2013-03-29, 18:37
I am getting a lot of Blank screens since switching to 12.1.
It happens when switching from display #1 to (PC) to Display #2 (TV)., when launching a YouTube trailer while watching Display #2, and everytime when
relaunching on PC after shutting XBMC down from Display #2, and Display #2 is off.
I have logs, some in debug mode, but this " Checking resolution 146" NOTICE is always the last log entry in the latter scenario.
So it is good starting point for me to figure this out.
I can get it to launch on the PC if I disable display#2 in the ATI CCC app.
What is "resolution 146" ?
Other logs that get past that point will say Checking resolution 15, or, Checking resolution 16., but "12:05:06 T:3500 NOTICE: Additional mode: 1920x1080 @ 29.97i - Full Screen #2", is always the last Additional Mode list.
The next line should be NOTICE: Running database version Addons15
12:05:06 T:3500 NOTICE: Additional mode: 1920x1080 @ 25.00i - Full Screen #2
12:05:06 T:3500 NOTICE: Additional mode: 1920x1080 @ 30.00i - Full Screen #2
12:05:06 T:3500 NOTICE: Checking resolution 146
This is an example of what happens when I tried to switch from display#1 to display#2.
I turned on debug, switched the display and it blanked out. My next step is using the web interface to confirm the display change,
as my displays are in seperate rooms, but both are blanked.
1:24:58 T:5576 NOTICE: Thread Jobworker start, auto delete: true
22:27:40 T:2168 NOTICE: Previous line repeats 4 times.
22:27:40 T:2168 NOTICE: Thread XBPyThread start, auto delete: false
22:27:40 T:2168 NOTICE: -->Python Interpreter Initialized<--
22:27:41 T:4960 NOTICE: Thread Jobworker start, auto delete: true
22:27:52 T:4548 NOTICE: Previous line repeats 1 times.
22:27:52 T:4548 NOTICE: Log level changed to 2
22:27:52 T:4548 NOTICE: Enabled debug logging due to GUI setting. Level 2.
22:27:52 T:4548 DEBUG: ------ Window Init () ------
22:27:56 T:4548 DEBUG: CApplication::ProcessMouse: trying mouse action leftclick
22:27:56 T:4548 DEBUG: CApplication::ExecuteXBMCAction : Translating SetFocus(800)
22:27:56 T:4548 DEBUG: CApplication::ExecuteXBMCAction : To SetFocus(800)
22:28:03 T:4548 DEBUG: ------ Window Deinit (Pointer.xml) ------
22:28:13 T:4548 INFO: XCURL::DllLibCurlGlobal::CheckIdle - Closing session to http://www.google.com (easy=037B8F50, multi=00000000)
22:28:15 T:5116 DEBUG: Thread Jobworker 5116 terminating (autodelete)
22:28:15 T:2028 DEBUG: Thread Jobworker 2028 terminating (autodelete)
22:28:15 T:4960 DEBUG: Thread Jobworker 4960 terminating (autodelete)
22:28:22 T:4648 DEBUG: webserver: request received for /
22:28:23 T:3280 DEBUG: webserver: request received for /jsonrpc?Playlist.GetPlaylists
22:28:23 T:3280 DEBUG: JSONRPC: Incoming request: {"jsonrpc":"2.0","method":"Playlist.GetPlaylists","id":1}
22:28:23 T:3280 DEBUG: JSONRPC: Calling playlist.getplaylists
22:28:24 T:3280 DEBUG: webserver: request received for /favicon.ico
22:28:24 T:4648 DEBUG: webserver: request received for /jsonrpc?Player.GetActivePlayers
22:28:24 T:4648 DEBUG: JSONRPC: Incoming request: {"jsonrpc":"2.0","method":"Player.GetActivePlayers","id":1}
