass%2Crequiressl%2Csource%2Cupn%2Cexpire&upn=lyv1obfglt8&sver=3&mime=video%2Fmp4&signature=F546F1F2EBD1166EE86D862825A895D59C3B6806.261231CD47B646BBF6DF8FEA194EABF745257135|User-Agent=Mozilla%2F5.0+%28X11%3B+Linux+x86_64%3B+rv%3A10.0%29+Gecko%2F20100101+Firefox%2F10.0+%28Chrome%29>
04:05:22 T:2020   ERROR: CDVDPlayer::OpenInputStream - error opening [https://r5---sn-8xgp1vo-uv5e.googlevideo.com/videoplayback?fexp=907263%2C927622%2C934954%2C9406843%2C9407751%2C9407817%2C940925%2C942645%2C942901%2C943606%2C943917%2C948124%2C951703%2C952302%2C952612%2C952901%2C955301%2C957201%2C959701%2C962720&mm=31&key=yt5&id=o-AEAkFOYwXcNz-z6uzwKRMSRmcqupi0iVfzEW-90b1MY7&gcr=us&dur=191.796&source=youtube&ms=au&requiressl=yes&ip=173.51.207.251&pl=18&mv=m&ratebypass=yes&initcwndbps=1567500&ipbits=0&mt=1426071794&itag=22&expire=1426093514&sparams=dur%2Cgcr%2Cid%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Cmime%2Cmm%2Cms%2Cmv%2Cpl%2Cratebypass%2Crequiressl%2Csource%2Cupn%2Cexpire&upn=lyv1obfglt8&sver=3&mime=video%2Fmp4&signature=F546F1F2EBD1166EE86D862825A895D59C3B6806.261231CD47B646BBF6DF8FEA194EABF745257135|User-Agent=Mozilla%2F5.0+%28X11%3B+Linux+x86_64%3B+rv%3A10.0%29+Gecko%2F20100101+Firefox%2F10.0+%28Chrome%29]
(2015-03-11, 13:17)woodside Wrote: [ -> ]It seems the last couple of Isengard nightlies have broken the ability to play youtubes or trailers. Not sure if it is temporary
Yep, the YouTube addon is also affected. With the nightly KodiSetup-20150309-93a2439-master everything is fine.
No need to report stuff from latest nightlies... As name says, they aren´t stable.
Just a quick question, I havent tested anything or looked into it, but it the trakt part of this addon broken or is it still running despite the v1 api?
(2015-03-11, 14:46)phil65 Wrote: [ -> ]No need to report stuff from latest nightlies... As name says, they aren´t stable.
Yeah... I didn't know if it was a temporary breakage due to it being a nightly or not. More or less just a heads up for anyone reading that those who are using the latest nightlies will not be able to play youtubes or trailers until it's fixed one way or the other. cheers Wink
(2015-03-11, 15:29)Razze Wrote: [ -> ]Just a quick question, I havent tested anything or looked into it, but it the trakt part of this addon broken or is it still running despite the v1 api?
v1 still running.
(2015-03-11, 15:38)phil65 Wrote: [ -> ]
v1 still running.
would it be an valid option for you to use
https://github.com/fuzeman/trakt.py (https://github.com/Razzeee/script.module.trakt)
for the interaction? when it supports all needed cases?
(2015-03-11, 16:45)Razze Wrote: [ -> ]
v1 still running.
not sure if I will get it in line with the way I´m caching etc, I tend to write that stuff myself. Things are a bit different for plugin stuff when used for lists ( <content> method)
