Even that didn't help, my xorg.conf looks like this now:
ection "Device"
Identifier "Device0"
Driver "intel"
VendorName "INTEL Corporation"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "HDMI2"
DefaultDepth 24
SubSection "Display"
Depth 24
Modes "1920x1080@50p" "[email protected]" "1920x1080@24p" "1920x1080@60p"
EndSubSection
EndSection
#Section "Monitor"
# Identifier "HDMI2"
# HorizSync 14.0 - 70.0
# VertRefresh 24.0 - 62.0
# Option "DPMS" "true"
# Modeline "1920x1080@24p" 74.230 1920 2560 2604 2752 1080 1084 1089 1125 +hsync +vsync
# Modeline "1920x1080@50p" 148.500 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync
# Modeline "[email protected]" 148.352 1920 1960 2016 2200 1080 1082 1088 1125 +hsync +vsync
# Modeline "1920x1080@60p" 148.500 1920 2008 2056 2200 1080 1084 1089 1125 +hsync +vsync
#EndSection
Section "ServerFlags"
Option "blank time" "0"
Option "standby time" "0"
Option "suspend time" "0"
Option "off time" "0"
Option "dpms" "false"
EndSection
Section "Extensions"
# fixes tearing
Option "Composite" "Disable"
EndSection
But the system keeps spawning another Xorg on another tty, after I while i notice that it will automatically stop and goes back to the tty where xbmc lives and resumes video playback.
But then again after a while it spawns another Xorg switching etc. etc.
It loops like that.
Another thing which I noticed was the logs of both Xorg's, In the first one i see normal behaviour except for the VT switch. In the second one however I notice that it tells stuff about devices:
Instance 0 of Xorg:
[351049.600]
X.Org X Server 1.13.0
Release Date: 2012-09-05
[351049.600] X Protocol Version 11, Revision 0
[351049.600] Build Operating System: Linux 3.2.0-32-generic x86_64 Ubuntu
[351049.600] Current Operating System: Linux media 3.5.0-26-generic #42-Ubuntu SMP Fri Mar 8 23:18:20 UTC 2013 x86_64
[351049.600] Kernel command line: BOOT_IMAGE=/vmlinuz-3.5.0-26-generic root=/dev/mapper/media-root ro
[351049.600] Build Date: 27 November 2012 07:44:35AM
[351049.600] xorg-server 2:1.13.0-0ubuntu6.1 (For technical support please see http://www.ubuntu.com/support)
[351049.600] Current version of pixman: 0.26.0
[351049.600] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[351049.600] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[351049.600] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Apr 4 21:53:45 2013
[351049.600] (==) Using config file: "/etc/X11/xorg.conf"
[351049.600] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[351049.601] (==) No Layout section. Using the first Screen section.
[351049.601] (**) |-->Screen "Screen0" (0)
[351049.601] (**) | |-->Monitor "<default monitor>"
[351049.601] (**) | |-->Device "Device0"
[351049.601] (==) No monitor specified for screen "Screen0".
Using a default monitor configuration.
[351049.601] (**) Option "BlankTime" "0"
[351049.601] (**) Option "StandbyTime" "0"
[351049.601] (**) Option "SuspendTime" "0"
[351049.601] (**) Option "OffTime" "0"
[351049.601] (==) Automatically adding devices
[351049.601] (==) Automatically enabling devices
[351049.601] (==) Automatically adding GPU devices
[351049.601] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[351049.601] Entry deleted from font path.
