2013-03-28, 00:06
Where are the .xml files that would allow me to do the following...
1. Add directory paths to given menu items to let the library scan. I think it was called <addpath>.
2. Add/Delete home items.
The below is hypothetical consisting of only 1 main menu entry, with 2 sub entries, but it is what I'm looking for.
Once upon a time, it was this simple...
Last time I used XBMC was ~2005, I remember configuring XBMC this way and prefer this type of method. I've read about "Smart Playlists" and "Party Mode", not wanted or needed. A lot of posts on here assume you will be using XBMC to configure XBMC even on a remote machine, that will not be the case for me.
<home>
<entry="Movies">
<entry="Kids">
<addpath>"~/__Movies/Cartoons"</addpath>
<addpath>"~/__Movies/PBS"</addpath>
</entry>
<entry="OldPeople">
<addpath>"~/__Movies/BlackAndWhite"</addpath>
<addpath>"~/__Movies/Silent"</addpath>
<addpath>"~/__Movies/Color"</addpath>
</entry>
</entry>
<home>
