Full Version: 12.1 AudioEngine DTS to AC3 transcode not working
Hi all,
I noticed earlier today that XBMC 12.1 will not properly transcode DTS to AC3 5.1 for playback on my old Denon AVR-2700 receiver. I get stereo instead and no DD sync light on the receiver.
I rolled back to 12.0 and same problem. I rolled back to 11.0 and DTS to AC3 transcoding worked again.
I have triple-checked the settings. The only radio button selected on the audio settings screen in XBMC is "AC3 Capable Receiver". "HDMI" output is enabled as was confusingly recommended in the wiki here.
My mac mini is older and doesn't have HDMI output, I use a DVI to HDMI adapter for video, and optical out straight to the Denon.
I took a look at the debug logs and it says that XBMC opened a 6 channel, non passthrough audio stream, but my receiver only plays back stereo.
I suspect it's my very old receiver being finicky about the AC3 signal generated by AudioEngine as opposed to the AC3 signal generated by the old XBMC transcode process in 11.0. Any help would be greatly appreciated. I don't want to be stuck on 11.0 forever.
Log excerpt from DTS playback test:
22:27:52 T:2685711680   DEBUG: Keyboard: scancode: 24, sym: 000d, unicode: 000d, modifier: 0
22:27:52 T:2685711680   DEBUG: OnKey: return (f00d) pressed, action is Select
22:27:52 T:2685711680   DEBUG: OnPlayMedia smb://r:[email protected]/Video/Movies/Action/DTS Test Video 720p BluRay x264.mkv
22:27:52 T:2685711680   DEBUG: CAnnouncementManager - Announcement: OnClear from xbmc
22:27:52 T:2685711680   DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnClear
22:27:52 T:2685711680   DEBUG: CAnnouncementManager - Announcement: OnAdd from xbmc
22:27:52 T:2685711680   DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnAdd
22:27:52 T:2685711680   DEBUG: CPlayerCoreFactory::GetPlayers(smb://r:[email protected]/Video/Movies/Action/DTS Test Video 720p BluRay x264.mkv)
22:27:52 T:2685711680   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
22:27:52 T:2685711680   DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
22:27:52 T:2685711680   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtv
22:27:52 T:2685711680   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: hdhomerun/myth/mms/udp
22:27:52 T:2685711680   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
22:27:52 T:2685711680   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtmp
22:27:52 T:2685711680   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
22:27:52 T:2685711680   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
22:27:52 T:2685711680   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
22:27:52 T:2685711680   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
22:27:52 T:2685711680   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
22:27:52 T:2685711680   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
22:27:52 T:2685711680   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio
22:27:52 T:2685711680   DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
22:27:52 T:2685711680   DEBUG: CPlayerCoreFactory::GetPlayers: adding videodefaultplayer (1)
22:27:52 T:2685711680   DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=0
22:27:52 T:2685711680   DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
22:27:52 T:2685711680   DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
22:27:52 T:2685711680   DEBUG: CPlayerCoreFactory::GetPlayers: added 1 players
22:27:52 T:2685711680  NOTICE: DVDPlayer: Opening: smb://r:[email protected]/Video/Movies/Action/DTS Test Video 720p BluRay x264.mkv
22:27:52 T:2685711680 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
22:27:52 T:2685711680   DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
22:27:52 T:2685711680   DEBUG: LinuxRendererGL: Cleaning up GL resources
22:27:52 T:2685711680   DEBUG: CLinuxRendererGL::PreInit - precision of luminance 16 is 16
22:27:52 T:2957688832  NOTICE: Thread CDVDPlayer start, auto delete: false
22:27:52 T:2957688832  NOTICE: Creating InputStream
22:27:52 T:2957688832   DEBUG: CSmbFile::Open - opened Video/Movies/Action/DTS Test Video 720p BluRay x264.mkv, fd=10000
22:27:52 T:2957688832   DEBUG: ScanForExternalSubtitles: Searching for subtitles...
