2013-03-29, 14:48
I am getting this error when trying to post a reply, not a long post(not more than anyone else's). I tried deleting the subject in the post but I stilll get the error and the subject text is restored. ??
(2013-03-29, 15:22)da-anda Wrote: [ -> ]Which thread was it so that I can fix the thread subject?
(2013-03-29, 15:22)da-anda Wrote: [ -> ]The subject limit is unfortunately hardcoded in myBB, and if you delete the subject line in your post, myBB will inject the threads subject automatically and that one will be validated then. So the only way to fix it is to rename the opening post (or mess with the myBB code which we try to avoid) or use a shorter custom title in your post (wile doing a full reply). This should only happen on threads created with the old forum.http://forum.xbmc.org/showthread.php?tid=42458
(2013-03-29, 16:04)spyder Wrote: [ -> ](2013-03-29, 15:22)da-anda Wrote: [ -> ]The subject limit is unfortunately hardcoded in myBB, and if you delete the subject line in your post, myBB will inject the threads subject automatically and that one will be validated then. So the only way to fix it is to rename the opening post (or mess with the myBB code which we try to avoid) or use a shorter custom title in your post (wile doing a full reply). This should only happen on threads created with the old forum.http://forum.xbmc.org/showthread.php?tid=42458
I will try a 'full reply', and see if that works.
EDIT: Tried POST REPLY, instead of QUICK REPLY, didn't work. I then tried quoting someone, then deleting their quote and that somehow worked.
