Full Version: Map Display Mode change to MCE Remote Button?
Is it possible to map a button on a MCE Remote to switch the display mode?
My displays are in different rooms, so currently I have to go to my PC,
switch the display setting, then use my smartphone to acknowledge the switch to the home theater,
before it times out and switches back.
The BGB will launch XBMC ok, but always to the last used display.
It would be nice to have a button on the MCE remote to initiate the change then just OK to confirm the switch.
What os are you using?
I'm using Windows 7-64
Have a look at Eventghost.
Gotcha.
Create a Macro of keyboard actions from the main screen to the Change Display function, assign it to a keyboard combo (say CTRL-ALT C) and assign that to a button on the remote.
Thanks for pointing me in the right direction.
