Just for your notice, but I think you are already beware of it:
Since Google drops the v2 API, there's always the YouTube device support video on position #1 (info=youtubeusersearch).
(2015-04-18, 14:40)sualfred Wrote: [ -> ]And found a small math issue with "$INFO[Window.Property(actor.Age)". It ignores the persons death.
Pushed a possible fix, untested though.
Didnt add any extra labelling for now, just changed it so it prints out age of death instead of actual age if person died.
Tested. Ends up in a endless loading loop
try again using latest commit, please.
(2015-04-22, 23:54)phil65 Wrote: [ -> ]try again using latest commit, please.
Sry, wasn't at the PC anymore.
Yes, everything works. Thx.
phil65:
Not sure if it is script related (tried 2 different skins) or not, but let me describe the issue:
I believe there is an issue when you select an actor and there is more than one with the same name, "please wait" message goes on forever.
I noticed it with the movie "All about eve", I selected Anne Baxter and 2 come up: Anne Baxter and Lee-Ann Baxter, hopefully you have this movie so you can test. using version 2.0.7
(2015-04-26, 04:34)Edworld Wrote: [ -> ]phil65:
you are correct, should be fixed with
https://github.com/phil65/script.extende...8a80a71f6b
(2015-04-26, 04:59)phil65 Wrote: [ -> ] (2015-04-26, 04:34)Edworld Wrote: [ -> ]phil65:
you are correct, should be fixed with https://github.com/phil65/script.extende...8a80a71f6b
Thanks, works like a charm!
Just discovered this addon and loving it.
Interested in Spanish Translations?
What happened to the ExtendedInfo addon with Isengard? I can't find it in My Addons nor can I find it in the Kodi repo.
(2015-04-26, 16:01)jurrabi Wrote: [ -> ]Just discovered this addon and loving it.
The add-on will appear on Transifex once our translation guy finished his planned changes to our translation system.
phil65
How do you make it with the pickup the color from the cover and use it as border or diffuse color?
This is a awesome feature for kodi, is there a way to explain or use it for kodi?
Special thx