22:27:52 T:2957688832   DEBUG: OpenDir - Using authentication url smb://r:[email protected]/Video/Movies/Action
22:27:52 T:2685711680   DEBUG: ------ Window Init (DialogBusy.xml) ------
22:27:52 T:2957688832    INFO: ScanForExternalSubtitles: found subtitle file smb://r:[email protected]/Video/Movies/Action/DTS Test Video 720p BluRay x264.srt
22:27:52 T:2957688832   DEBUG: ScanForExternalSubtitles: END (total time: 199 ms)
22:27:52 T:2957688832  NOTICE: Creating Demuxer
22:27:52 T:2957688832   DEBUG: Open - probing detected format [matroska,webm]
22:27:52 T:2957688832   DEBUG: Open - avformat_find_stream_info starting
22:27:52 T:2957688832   DEBUG: Open - av_find_stream_info finished
22:27:52 T:2957688832    INFO: ffmpeg[B04AC000]: Input #0, matroska,webm, from 'smb://r:[email protected]/Video/Movies/Action/DTS Test Video 720p BluRay x264.mkv':
22:27:52 T:2957688832    INFO: ffmpeg[B04AC000]:   Duration: 02:37:49.46, start: 0.000000, bitrate: 5949 kb/s
22:27:52 T:2957688832    INFO: ffmpeg[B04AC000]:     Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x536, SAR 1:1 DAR 160:67, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
22:27:52 T:2957688832    INFO: ffmpeg[B04AC000]:     Stream #0:1: Audio: dts (DTS), 48000 Hz, 5.1(side), s16, 1536 kb/s (default)
22:27:52 T:2957688832    INFO: ffmpeg[B04AC000]:     Stream #0:2(eng): Subtitle: text (default)
22:27:52 T:2957688832  NOTICE: Opening video stream: 0 source: 256
22:27:52 T:2957688832  NOTICE: Creating video codec with codec id: 28
22:27:52 T:2957688832   DEBUG: CDVDFactoryCodec: compiled in hardware support: VDADecoder:yes VideoToolBoxDecoder:no CrystalHD:yes OpenMax:no
22:27:52 T:2957688832   DEBUG: FactoryCodec - Video: vda- - Opening
22:27:52 T:2957688832  NOTICE: Open - VDADecoder Codec failed to open, status(-12470), profile(100), level(41)
22:27:52 T:2957688832   DEBUG: FactoryCodec - Video: vda-h264 - Failed
22:27:52 T:2957688832   DEBUG: FactoryCodec - Video:  - Opening
22:27:52 T:2957688832  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
22:27:52 T:2957688832   DEBUG: FactoryCodec - Video: ff-h264 - Opened
22:27:52 T:2957688832  NOTICE: Creating video thread
22:27:52 T:2959818752  NOTICE: Thread CDVDPlayerVideo start, auto delete: false
22:27:52 T:2959818752  NOTICE: running thread: video_thread
22:27:52 T:2957688832  NOTICE: Opening audio stream: 1 source: 256
22:27:52 T:2957688832  NOTICE: Finding audio codec for: 86020
22:27:52 T:2959818752   DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_SYNCHRONIZE
22:27:52 T:2957688832   DEBUG: FactoryCodec - Audio: PassthroughFFmpeg - Opening
22:27:52 T:2957688832   DEBUG: Error: Requested setting (audiooutput.passthroughaac) was not found.  It must be case-sensitive
22:27:52 T:2957688832   ERROR: CDVDAudioCodecPassthroughFFmpeg::Open - FFmpeg SPDIF muxer does not support this codec
22:27:52 T:2957688832   DEBUG: FactoryCodec - Audio: PassthroughFFmpeg - Failed
22:27:52 T:2957688832   DEBUG: FactoryCodec - Audio: passthrough - Opening
22:27:52 T:2957688832   DEBUG: Error: Requested setting (audiooutput.truehdpassthrough) was not found.  It must be case-sensitive