[351049.601] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[351049.601] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[351049.601] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[351049.601] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[351049.601] (WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
[351049.601] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[351049.601] (==) ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[351049.601] (**) Extension "Composite" is disabled
[351049.601] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[351049.601] (II) Loader magic: 0x7ff29dcb0c40
[351049.601] (II) Module ABI versions:
[351049.601] X.Org ANSI C Emulation: 0.4
[351049.601] X.Org Video Driver: 13.0
[351049.601] X.Org XInput driver : 18.0
[351049.601] X.Org Server Extension : 7.0
[351049.602] (II) config/udev: Adding drm device (/dev/dri/card0)
[351049.604] (--) PCI:*(0:0:2:0) 8086:0042:1458:d000 rev 24, Mem @ 0xfb800000/4194304, 0xe0000000/268435456, I/O @ 0x0000ff00/8
[351049.604] (II) Open ACPI successful (/var/run/acpid.socket)
[351049.604] Initializing built-in extension Generic Event Extension
[351049.604] Initializing built-in extension SHAPE
[351049.604] Initializing built-in extension MIT-SHM
[351049.604] Initializing built-in extension XInputExtension
[351049.604] Initializing built-in extension XTEST
[351049.604] Initializing built-in extension BIG-REQUESTS
[351049.604] Initializing built-in extension SYNC
[351049.604] Initializing built-in extension XKEYBOARD
[351049.604] Initializing built-in extension XC-MISC
[351049.604] Initializing built-in extension SECURITY
[351049.604] Initializing built-in extension XINERAMA
[351049.604] Initializing built-in extension XFIXES
[351049.604] Initializing built-in extension RENDER
[351049.604] Initializing built-in extension RANDR
[351049.604] Initializing built-in extension COMPOSITE
[351049.604] Initializing built-in extension DAMAGE
[351049.604] Initializing built-in extension MIT-SCREEN-SAVER
[351049.604] Initializing built-in extension DOUBLE-BUFFER
[351049.604] Initializing built-in extension RECORD
[351049.604] Initializing built-in extension DPMS
[351049.604] Initializing built-in extension X-Resource
[351049.604] Initializing built-in extension XVideo
[351049.604] Initializing built-in extension XVideo-MotionCompensation
[351049.604] Initializing built-in extension XFree86-VidModeExtension
[351049.604] Initializing built-in extension XFree86-DGA
[351049.604] Initializing built-in extension XFree86-DRI
[351049.604] Initializing built-in extension DRI2
[351049.604] (II) LoadModule: "glx"
[351049.605] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[351049.605] (II) Module glx: vendor="X.Org Foundation"
[351049.605] compiled for 1.13.0, module version = 1.0.0
[351049.605] ABI class: X.Org Server Extension, version 7.0
[351049.605] (==) AIGLX enabled
[351049.605] Loading extension GLX
[351049.605] (II) LoadModule: "intel"
[351049.605] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[351049.606] (II) Module intel: vendor="X.Org Foundation"
[351049.606] compiled for 1.13.0, module version = 2.20.9
[351049.606] Module class: X.Org Video Driver
[351049.606] ABI class: X.Org Video Driver, version 13.0
[351049.606] (II) intel: Driver for Intel Integrated Graphics Chipsets: i810,
i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G, 915G,
E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM, Pineview G,
965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33, GM45,
4 Series, G45/G43, Q45/Q43, G41, B43, B43, Clarkdale, Arrandale,
Sandybridge Desktop (GT1), Sandybridge Desktop (GT2),
Sandybridge Desktop (GT2+), Sandybridge Mobile (GT1),
Sandybridge Mobile (GT2), Sandybridge Mobile (GT2+),
Sandybridge Server, Ivybridge Mobile (GT1), Ivybridge Mobile (GT2),
Ivybridge Desktop (GT1), Ivybridge Desktop (GT2), Ivybridge Server,
Ivybridge Server (GT2), Haswell Desktop (GT1), Haswell Desktop (GT2),
Haswell Desktop (GT2+), Haswell Mobile (GT1), Haswell Mobile (GT2),
Haswell Mobile (GT2+), Haswell Server (GT1), Haswell Server (GT2),
Haswell Server (GT2+), Haswell SDV Desktop (GT1),
Haswell SDV Desktop (GT2), Haswell SDV Desktop (GT2+),
Haswell SDV Mobile (GT1), Haswell SDV Mobile (GT2),
Haswell SDV Mobile (GT2+), Haswell SDV Server (GT1),
Haswell SDV Server (GT2), Haswell SDV Server (GT2+),
Haswell ULT Desktop (GT1), Haswell ULT Desktop (GT2),
Haswell ULT Desktop (GT2+), Haswell ULT Mobile (GT1),
Haswell ULT Mobile (GT2), Haswell ULT Mobile (GT2+),
Haswell ULT Server (GT1), Haswell ULT Server (GT2),
Haswell ULT Server (GT2+), Haswell CRW Desktop (GT1),
Haswell CRW Desktop (GT2), Haswell CRW Desktop (GT2+),
Haswell CRW Mobile (GT1), Haswell CRW Mobile (GT2),
Haswell CRW Mobile (GT2+), Haswell CRW Server (GT1),
Haswell CRW Server (GT2), Haswell CRW Server (GT2+),
ValleyView PO board
[351049.607] (--) using VT number 7
