(2015-06-09, 13:36)phil65 Wrote: [ -> ] (2015-06-09, 13:25)Dumyat Wrote: [ -> ]Something I've noticed and quite curious about is why all the movie titles I view when using this script return movie certifications for the US? My details on The Movedb site are set to the UK and Europe time zone. I also have the correct credentials and preferences set for both this script and the movie database plugin in Kodi, but I'm still not getting UK certifications for the movie titles I view. Is somebody able to tell me if I'm doing anything wrong, or for that matter if I need to do anything further?
atm it always takes the first certification returned by the API. would need some work to be able to prioritize them.
Ok, That's great. Thanks for the quick reply
Was more curious than anything else why it wasn't showing them.....Now I know why.
That autocompletion feature is awesome. Thanks for this.
(2015-06-09, 12:16)Gade Wrote: [ -> ]Pressing button id="6006" (Already Rated) in Script-DialogVideoInfo.xml seems to not go to the user ratings window - the ratings are missing (ListItem.Property(User_Rating)):
should also be fixed now.
(2015-06-09, 15:02)sualfred Wrote: [ -> ]That autocompletion feature is awesome. Thanks for this.
Thx
I guess it's probably the fastest-adopted script feature ever.
(2015-06-09, 12:16)Gade Wrote: [ -> ]Also, in Script-VideoList.xml the property Container(500).ListItem.Year seems empty. The Year property is generally an issue with 3.0.0, which you will see below.
Anything left to fix?
(2015-06-09, 18:21)phil65 Wrote: [ -> ] (2015-06-09, 12:16)Gade Wrote: [ -> ]Also, in Script-VideoList.xml the property Container(500).ListItem.Year seems empty. The Year property is generally an issue with 3.0.0, which you will see below.
Works great now, thanks a lot for this.
The only thing is that the user ratings using button 6006 are not updated? Script-VideoList.xml only shows 1 movie at all times. As I understand it, this is a feature to locally rate the movies, even when not logged into tmdb?
Btw, fantastic new features in 3.0.0. I especially like the context menu for posters/fanart, which works great.
(2015-06-09, 21:55)Gade Wrote: [ -> ] (2015-06-09, 18:21)phil65 Wrote: [ -> ] (2015-06-09, 12:16)Gade Wrote: [ -> ]Also, in Script-VideoList.xml the property Container(500).ListItem.Year seems empty. The Year property is generally an issue with 3.0.0, which you will see below.
will have a look at non-refreshing rating list.
You also vote online even if you´re not logged in. Nothing is saved on disk except cache. (This also means that you lose your ratings if you delete your complete cache because you will have to generate a new guest user token then. That one is also in cache.)
Thx much
(2015-06-09, 21:59)phil65 Wrote: [ -> ] (2015-06-09, 21:55)Gade Wrote: [ -> ] (2015-06-09, 18:21)phil65 Wrote: [ -> ]should also be fixed now.
Thx much
That makes a lot of sense. Switching to 2.0.10 gives me all the user rated movies back, but only 1 movie appear in 3.0.0.
Let me know if there's anything I can do to help or test it out
(2015-06-09, 22:18)Gade Wrote: [ -> ] (2015-06-09, 21:59)phil65 Wrote: [ -> ] (2015-06-09, 21:55)Gade Wrote: [ -> ]Works great now, thanks a lot for this.
Thx much
The exact reason is that the cache files are now placed in subfolders inside addon_data/script.extendedinfo. You could get your old ratings back by moving all textfiles from folder root into the MovieDB subfolder (+ restarting kodi) )
(2015-06-09, 22:30)phil65 Wrote: [ -> ] (2015-06-09, 22:18)Gade Wrote: [ -> ] (2015-06-09, 21:59)phil65 Wrote: [ -> ]will have a look at non-refreshing rating list.
Thx much
That definately brought the previously rated movies back. But newly rated movies are not added to the list / updated.
(2015-06-10, 01:02)Gade Wrote: [ -> ]Thanks!
Should also be fixed now.
(2015-06-09, 14:00)phil65 Wrote: [ -> ] (2015-06-09, 06:23)braz Wrote: [ -> ]Just started testing the plugin paths I use and got an error with topartists.
plugin://script.extendedinfo?info=topartists
http://pastebin.com/rW8nw8KL
toprentals, trendingshows, trendingmovies, and dailybabes all worked fine.
should be fixed now.
(2015-06-09, 14:01)phil65 Wrote: [ -> ] (2015-06-09, 06:43)braz Wrote: [ -> ]Ok, here's a strange one, didn't notice this before. I can't get out of the video info or actor info windows by pressing back or esc. Log says its an unknown control type for python. Not sure if I did anything to cause this, tried a restart but got the same results.
http://pastebin.com/dmDP6JBV
also fixed.
Fixes confirmed here, thanks!
