(2015-06-26, 17:33)phil65 Wrote: [ -> ]..forgot to mention: The add-on now automatically closes DialogVideoInfo.xml when opening an infodialog and re-opens it when finished.
Let me know if such behaviour is wanted or if skinners should deal with that "manually" somehow.
This behaviour helps me a lot - so thanks
(2015-06-27, 00:57)phil65 Wrote: [ -> ]fixed, thx.
That's gotta be the quickest fix ever, thanks!
I won't get any content with ?info=youtubeusersearch anymore. (GitHub version of today).
Atm, I only have 1 device here to test , so I don't know if the problem is on my side.
Hi Phil,
Is it possible to control which .xml are executed when pressing 'I'. I was wondering if a switch could control execution of the skin version of scrip-exetendedinfo....xml or your own in the relevant addon directory?. This would give the user to choice to run the skin based extended info scripts or your own?
Just wondered?
Mike.
When running the script with this code in movieinformation, i get an
error:
<content target="video">plugin://script.extendedinfo?info=studio&&studio=$INFO[ListItem.Studio]</content>
Hi Phil,
FYI: I get the following error when selecting a recommended series from a widget in Aeon Nox Silvo:
http://pastebin.com/DuE4XHnQ
Thx for your hard work!
Edit: fixed in 1 min! Great!
(2015-06-28, 17:19)phil65 Wrote: [ -> ] (2015-06-28, 10:20)sualfred Wrote: [ -> ]I won't get any content with ?info=youtubeusersearch anymore. (GitHub version of today).
Fixed, thx.
Hmm.. gave it a try but nothing changed on my side. Still no content.