[351049.618] (II) intel(0): using device path '/dev/dri/card0'
[351049.618] (**) intel(0): Depth 24, (--) framebuffer bpp 32
[351049.618] (==) intel(0): RGB weight 888
[351049.618] (==) intel(0): Default visual is TrueColor
[351049.618] (--) intel(0): Integrated Graphics Chipset: Intel(R) Clarkdale
[351049.618] (**) intel(0): Relaxed fencing enabled
[351049.618] (**) intel(0): Wait on SwapBuffers? enabled
[351049.618] (**) intel(0): Triple buffering? enabled
[351049.618] (**) intel(0): Framebuffer tiled
[351049.618] (**) intel(0): Pixmaps tiled
[351049.618] (**) intel(0): 3D buffers tiled
[351049.618] (**) intel(0): SwapBuffers wait enabled
[351049.618] (==) intel(0): video overlay key set to 0x101fe
[351049.618] (II) intel(0): Output VGA1 has no monitor section
[351049.619] (II) intel(0): Output HDMI1 has no monitor section
[351049.668] (II) intel(0): Output DP1 has no monitor section
[351050.244] (II) intel(0): Output HDMI2 has no monitor section
[351050.260] (II) intel(0): Output HDMI3 has no monitor section
[351050.308] (II) intel(0): Output DP2 has no monitor section
[351050.356] (II) intel(0): Output DP3 has no monitor section
[351050.356] (II) intel(0): EDID for output VGA1
[351050.356] (II) intel(0): EDID for output HDMI1
[351050.404] (II) intel(0): EDID for output DP1
[351050.980] (II) Quirked EDID physical size to 0x0 cm
[351050.980] (II) intel(0): EDID for output HDMI2
[351050.980] (II) intel(0): Manufacturer: ONK Model: a52 Serial#: 0
[351050.980] (II) intel(0): Year: 2010 Week: 0
[351050.980] (II) intel(0): EDID Version: 1.3
[351050.980] (II) intel(0): Digital Display Input
[351050.980] (II) intel(0): Indeterminate output size
[351050.980] (II) intel(0): Gamma: 2.20
[351050.980] (II) intel(0): No DPMS capabilities specified
[351050.980] (II) intel(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[351050.980] (II) intel(0): First detailed timing is preferred mode
[351050.980] (II) intel(0): redX: 0.640 redY: 0.330 greenX: 0.300 greenY: 0.600
[351050.980] (II) intel(0): blueX: 0.150 blueY: 0.060 whiteX: 0.312 whiteY: 0.329
[351050.980] (II) intel(0): Supported established timings:
[351050.980] (II) intel(0): 640x480@60Hz
[351050.980] (II) intel(0): Manufacturer's mask: 0
[351050.980] (II) intel(0): Supported detailed timing:
[351050.980] (II) intel(0): clock: 148.5 MHz Image Size: 160 x 90 mm
[351050.980] (II) intel(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[351050.980] (II) intel(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[351050.980] (II) intel(0): clock: 74.2 MHz Image Size: 160 x 90 mm
[351050.980] (II) intel(0): h_active: 1280 h_sync: 1390 h_sync_end 1430 h_blank_end 1650 h_border: 0
[351050.980] (II) intel(0): v_active: 720 v_sync: 725 v_sync_end 730 v_blanking: 750 v_border: 0
[351050.980] (II) intel(0): Monitor name: TX-SR578
[351050.980] (II) intel(0): Ranges: V min: 23 V max: 61 Hz, H min: 26 H max: 68 kHz, PixClock max 175 MHz
[351050.980] (II) intel(0): h_active: 1280 h_sync: 1720 h_sync_end 1760 h_blank_end 1980 h_border: 0
[351050.980] (II) intel(0): v_active: 540 v_sync: 542 v_sync_end 547 v_blanking: 562 v_border: 0
[351050.980] (II) intel(0): h_active: 1920 h_sync: 2448 h_sync_end 2492 h_blank_end 2640 h_border: 0
[351050.980] (II) intel(0): Number of EDID sections to follow: 1
[351050.980] (II) intel(0): EDID (in hex):
[351050.980] (II) intel(0): 00ffffffffffff003dcb520a00000000
[351050.980] (II) intel(0): 00140103801009780aee91a3544c9926
[351050.980] (II) intel(0): 0f505420000001010101010101010101
[351050.980] (II) intel(0): 010101010101023a801871382d40582c
[351050.980] (II) intel(0): 4500a05a0000001e011d007251d01e20
[351050.980] (II) intel(0): 6e285500a05a0000001e000000fc0054
[351050.980] (II) intel(0): 582d53523537380a20202020000000fd
[351050.980] (II) intel(0): 00173d1a4411000a202020202020011b
[351050.980] (II) intel(0): 020345714f901f041305140312202122
[351050.980] (II) intel(0): 0f1e242638097f070f7f071707503f06
[351050.980] (II) intel(0): c04d02005706005f7e01675400834f00
[351050.980] (II) intel(0): 006c030c004100b82dc000000000e305
[351050.981] (II) intel(0): 0301e2000f011d00bc52d01e20b82855
[351050.981] (II) intel(0): 40a05a0000001e011d8018711c162058
[351050.981] (II) intel(0): 2c2500a05a0000009e011d80d0721c16
[351050.981] (II) intel(0): 20102c2580a05a0000009e00000000d8
[351050.981] (II) intel(0): Printing probed modes for output HDMI2
[351050.981] (II) intel(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[351050.981] (II) intel(0): Modeline "1920x1080"x60.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz eP)
[351050.981] (II) intel(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[351050.981] (II) intel(0): Modeline "1920x1080"x50.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[351050.981] (II) intel(0): Modeline "1920x1080"x30.0 74.25 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[351050.981] (II) intel(0): Modeline "1920x1080"x25.0 74.25 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (28.1 kHz e)
