09:09:54 T:1908 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.AttributeError'>
Error Contents: 'module' object has no attribute 'ACTION_OSD_SHOW_LEFT'
File "C:\Users\danrach\AppData\Roaming\Kodi\addons\script.extendedinfo\default.py", line 45, in <module>
Main()
File "C:\Users\danrach\AppData\Roaming\Kodi\addons\script.extendedinfo\default.py", line 19, in __init__
start_info_actions(self.infos, self.params)
File "C:\Users\danrach\AppData\Roaming\Kodi\addons\script.extendedinfo\resources\lib\process.py", line 371, in start_info_actions
name=params.get("name", ""))
File "C:\Users\danrach\AppData\Roaming\Kodi\addons\script.extendedinfo\resources\lib\WindowManager.py", line 161, in open_actor_info
from dialogs import DialogActorInfo
File "C:\Users\danrach\AppData\Roaming\Kodi\addons\script.extendedinfo\resources\lib\dialogs\DialogActorInfo.py", line 10, in <module>
from DialogBaseInfo import DialogBaseInfo
File "C:\Users\danrach\AppData\Roaming\Kodi\addons\script.extendedinfo\resources\lib\dialogs\DialogBaseInfo.py", line 11, in <module>
from ..OnClickHandler import OnClickHandler
File "C:\Users\danrach\AppData\Roaming\Kodi\addons\script.extendedinfo\resources\lib\OnClickHandler.py", line 84, in <module>
"osdleft": xbmcgui.ACTION_OSD_SHOW_LEFT,
AttributeError: 'module' object has no attribute 'ACTION_OSD_SHOW_LEFT'
09:10:12 T:5592 ERROR: dll_fgets emulated function failed
09:10:28 T:2324 NOTICE: Thread LanguageInvoker start, auto delete: false
09:10:28 T:6136 NOTICE: Previous line repeats 1 times.
09:10:28 T:6136 NOTICE: -->Python Interpreter Initialized<--
09:10:28 T:2324 NOTICE: Previous line repeats 1 times.
09:10:28 T:2324 NOTICE: version 3.0.1 started
09:10:29 T:2324 NOTICE: finished
09:10:29 T:5592 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&dbid=183
09:10:29 T:5592 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&dbid=10
09:10:29 T:5592 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=68724
09:10:29 T:5592 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=75612
09:10:29 T:5592 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=19995
09:10:29 T:5592 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=13475
09:10:29 T:5592 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=2103
09:10:29 T:5592 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=8656
09:10:29 T:5592 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&dbid=99
09:10:29 T:5592 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=568
09:10:29 T:5592 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=957
09:10:29 T:5592 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=679
09:10:29 T:5592 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=1892
09:10:29 T:5592 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=1891
09:10:29 T:5592 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&dbid=204
09:10:29 T:5592 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&dbid=193
09:10:29 T:5592 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&dbid=202
09:10:29 T:5840 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=698
09:10:29 T:5840 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=40430
09:10:29 T:4072 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://script.extendedinfo/?info=extendedinfo&&id=62
09:10:35 T:5484 NOTICE: Thread LanguageInvoker start, auto delete: false
09:10:35 T:5484 NOTICE: -->Python Interpreter Initialized<--
09:10:35 T:5484 NOTICE: version 3.0.1 started
09:10:35 T:264 ERROR: PlayMedia could not play media: plugin://script.extendedinfo/?info=extendedinfo&&dbid=183
09:10:35 T:5484 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
File "C:\Users\danrach\AppData\Roaming\Kodi\addons\script.extendedinfo\plugin.py", line 91, in <module>
Main()
File "C:\Users\danrach\AppData\Roaming\Kodi\addons\script.extendedinfo\plugin.py", line 21, in __init__
File "C:\Users\danrach\AppData\Roaming\Kodi\addons\script.extendedinfo\resources\lib\process.py", line 365, in start_info_actions
File "C:\Users\danrach\AppData\Roaming\Kodi\addons\script.extendedinfo\resources\lib\WindowManager.py", line 68, in open_movie_info
from dialogs import DialogVideoInfo
File "C:\Users\danrach\AppData\Roaming\Kodi\addons\script.extendedinfo\resources\lib\dialogs\DialogVideoInfo.py", line 13, in <module>
