2015-11-09, 15:47
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151
2015-11-09, 15:47
2015-11-10, 06:16
(2015-10-30, 06:23)guido1138 Wrote: [ -> ]HI Phil,Hi Phil, I'm not sure you had a chance to look into this since I posted the log as you requested, but I wanted to give a little update...
Many thanks for making this indispensible script. I expect you're quite busy these days, but I'm hoping if you have a moment you might comment on my earlier post regarding the 'info=extendedepisodeinfo' call:
Post: #1424
All the best...
EDIT: A log of the extendedinfo call is here as requested. However, my original question was around the status of 'extenedepisodeinfo' based on your earlier post --- whether still an undocumented WIP or not --- so if you could also comment on that I'd really appreciate it.
I updated to the latest git version after noticing a log exception that you recently fixed, but I still see the same behaviour as before: the extendedepisodeinfo dialog has only the title and release date displayed, without the plot shown (same as Post #1424). There are also no errors or exceptions in the debug log this time.
I checked the cached TMDB text file listed in the log, and it does include the plot information: 6655da7087ad403a3ae360e3b29a2210.txt.
Another thought I had was there might be a problem with the script-ExtendedInfo Script-DialogVideoInfo.xml file used in Eminence 2. To rule this out, I set "Force native appearance" in Extendedinfo and tried again the extendedepisodeinfo call. The dialog style/theme changed as expected, but still showed only title and date, without plot or other details.
My thanks if you could look into this, offer other testing suggestions, or clarify expected behaviour for extendedepisode info.
Best regards...
2015-11-12, 11:19
Having problems with the all of a sudden I get 2 error messages all the time:
cannot get session id
login failed.
Have checked username and pwd for tmdb and they work on their website?
I don't have a log yet so just wondering if anyone else is / has had this issue?
login failed.
2015-11-19, 11:19
(2015-10-02, 18:49)phil65 Wrote: [ -> ]will look into 3)http://forum.kodi.tv/showthread.php?tid=...pid2121494
Phil, Hate to remind you, but it's really annoying that we can't manually search for subtitles.. I Hope you'll have time to take a look please,
let me know if tests is needed or any help, maybe you can just point me to the relevant code, ill find someone else to fix it.
much appreciated.
2015-11-21, 21:17
Hi Phil,
I really enjoy your script. I have been trying to do some little modifications on it so I can make more use of it. I prefer extended's built-in youtube browser/player over the default kodi youtube-addo beause it's so much more esthetically pleasing.
So for instance I edited the default.py so it will let me start in TV/Youtube-mode but there's this bug I can not seem to get rid off, probably because I am not a proper developer. I was wondering if you or anybody else here might give me some advice/pointers on how to fix it?
Ok, so I've added this to the default.py
so I can start in TV Show-mode by doing "RunScript(script.extendedinfo,mode=tv1)" but when I do that and then back out of Extended I always have to go through the movie-list. If I start extended the normal way and change to "TV Show" and back out that doesn't happen. What to do to get it working as I want it? (i.e. start with type: "TV Show" and not having to go through type: Movie when backing out of extended info)
elif param.startswith('mode=tv1'):
from resources.lib.WindowManager import wm
wm.open_video_list(force=True,
media_type="tv",
prev_window=None)
2015-11-22, 00:30
Hello Phil
First of all thanks! for this gr8 script.
Feature Request:
Could you add "Similar Artists" (Last FM) to the Script
Think it would fit in Nicely.
Additional Infos in case it is of any Interest:
In Helix i use the artistslideshow-skript to provide this Infos. It worked from Time to Time but not verry smooth.
Now with Isengard it stop working No Idea why, (think the Autor from the Artistslideshow-script hase also no clue) + it seems he don't care .
Anyway; think "Similar Artists" would fit in much better in your ExtendendInfo-script.
As you already catch some Information from Last.fm i was hoping it wouldnd need to much efford to include "Similar Artists" to.
Would be cool if you could give it a go. / if you dicide to give it a go.
Regards.
Feature Request:
Regards.
2015-11-22, 15:57
(2015-11-04, 12:23)Tomislawww Wrote: [ -> ]Hello,
In Mimic skin I get extendedinfo script errors when I open info dialog.
LOG
I have the same problem, anyone got any idea how to solve this ?
log: http://pastebin.com/84QwTj1S
2015-11-24, 14:49
same problem for me as these guys
(2015-11-22, 15:57)edd-- Wrote: [ -> ](2015-11-04, 12:23)Tomislawww Wrote: [ -> ]Hello,
LOG
2015-11-24, 18:27
Hi Phil,
I've this error in debug log:
Can you help me?
17:24:52 T:11012 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.KeyError'>
Error Contents: ('mbid',)
File "C:\Users\pino71\AppData\Roaming\Kodi\addons\script.extendedinfo\plugin.py", line 91, in <module>
Main()
File "C:\Users\pino71\AppData\Roaming\Kodi\addons\script.extendedinfo\plugin.py", line 21, in __init__
start_info_actions(self.infos, self.params)
File "C:\Users\pino71\AppData\Roaming\Kodi\addons\script.extendedinfo\resources\lib\process.py", line 48, in start_info_actions
discography = get_artist_albums(params.get("artist_mbid"))
File "C:\Users\pino71\AppData\Roaming\Kodi\addons\script.extendedinfo\resources\lib\LastFM.py", line 218, in get_artist_albums
return handle_lastfm_albums(results)
File "C:\Users\pino71\AppData\Roaming\Kodi\addons\script.extendedinfo\resources\lib\LastFM.py", line 81, in handle_lastfm_albums
'mbid': album['mbid'],
KeyError: ('mbid',)
17:24:52 T:5888 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://script.extendedinfo/?info=discography&&artistname=Georgie Fame
Can you help me?
2015-11-24, 18:50
should be fixed with https://github.com/phil65/script.extende...8f5de2777f
2015-11-25, 18:24
(2015-11-22, 00:30)Rantanplan-1 Wrote: [ -> ]Feature Request:
Did send you a PM
no luck on my side.
Regards.
2015-11-27, 15:11
Hi Phil,
Just noticed opening "script-ExtendedInfo Script-DialogVideoInfo.xml" and "script-ExtendedInfo Script-DialogInfo.xml" closes "script-ExtendedInfo Script-VideoList.xml" and all other active dialogs (like "DialogVideoInfo.xml"). Since they are identified as dialogs in their title, just asking if this is normal behavior ? It breaks somehow my dialog management system (dialogs stacking, it clears the stack) since it doesn't follow the dialog rules. I also tried adding type="dialog" but no luck ... it seems to be hard coded. Any chance to get them work like dialogs, at least with using the type="dialog" in window structure, so it won't break other skins code ?
Thanks in advance.
Thanks in advance.
2015-11-27, 18:34
Is it possible to open a TVshows information window? In addition to the movies / actors / directors.
2015-11-28, 01:36
(2015-11-27, 18:34)finalmakerr Wrote: [ -> ]Is it possible to open a TVshows information window? In addition to the movies / actors / directors.
RunScript(script.extendedinfo,info=extendedtvinfo,name=$INFO[ListItem.TvShowTitle])
2015-11-30, 22:20
(2015-06-07, 20:40)phil65 Wrote: [ -> ]Google AutoCompletion possible for DialogKeyBoard.xml now, too
(Isengard-only)Code:plugin://script.extendedinfo?info=autocomplete&&id=$INFO[Control.GetLabel(312).index(1)]
Hi
Can someone please hep me integrate this with Transparency skin?
Im trying to do it myself with no luck :\