[351050.981] (II) intel(0): Modeline "1920x1080"x24.0 74.25 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[351050.981] (II) intel(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[351050.981] (II) intel(0): Modeline "2880x576"x50.0 108.00 2880 2928 3184 3456 576 581 586 625 -hsync -vsync (31.2 kHz e)
[351050.981] (II) intel(0): Modeline "1680x945"x60.0 131.48 1680 1784 1960 2240 945 946 949 978 -hsync +vsync (58.7 kHz)
[351050.981] (II) intel(0): Modeline "1400x1050"x59.9 101.00 1400 1448 1480 1560 1050 1053 1057 1080 +hsync -vsync (64.7 kHz e)
[351050.981] (II) intel(0): Modeline "1600x900"x60.0 118.96 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz)
[351050.981] (II) intel(0): Modeline "2880x480"x59.9 108.00 2880 2944 3192 3432 480 489 495 525 -hsync -vsync (31.5 kHz e)
[351050.981] (II) intel(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[351050.981] (II) intel(0): Modeline "1440x900"x59.9 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[351050.981] (II) intel(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[351050.981] (II) intel(0): Modeline "1366x768"x60.0 85.89 1366 1439 1583 1800 768 769 772 795 -hsync +vsync (47.7 kHz)
[351050.981] (II) intel(0): Modeline "1360x768"x60.0 85.50 1360 1424 1536 1792 768 771 777 795 +hsync +vsync (47.7 kHz e)
[351050.981] (II) intel(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz e)
[351050.981] (II) intel(0): Modeline "1280x768"x60.0 68.25 1280 1328 1360 1440 768 771 778 790 +hsync -vsync (47.4 kHz e)
[351050.981] (II) intel(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[351050.981] (II) intel(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[351050.981] (II) intel(0): Modeline "1440x576"x50.0 54.00 1440 1464 1592 1728 576 581 586 625 -hsync -vsync (31.2 kHz e)
[351050.981] (II) intel(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[351050.981] (II) intel(0): Modeline "1440x480"x59.9 54.00 1440 1472 1596 1716 480 489 495 525 -hsync -vsync (31.5 kHz e)
[351050.981] (II) intel(0): Modeline "1024x576"x60.0 46.97 1024 1064 1168 1312 576 577 580 597 -hsync +vsync (35.8 kHz)
[351050.981] (II) intel(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[351050.981] (II) intel(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[351050.981] (II) intel(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[351050.981] (II) intel(0): Modeline "848x480"x60.0 33.75 848 864 976 1088 480 486 494 517 +hsync +vsync (31.0 kHz e)
[351050.981] (II) intel(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[351050.981] (II) intel(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[351050.996] (II) intel(0): EDID for output HDMI3
[351051.044] (II) intel(0): EDID for output DP2
[351051.092] (II) intel(0): EDID for output DP3
[351051.092] (II) intel(0): Output VGA1 disconnected
[351051.092] (II) intel(0): Output HDMI1 disconnected
[351051.092] (II) intel(0): Output DP1 disconnected
[351051.092] (II) intel(0): Output HDMI2 connected
[351051.092] (II) intel(0): Output HDMI3 disconnected
[351051.092] (II) intel(0): Output DP2 disconnected
[351051.092] (II) intel(0): Output DP3 disconnected
[351051.092] (II) intel(0): Using exact sizes for initial modes
[351051.092] (II) intel(0): Output HDMI2 using initial mode 1920x1080
[351051.092] (II) intel(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[351051.092] (II) intel(0): Kernel page flipping support detected, enabling
[351051.092] (==) intel(0): DPI set to (96, 96)
[351051.092] (II) Loading sub module "fb"
[351051.092] (II) LoadModule: "fb"
[351051.092] (II) Loading /usr/lib/xorg/modules/libfb.so
[351051.092] (II) Module fb: vendor="X.Org Foundation"
[351051.092] compiled for 1.13.0, module version = 1.0.0
[351051.092] ABI class: X.Org ANSI C Emulation, version 0.4
[351051.092] (II) Loading sub module "dri2"
[351051.092] (II) LoadModule: "dri2"
[351051.092] (II) Module "dri2" already built-in
[351051.092] (==) Depth 24 pixmap format is 32 bpp
[351051.092] (II) intel(0): [DRI2] Setup complete
[351051.092] (II) intel(0): [DRI2] DRI driver: i965
[351051.092] (II) intel(0): Allocated new frame buffer 1920x1080 stride 7680, tiled
[351051.103] (II) UXA(0): Driver registered support for the following operations:
[351051.103] (II) solid
[351051.103] (II) copy
[351051.103] (II) composite (RENDER acceleration)
[351051.103] (II) put_image
[351051.103] (II) get_image
[351051.103] (==) intel(0): Backing store disabled
[351051.103] (==) intel(0): Silken mouse enabled
[351051.103] (II) intel(0): Initializing HW Cursor
[351051.103] (II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[351051.104] (==) intel(0): DPMS enabled
[351051.104] (==) intel(0): Intel XvMC decoder enabled
[351051.104] (II) intel(0): Set up textured video
[351051.104] (II) intel(0): [XvMC] xvmc_vld driver initialized.
