Full Version: Raspberry Pi Xbian - LiveTV only works for seconds
Hello folks,
since last week I've tried and made settings change and step by step to get further. The above mentioned issue is annoying but, because actually that's his purpose: I want to stream LiveTV of the dream in the dining room. I had purchased the MPEG2 - license - key and I thought it would have to work now. Unfortunately each stream is ends after a few seconds, the pictures is freezing and then I have to wait about a minute until it goes further. it is no matter whether HD or SD. Sound goes via RCA Jack to an amplifier, image via a HDMI-VGA adapter on a LCD, SD-Card is a Class10, power supply has 1200mA and a Powerlan serves as network. What am I doing wrong?
Here is my logfile: http://xbmclogs.com/show.php?id=7197
I've now increase the Powerline datarate, because the eco mode was active and he was accordingly slow. SD material running well, yet still breaks out. HD runs continue briefly, but then again breaks off after a few seconds. Nobody any idea?
I have the same setup - After small advancedsettings.xml tweak, VU+ plugin as LiveTV enabler works like a charm..
although you had already
<pvr>
  <minvideocachelevel>60</minvideocachelevel>
  <minaudiocachelevel>60</minaudiocachelevel>
</pvr>
http://forum.xbmc.org/showthread.php?tid=159142
