Full Version: alarab.net arabic VOD plugin
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18
Hi
Please enjoy the new alarab.net video plugin for this site: http://tv1.alarab.net/.
The plugin is now apart of the arabic video repository and will be updated soon since the development of film part is still ongoing.
I hope you will like it.
Regards
Bisha
Message from elsaadi - 7 July 2017
Lads,
Link to my repo: Download Here
Version number is fixed, that way kodi won't revert to any older versions of addons.
Up directory is fixed as well.
If you guys run into any errors, please let me know.
ASA
Thank you bisha, I just test it the plugin on Raspberry, it play only audio, I m not sure alarab are using what codecs, and I already own the mpeg 2 and vc1 codec
Bisha thanks a lot, another great addon from you .
(2013-03-27, 01:46)bisha Wrote: [ -> ]Hi
Regards
Bisha
Thank you very much . you are the best of the best
thank you very much i was waiting for this.
hi, I don't know why but there is no arabic titles only pictures. please help
yh the same i cant see nothing
(2013-03-27, 20:16)diden Wrote: [ -> ]yh the same i cant see nothing
Please navigate to System- Appearance - skin and change font to Arial based ,then you should see Arabic characters
(2013-03-27, 02:15)Ikyo Wrote: [ -> ]Thank you bisha, I just test it the plugin on Raspberry, it play only audio, I m not sure alarab are using what codecs, and I already own the mpeg 2 and vc1 codec
Yes , I have the same issue in my Raspberry Pi , Windows ,Android and Ipad are fine.
thank you bisha but where is the movies is only mosalslat
you are mine hero bisha and please i wel a addon for zeedrama.com they have a good video qualiteit.
can you add this plugin in one zip file please ?
i dont want to install all arabic video repository.
(2013-03-28, 00:30)watheq Wrote: [ -> ]can you add this plugin in one zip file please ?
https://github.com/hadynz/repository.ara...p?raw=true
(2013-03-28, 01:23)bisha Wrote: [ -> ]
thanks
Hi
There is an upgrade for this addon now. Movie parts are in Place . You can upgrade it through arabic repo , No separate zip files will be provided!
thanks good one