[351051.104] (II) intel(0): direct rendering: DRI2 Enabled
[351051.104] (==) intel(0): hotplug detection: "enabled"
[351051.120] (--) RandR disabled
[351051.135] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[351051.135] (II) AIGLX: enabled GLX_INTEL_swap_event
[351051.135] (II) AIGLX: enabled GLX_ARB_create_context
[351051.135] (II) AIGLX: enabled GLX_ARB_create_context_profile
[351051.135] (II) AIGLX: enabled GLX_EXT_create_context_es2_profile
[351051.135] (II) AIGLX: enabled GLX_SGI_swap_control and GLX_MESA_swap_control
[351051.135] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
[351051.135] (II) AIGLX: Loaded and initialized i965
[351051.135] (II) GLX: Initialized DRI2 GL provider for screen 0
[351051.136] (II) intel(0): Setting screen physical size to 508 x 285
[351051.144] (II) XKB: reuse xkmfile /var/lib/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
[351051.145] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[351051.145] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[351051.145] (II) LoadModule: "evdev"
[351051.146] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[351051.146] (II) Module evdev: vendor="X.Org Foundation"
[351051.146] compiled for 1.13.0, module version = 2.7.3
[351051.146] Module class: X.Org XInput Driver
[351051.146] ABI class: X.Org XInput driver, version 18.0
[351051.146] (II) Using input driver 'evdev' for 'Power Button'
[351051.146] (**) Power Button: always reports core events
[351051.146] (**) evdev: Power Button: Device: "/dev/input/event1"
[351051.146] (--) evdev: Power Button: Vendor 0 Product 0x1
[351051.146] (--) evdev: Power Button: Found keys
[351051.146] (II) evdev: Power Button: Configuring as keyboard
[351051.146] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[351051.146] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[351051.146] (**) Option "xkb_rules" "evdev"
[351051.146] (**) Option "xkb_model" "pc105"
[351051.146] (**) Option "xkb_layout" "us"
[351051.146] (**) Option "xkb_variant" "intl"
[351051.147] (II) XKB: reuse xkmfile /var/lib/xkb/server-A5431D4A34463C892C9E905E2E421B30A3CC30DD.xkm
[351051.148] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[351051.148] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[351051.148] (II) Using input driver 'evdev' for 'Power Button'
[351051.148] (**) Power Button: always reports core events
[351051.148] (**) evdev: Power Button: Device: "/dev/input/event0"
[351051.148] (--) evdev: Power Button: Vendor 0 Product 0x1
[351051.148] (--) evdev: Power Button: Found keys
[351051.148] (II) evdev: Power Button: Configuring as keyboard
[351051.148] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[351051.148] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[351051.148] (**) Option "xkb_rules" "evdev"
[351051.148] (**) Option "xkb_model" "pc105"
[351051.148] (**) Option "xkb_layout" "us"
[351051.148] (**) Option "xkb_variant" "intl"
[351051.148] (II) config/udev: Adding drm device (/dev/dri/card0)
[351051.148] (II) config/udev: Adding input device 2.4G Wireless Touchpad Keyboard (/dev/input/event2)
[351051.148] (**) 2.4G Wireless Touchpad Keyboard: Applying InputClass "evdev keyboard catchall"
[351051.148] (II) Using input driver 'evdev' for '2.4G Wireless Touchpad Keyboard'
[351051.148] (**) 2.4G Wireless Touchpad Keyboard: always reports core events
