Full Version: Error queuing folders
Hi all,
I have a problem with trying to queue [music] folders. With every folder I try to queue, it gives an error 'Error Queuing x' (where x is the folder location).
If I queue a single folder with only songs in it, it will give that error message but it will still queue. However if I try to queue another folder of songs behind it, I get the error message again, and [most of the time] the 2nd folder won't be added to the queue. (It will also start playing the first folder from the beginning).
If I try to queue a folder with subfolders inside it (eg an Artist with 2 or more Albums) - then I get the error message and nothing will go to the queue, regardless of if there is anything already in the queue or not.
If I queue songs individually, I get the error message for every song I add, (they do add to the queue though), but if I go and view the queue list, the 'Play' icon seems to stay stuck on the first song (even if one of the other songs are playing).
I'm on XBMC Remote V1.0.9, XBMC Frodo 12.1 (I was having this problem on Eden 11 so I updated to 12.1 but still no joy).
Does anyone know why this is happening and how to fix it?
any help is much appreciated
cheers
still no updates on this?
Just to say, I met exactly the same issue with XBMC Remonte, intalled on my Android Phone (Samsung GII).
But I found no trace in the logs on the server, even in debug mode.
I'm unable to understand why ? (may be, rights access, folder and file too long, too many sub-folder, too many files ? ...)
I also didn't find any solution to solve this problem.
However, I can add in my post, that problem didn't appear in the first times, when I began to use the Eden version.
It has happened few month later, after some hours of use.
When the problem started, I try to reinstall both XBMC remonte and server, but nothing better, nada !
Any help would be very much appreciated Smile
Thanks at all