22:27:52 T:2957688832   DEBUG: Error: Requested setting (audiooutput.dtshdpassthrough) was not found.  It must be case-sensitive
22:27:52 T:2957688832   DEBUG: FactoryCodec - Audio: passthrough - Failed
22:27:52 T:2957688832   DEBUG: FactoryCodec - Audio: FFmpeg - Opening
22:27:52 T:2957688832   DEBUG: FactoryCodec - Audio: FFmpeg - Opened
22:27:52 T:2957688832  NOTICE: Creating audio thread
22:27:52 T:2967326720  NOTICE: Thread CDVDPlayerAudio start, auto delete: false
22:27:52 T:2967326720  NOTICE: running thread: CDVDPlayerAudio::Process()
22:27:52 T:2957688832  NOTICE: Opening Subtitle stream: 0 source: 1024
22:27:52 T:2957688832   DEBUG: CSmbFile::Open - opened Video/Movies/Action/DTS Test Video 720p BluRay x264.srt, fd=10001
22:27:52 T:2957688832   DEBUG: CSmbFile::Close closing fd 10001
22:27:52 T:2957688832   DEBUG: ReadEditDecisionLists - Checking for edit decision lists (EDL) on local drive or remote share for: smb://r:[email protected]/Video/Movies/Action/DTS Test Video 720p BluRay x264.mkv
22:27:52 T:2957688832   DEBUG: CDVDPlayer::SetCaching - caching state 3
22:27:52 T:2959818752    INFO: CDVDPlayerVideo - Stillframe left, switching to normal playback
22:27:52 T:2967326720  NOTICE: Creating audio stream (codec id: 86020, channels: 6, sample rate: 48000, no pass-through)
22:27:52 T:2967326720    INFO: CCoreAudioAE::MakeStream - AE_FMT_S16NE, 48000, 48000, FL,FR,FC,LFE,SL,SR
22:27:52 T:2967326720   DEBUG: AERemap: Downmix normalization is enabled
22:27:52 T:2967326720   DEBUG: CCoreAudioAEStream::CCoreAudioAEStream - Converting from AE_FMT_S16NE to AE_FMT_FLOAT
22:27:52 T:2959818752   DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_RESYNC(42000.000000, 0)
22:27:52 T:2967326720   DEBUG: CCoreAudioGraph::Open: Mixer Output Format: 6 channels, 48.0 kHz, 32 bits, 4 bytes per frame
22:27:52 T:2959818752    INFO: ffmpeg[B06B4000]: [h264] Cannot parallelize deblocking type 1, decoding such frames in sequential order
22:27:52 T:2685711680   DEBUG: CGUIInfoManager::SetCurrentMovie(smb://r:[email protected]/Video/Movies/Action/DTS Test Video 720p BluRay x264.mkv)
22:27:52 T:2959818752  NOTICE:  fps: 23.976024, pwidth: 1280, pheight: 536, dwidth: 1280, dheight: 536
22:27:52 T:2959818752   DEBUG: OutputPicture - change configuration. 1280x536. framerate: 23.98. format: YV12
22:27:52 T:2685711680   DEBUG: GetMovieId (smb://r:[email protected]/Video/Movies/Action/DTS Test Video 720p BluRay x264.mkv), query = select idMovie from movie where idFile=6494
22:27:52 T:2685711680   DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
22:27:52 T:2685711680   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
22:27:52 T:2685711680   DEBUG: Building didl for object 'smb://r:[email protected]/Video/Movies/Action/DTS Test Video 720p BluRay x264.mkv'
22:27:52 T:2957688832   DEBUG: CDVDPlayer::HandleMessages - player started 1
22:27:52 T:2959818752 WARNING: CRenderManager::Configure - timeout waiting for previous frame
22:27:52 T:2959818752  NOTICE: Display resolution DESKTOP : 1920x1080 @ 60.00 - Full Screen (16)
22:27:52 T:2685711680   DEBUG: Activating window ID: 12005