[351051.148] (**) evdev: 2.4G Wireless Touchpad Keyboard: Device: "/dev/input/event2"
[351051.148] (--) evdev: 2.4G Wireless Touchpad Keyboard: Vendor 0x4d9 Product 0x2519
[351051.148] (--) evdev: 2.4G Wireless Touchpad Keyboard: Found keys
[351051.148] (II) evdev: 2.4G Wireless Touchpad Keyboard: Configuring as keyboard
[351051.148] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.2/usb5/5-1/5-1:1.0/input/input2/event2"
[351051.148] (II) XINPUT: Adding extended input device "2.4G Wireless Touchpad Keyboard" (type: KEYBOARD, id 8)
[351051.149] (II) config/udev: Adding input device 2.4G Wireless Touchpad Keyboard (/dev/input/event3)
[351051.149] (**) 2.4G Wireless Touchpad Keyboard: Applying InputClass "evdev pointer catchall"
[351051.149] (**) 2.4G Wireless Touchpad Keyboard: Applying InputClass "evdev keyboard catchall"
[351051.149] (II) Using input driver 'evdev' for '2.4G Wireless Touchpad Keyboard'
[351051.149] (**) 2.4G Wireless Touchpad Keyboard: always reports core events
[351051.149] (**) evdev: 2.4G Wireless Touchpad Keyboard: Device: "/dev/input/event3"
[351051.149] (--) evdev: 2.4G Wireless Touchpad Keyboard: Vendor 0x4d9 Product 0x2519
[351051.149] (--) evdev: 2.4G Wireless Touchpad Keyboard: Found 9 mouse buttons
[351051.149] (--) evdev: 2.4G Wireless Touchpad Keyboard: Found scroll wheel(s)
[351051.149] (--) evdev: 2.4G Wireless Touchpad Keyboard: Found relative axes
[351051.149] (--) evdev: 2.4G Wireless Touchpad Keyboard: Found x and y relative axes
[351051.149] (--) evdev: 2.4G Wireless Touchpad Keyboard: Found absolute axes
[351051.149] (II) evdev: 2.4G Wireless Touchpad Keyboard: Forcing absolute x/y axes to exist.
[351051.149] (--) evdev: 2.4G Wireless Touchpad Keyboard: Found keys
[351051.149] (II) evdev: 2.4G Wireless Touchpad Keyboard: Configuring as mouse
[351051.149] (II) evdev: 2.4G Wireless Touchpad Keyboard: Configuring as keyboard
[351051.149] (II) evdev: 2.4G Wireless Touchpad Keyboard: Adding scrollwheel support
[351051.149] (**) evdev: 2.4G Wireless Touchpad Keyboard: YAxisMapping: buttons 4 and 5
[351051.149] (**) evdev: 2.4G Wireless Touchpad Keyboard: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[351051.149] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.2/usb5/5-1/5-1:1.1/input/input3/event3"
[351051.149] (II) XINPUT: Adding extended input device "2.4G Wireless Touchpad Keyboard" (type: KEYBOARD, id 9)
[351051.149] (**) Option "xkb_rules" "evdev"
[351051.149] (**) Option "xkb_model" "pc105"
[351051.149] (**) Option "xkb_layout" "us"
[351051.149] (**) Option "xkb_variant" "intl"
[351051.149] (II) evdev: 2.4G Wireless Touchpad Keyboard: initialized for relative axes.
[351051.149] (WW) evdev: 2.4G Wireless Touchpad Keyboard: ignoring absolute axes.
[351051.149] (**) 2.4G Wireless Touchpad Keyboard: (accel) keeping acceleration scheme 1
[351051.149] (**) 2.4G Wireless Touchpad Keyboard: (accel) acceleration profile 0
[351051.149] (**) 2.4G Wireless Touchpad Keyboard: (accel) acceleration factor: 2.000
[351051.149] (**) 2.4G Wireless Touchpad Keyboard: (accel) acceleration threshold: 4
[351051.149] (II) config/udev: Adding input device 2.4G Wireless Touchpad Keyboard (/dev/input/mouse0)
[351051.149] (II) No input driver specified, ignoring this device.
[351051.149] (II) This device may have been added with another device file.
