(2015-06-01, 16:52)im85288 Wrote: [ -> ]Phil, I've started integrating your changes such as the custom dialogvideo window and it's pretty amazing how it all fits together. I wasn't sure if Tvtunes was supported so asked on this thread: http://forum.kodi.tv/showthread.php?tid=214287&page=9 where the author said it was up to you if you could/would support it.
Cheers
In which way should I support it? Remember that my movie infodialog is often used for movies which are not in the local library.
I was thinking more for when it was browsing TV shows but I guess it could also be cool if local movies were supported.
(2015-06-02, 00:49)im85288 Wrote: [ -> ]I was thinking more for when it was browsing TV shows but I guess it could also be cool if local movies were supported.
Had a quick look, the add-on only allows to get started via some backend mode, so there is no way to manually pass some movie id / movie title to it.
Sorry if this request was discussed before...
Would it be possible to have an option to add movies from the ExtendedInfo Script to Couchpotato?
(2015-06-06, 13:57)werewolf80 Wrote: [ -> ]Sorry if this request was discussed before...
there already is a button for that in the "manage" menu.
(2015-06-06, 16:10)phil65 Wrote: [ -> ] (2015-06-06, 13:57)werewolf80 Wrote: [ -> ]Sorry if this request was discussed before...
Thanks for the response Phil, though the hint hasn't reached me. Got another hint? When I open the info-screen to a movie in my library I go to the extended info... then there are movies recommended and such. Any way to add these to couchpotato?
And when running Extended Info as a program addon, I can also add these moviess to couchpotato??
What is the Manage menu ou are refering to??
(2015-06-06, 23:36)werewolf80 Wrote: [ -> ] (2015-06-06, 16:10)phil65 Wrote: [ -> ] (2015-06-06, 13:57)werewolf80 Wrote: [ -> ]Sorry if this request was discussed before...
depends on the skin you use. also possible that it is not included.
Im using the Titan skin...
If not supported, by any chance possible with key-mapping?
new features:
-T9 Text input for TMDB search
- search results now update on-the-fly
- added google suggestions for autocompletion
Sorry... the maker of the Titan skin has add it already.... Solved!
Cheers
Google AutoCompletion possible for DialogKeyBoard.xml now, too
plugin://script.extendedinfo?info=autocomplete&&id=$INFO[Control.GetLabel(312).index(1)]
(Isengard-only)