22:27:52 T:2685711680   DEBUG: ------ Window Deinit (MyVideoNav.xml) ------
22:27:52 T:2685711680   DEBUG: ------ Window Init (VideoFullScreen.xml) ------
22:27:52 T:2957688832   DEBUG: CDVDPlayer::SetCaching - caching state 0
22:27:52 T:2967326720   DEBUG: CDVDPlayerAudio - CDVDMsg::GENERAL_RESYNC(10000.000000, 1)
22:27:52 T:2967326720   DEBUG: CDVDPlayerAudio:: Discontinuity1 - was:-6990.165667, should be:-6988.869667, error:1.296000
22:27:52 T:2685711680  NOTICE: Using GL_TEXTURE_2D
22:27:52 T:2685711680   DEBUG: GL: Requested render method: 0
22:27:52 T:2685711680  NOTICE: GL: ARB shaders support detected
22:27:52 T:2685711680   DEBUG: GL: YUV2RGBProgressiveShaderARB: loading yuv2rgb_basic_2d.arb
22:27:52 T:2685711680  NOTICE: GL: Selecting Single Pass ARB YUV2RGB shader
22:27:52 T:2685711680  NOTICE: GL: No vertex shader, fixed pipeline in use
22:27:52 T:2685711680  NOTICE: GL: NPOT texture support detected
22:27:52 T:2685711680  NOTICE: GL: Using GL_ARB_pixel_buffer_object
22:27:52 T:2685711680   DEBUG: CCoreAudioAE::GarbageCollect - Acquire CA HAL.
22:27:52 T:2967326720   DEBUG: CDVDPlayerAudio:: synctype set to 0: clock feedback
22:27:52 T:2685711680   DEBUG: ------ Window Deinit (DialogBusy.xml) ------
22:27:52 T:2957688832   DEBUG: CDVDPlayer::HandleMessages - player started 2
22:27:52 T:2967326720   DEBUG: CDVDPlayerAudio:: Discontinuity1 - was:103707.414333, should be:241031.907333, error:137324.493000
22:27:57 T:2959818752   DEBUG: CPullupCorrection: detected pattern of length 1: 41708.33, frameduration: 41708.333333
22:27:58 T:2685711680   DEBUG: Keyboard: scancode: 07, sym: 0078, unicode: 0078, modifier: 0
22:27:58 T:2685711680   DEBUG: OnKey: x (f058) pressed, action is Stop
22:27:58 T:2685711680  NOTICE: CDVDPlayer::CloseFile()
22:27:58 T:2685711680  NOTICE: DVDPlayer: waiting for threads to exit
22:27:58 T:2957688832  NOTICE: CDVDPlayer::OnExit()
22:27:58 T:2957688832  NOTICE: DVDPlayer: closing audio stream
22:27:58 T:2957688832  NOTICE: Closing audio stream
22:27:58 T:2957688832  NOTICE: Waiting for audio thread to exit
22:27:58 T:2967326720  NOTICE: thread end: CDVDPlayerAudio::OnExit()
22:27:58 T:2967326720   DEBUG: Thread CDVDPlayerAudio 2967326720 terminating
22:27:58 T:2957688832  NOTICE: Closing audio device
22:27:58 T:2957688832   DEBUG: CCoreAudioAEStream::~CCoreAudioAEStream - Destructed
22:27:58 T:2957688832  NOTICE: Deleting audio codec
22:27:58 T:2957688832  NOTICE: DVDPlayer: closing video stream
22:27:58 T:2957688832  NOTICE: Closing video stream
22:27:58 T:2957688832  NOTICE: waiting for video thread to exit
22:27:58 T:2959818752  NOTICE: thread end: video_thread
22:27:58 T:2959818752   DEBUG: Thread CDVDPlayerVideo 2959818752 terminating
22:27:58 T:2957688832  NOTICE: deleting video codec
22:27:58 T:2957688832  NOTICE: DVDPlayer: closing subtitle stream
22:27:58 T:2957688832  NOTICE: Closing subtitle stream
22:27:58 T:2957688832  NOTICE: CDVDPlayer::OnExit() deleting demuxer
22:27:58 T:2957688832  NOTICE: CDVDPlayer::OnExit() deleting input stream
22:27:58 T:2957688832   DEBUG: CSmbFile::Close closing fd 10000