[351051.150] (II) config/udev: Adding input device Media Center Ed. eHome Infrared Remote Transceiver (147a:e03e) (/dev/input/event4)
[351051.150] (**) Media Center Ed. eHome Infrared Remote Transceiver (147a:e03e): Applying InputClass "evdev keyboard catchall"
[351051.150] (II) Using input driver 'evdev' for 'Media Center Ed. eHome Infrared Remote Transceiver (147a:e03e)'
[351051.150] (**) Media Center Ed. eHome Infrared Remote Transceiver (147a:e03e): always reports core events
[351051.150] (**) evdev: Media Center Ed. eHome Infrared Remote Transceiver (147a:e03e): Device: "/dev/input/event4"
[351051.150] (--) evdev: Media Center Ed. eHome Infrared Remote Transceiver (147a:e03e): Vendor 0x147a Product 0xe03e
[351051.150] (--) evdev: Media Center Ed. eHome Infrared Remote Transceiver (147a:e03e): Found keys
[351051.150] (II) evdev: Media Center Ed. eHome Infrared Remote Transceiver (147a:e03e): Configuring as keyboard
[351051.150] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.2/usb5/5-2/5-2:1.0/rc/rc0/input4/event4"
[351051.150] (II) XINPUT: Adding extended input device "Media Center Ed. eHome Infrared Remote Transceiver (147a:e03e)" (type: KEYBOARD, id 10)
[351051.150] (**) Option "xkb_rules" "evdev"
[351051.150] (**) Option "xkb_model" "pc105"
[351051.150] (**) Option "xkb_layout" "us"
[351051.150] (**) Option "xkb_variant" "intl"
[351051.150] (II) config/udev: Adding input device IR-receiver inside an USB DVB receiver (/dev/input/event6)
[351051.150] (**) IR-receiver inside an USB DVB receiver: Applying InputClass "evdev keyboard catchall"
[351051.150] (II) Using input driver 'evdev' for 'IR-receiver inside an USB DVB receiver'
[351051.150] (**) IR-receiver inside an USB DVB receiver: always reports core events
[351051.150] (**) evdev: IR-receiver inside an USB DVB receiver: Device: "/dev/input/event6"
[351051.150] (--) evdev: IR-receiver inside an USB DVB receiver: Vendor 0x1c73 Product 0x861f
[351051.150] (--) evdev: IR-receiver inside an USB DVB receiver: Found keys
[351051.150] (II) evdev: IR-receiver inside an USB DVB receiver: Configuring as keyboard
[351051.150] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.7/usb1/1-3/rc/rc1/input6/event6"
[351051.150] (II) XINPUT: Adding extended input device "IR-receiver inside an USB DVB receiver" (type: KEYBOARD, id 11)
[351051.150] (II) config/udev: Adding input device IR-receiver inside an USB DVB receiver (/dev/input/event7)
[351051.150] (**) evdev: IR-receiver inside an USB DVB receiver: Device: "/dev/input/event7"
[351051.151] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.7/usb1/1-4/rc/rc2/input7/event7"
[351051.151] (II) XINPUT: Adding extended input device "IR-receiver inside an USB DVB receiver" (type: KEYBOARD, id 12)
[351051.151] (**) Option "xkb_rules" "evdev"
[351051.151] (**) Option "xkb_model" "pc105"
[351051.151] (**) Option "xkb_layout" "us"
[351051.151] (**) Option "xkb_variant" "intl"
[351051.151] (II) config/udev: Adding input device HDA Intel Front Mic (/dev/input/event10)
[351051.151] (II) No input driver specified, ignoring this device.
[351051.151] (II) This device may have been added with another device file.
[351051.151] (II) config/udev: Adding input device HDA Intel Rear Mic (/dev/input/event11)
[351051.151] (II) config/udev: Adding input device HDA Intel Front Headphone (/dev/input/event12)
[351051.151] (II) config/udev: Adding input device HDA Intel Line Out Side (/dev/input/event13)
[351051.151] (II) config/udev: Adding input device HDA Intel Line Out CLFE (/dev/input/event14)
[351051.152] (II) No input driver specified, ignoring this device.
[351051.152] (II) This device may have been added with another device file.
