Full Version: Daily Frodo 12.1 crahes. Log included.
Seems to be rather random. Video play ing fine, then video stops, audio gets wonky, then XBMC freezes.
My XBMC.log writes nothing while video is happily playing, then this occurs before crash:
Quote:20:23:31 T:3596 DEBUG: CPullupCorrection: pattern lost on diff -688554533.333333
20:23:31 T:3596 DEBUG: CVideoReferenceClock: Clock speed 0.000000%
20:23:31 T:3736 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.IOError'>
Error Contents: (2, 'No such file or directory')
File "C:\Users\Media Whore\AppData\Roaming\XBMC\addons\script.common.plugin.cache\default.py", line 40, in <module>
run()
File "C:\Users\Media Whore\AppData\Roaming\XBMC\addons\script.common.plugin.cache\default.py", line 35, in run
s.run()
File "C:\Users\Media Whore\AppData\Roaming\XBMC\addons\script.common.plugin.cache/lib\StorageServer.py", line 215, in run
if idle_since + self.idle < time.time():
IOError: (2, 'No such file or directory')
20:23:35 T:3812 DEBUG: CDVDPlayerAudio:: Discontinuity2 - was:688362823.018943, should be:688362823.018943, error:0.000000
20:23:38 T:3812 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
20:23:39 T:3532 DEBUG: CSoftAEStream::GetFrame - Underrun
20:23:39 T:3812 DEBUG: CSoftAEStream::Flush
So I guess it's related to a Python script, but does;'t show whic one? I are confused. I/O error.. maybe my HDD is dying? Will run Chkdsk later tonight.
Specs:
q9550 3.4ghz
HD 6670 1gb with v13.2 drivers
4gb ddr2
Win 7 x64
Frodo 12.1
That's just a snippet rather than the complete log. Please upload the entire log to www.xbmlogs.com and post the assigned URL here.
You may want to uninstall and then reinstall the Common plugin cache add-on and see if the makes a difference.