22:27:58 T:2957688832   DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc
22:27:58 T:2957688832   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop
22:27:58 T:2957688832   DEBUG: Thread CDVDPlayer 2957688832 terminating
22:27:58 T:2685711680  NOTICE: DVDPlayer: finished waiting
22:27:58 T:2685711680   DEBUG: LinuxRendererGL: Cleaning up GL resources
22:27:58 T:2685711680   DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
22:27:58 T:2685711680   DEBUG: ------ Window Deinit (VideoFullScreen.xml) ------
22:27:58 T:2685711680   DEBUG: CGUIWindowManager::PreviousWindow: Activate new
22:27:58 T:2685711680   DEBUG: ------ Window Init (MyVideoNav.xml) ------
22:27:58 T:2685711680   DEBUG: CGUIMediaWindow::GetDirectory (smb://r:[email protected]/Video/Movies/Action/)
22:27:58 T:2685711680   DEBUG:   ParentPath = [smb://r:[email protected]/Video/Movies/Action/]
22:27:58 T:2685711680   DEBUG: OpenDir - Using authentication url smb://r:[email protected]/Video/Movies/Action
22:27:58 T:2685711680   DEBUG: RunQuery took 13 ms for 97 items query: select * from movieview  WHERE c23=1389
22:27:58 T:2685711680   DEBUG: RunQuery took 1 ms for 97 items query: SELECT  files.strFilename, files.playCount,  bookmark.timeInSeconds, bookmark.totalTimeInSeconds FROM files  LEFT JOIN bookmark ON    files.idFile = bookmark.idFile AND bookmark.type = 1  WHERE files.idPath=1389
22:27:58 T:2957688832  NOTICE: Thread Background Loader start, auto delete: false
22:27:58 T:2957156352   DEBUG: DoWork - trying to extract filestream details from video file smb://r:[email protected]/Video/Movies/Action/Gladiator.1080p.eng.DTS.2.DVD9.disk.2 (2000).TM.mkv
22:27:58 T:2957688832   DEBUG: Thread Background Loader 2957688832 terminating
22:27:58 T:2956017664   DEBUG: OpenDir - Using authentication url smb://192.168.0.5/Video/Movies/Action/extrafanart
22:27:58 T:2956017664   ERROR: SMBDirectory->GetDirectory: Unable to open directory : 'smb://192.168.0.5/Video/Movies/Action/extrafanart'
                                            unix_err:'d' error : 'Permission denied'
22:27:58 T:2956017664   ERROR: GetDirectory - Error getting smb://192.168.0.5/Video/Movies/Action/extrafanart/
22:27:58 T:2953850880   DEBUG: OpenDir - Using authentication url smb://192.168.0.5/Video/Movies/Action/extrafanart
22:27:58 T:2953850880   ERROR: SMBDirectory->GetDirectory: Unable to open directory : 'smb://192.168.0.5/Video/Movies/Action/extrafanart'
22:27:58 T:2953850880   ERROR: GetDirectory - Error getting smb://192.168.0.5/Video/Movies/Action/extrafanart/
22:27:58 T:2957156352   DEBUG: OpenDir - Using authentication url smb://192.168.0.5/Video/Movies/Action/extrathumbs
22:27:58 T:2957156352   ERROR: SMBDirectory->GetDirectory: Unable to open directory : 'smb://192.168.0.5/Video/Movies/Action/extrathumbs'
22:27:58 T:2957156352   ERROR: GetDirectory - Error getting smb://192.168.0.5/Video/Movies/Action/extrathumbs/
22:27:58 T:2685711680 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
[/code]
My apologies, just found this thread http://forum.xbmc.org/showthread.php?tid=153039
Looks like it hasn't been coded yet. Lame, v11 for me.