[351051.152] (II) config/udev: Adding input device HDA Intel Line Out Surround (/dev/input/event15)
[351051.152] (II) config/udev: Adding input device HDA Intel Line Out Front (/dev/input/event16)
[351051.152] (II) config/udev: Adding input device HDA Intel HDMI/DP,pcm=3 (/dev/input/event8)
[351051.152] (II) config/udev: Adding input device HDA Intel Line (/dev/input/event9)
[351051.153] (II) config/udev: Adding input device MCE IR Keyboard/Mouse (mceusb) (/dev/input/event5)
[351051.153] (**) MCE IR Keyboard/Mouse (mceusb): Applying InputClass "evdev pointer catchall"
[351051.153] (**) MCE IR Keyboard/Mouse (mceusb): Applying InputClass "evdev keyboard catchall"
[351051.153] (II) Using input driver 'evdev' for 'MCE IR Keyboard/Mouse (mceusb)'
[351051.153] (**) MCE IR Keyboard/Mouse (mceusb): always reports core events
[351051.153] (**) evdev: MCE IR Keyboard/Mouse (mceusb): Device: "/dev/input/event5"
[351051.153] (--) evdev: MCE IR Keyboard/Mouse (mceusb): Vendor 0 Product 0
[351051.153] (--) evdev: MCE IR Keyboard/Mouse (mceusb): Found 3 mouse buttons
[351051.153] (--) evdev: MCE IR Keyboard/Mouse (mceusb): Found relative axes
[351051.153] (--) evdev: MCE IR Keyboard/Mouse (mceusb): Found x and y relative axes
[351051.153] (--) evdev: MCE IR Keyboard/Mouse (mceusb): Found keys
[351051.153] (II) evdev: MCE IR Keyboard/Mouse (mceusb): Configuring as mouse
[351051.153] (II) evdev: MCE IR Keyboard/Mouse (mceusb): Configuring as keyboard
[351051.153] (**) evdev: MCE IR Keyboard/Mouse (mceusb): YAxisMapping: buttons 4 and 5
[351051.153] (**) evdev: MCE IR Keyboard/Mouse (mceusb): EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[351051.153] (**) Option "config_info" "udev:/sys/devices/virtual/input/input5/event5"
[351051.153] (II) XINPUT: Adding extended input device "MCE IR Keyboard/Mouse (mceusb)" (type: KEYBOARD, id 13)
[351051.153] (**) Option "xkb_rules" "evdev"
[351051.153] (**) Option "xkb_model" "pc105"
[351051.153] (**) Option "xkb_layout" "us"
[351051.153] (**) Option "xkb_variant" "intl"
[351051.154] (II) evdev: MCE IR Keyboard/Mouse (mceusb): initialized for relative axes.
[351051.154] (**) MCE IR Keyboard/Mouse (mceusb): (accel) keeping acceleration scheme 1
[351051.154] (**) MCE IR Keyboard/Mouse (mceusb): (accel) acceleration profile 0
[351051.154] (**) MCE IR Keyboard/Mouse (mceusb): (accel) acceleration factor: 2.000
[351051.154] (**) MCE IR Keyboard/Mouse (mceusb): (accel) acceleration threshold: 4
[351051.154] (II) config/udev: Adding input device MCE IR Keyboard/Mouse (mceusb) (/dev/input/mouse1)
[351051.154] (II) No input driver specified, ignoring this device.
[351051.154] (II) This device may have been added with another device file.
[351052.020] (II) Quirked EDID physical size to 0x0 cm
[351052.020] (II) intel(0): EDID vendor "ONK", prod id 2642
[351052.020] (II) intel(0): Using EDID range info for horizontal sync
[351052.020] (II) intel(0): Using EDID range info for vertical refresh
[351052.020] (II) intel(0): Printing DDC gathered Modelines:
[351052.020] (II) intel(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[351052.020] (II) intel(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[351052.020] (II) intel(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[351052.020] (II) intel(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[351052.020] (II) intel(0): Modeline "1920x1080i"x0.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[351052.020] (II) intel(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[351052.020] (II) intel(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[351052.020] (II) intel(0): Modeline "1920x1080"x0.0 74.25 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[351052.020] (II) intel(0): Modeline "1440x480i"x0.0 27.00 1440 1478 1602 1716 480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[351052.020] (II) intel(0): Modeline "1440x576i"x0.0 27.00 1440 1464 1590 1728 576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[351052.020] (II) intel(0): Modeline "1920x1080"x0.0 74.25 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (28.1 kHz e)
[351052.020] (II) intel(0): Modeline "1920x1080"x0.0 74.25 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[351052.020] (II) intel(0): Modeline "2880x480"x0.0 108.00 2880 2944 3192 3432 480 489 495 525 -hsync -vsync (31.5 kHz e)
[351052.020] (II) intel(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[351052.020] (II) intel(0): Modeline "2880x576"x0.0 108.00 2880 2928 3184 3456 576 581 586 625 -hsync -vsync (31.2 kHz e)
[351052.020] (II) intel(0): Modeline "1920x1080i"x0.0 72.00 1920 1952 2120 2304 1080 1126 1136 1250 interlace +hsync -vsync (31.2 kHz e)
[351053.000] (II) Quirked EDID physical size to 0x0 cm
[351053.000] (II) intel(0): EDID vendor "ONK", prod id 2642
[351053.000] (II) intel(0): Using hsync ranges from config file
[351053.000] (II) intel(0): Using vrefresh ranges from config file
[351053.000] (II) intel(0): Printing DDC gathered Modelines:
[351053.000] (II) intel(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[351053.000] (II) intel(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[351053.000] (II) intel(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[351053.000] (II) intel(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[351053.000] (II) intel(0): Modeline "1920x1080i"x0.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[351053.000] (II) intel(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[351053.000] (II) intel(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[351053.000] (II) intel(0): Modeline "1920x1080"x0.0 74.25 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[351053.000] (II) intel(0): Modeline "1440x480i"x0.0 27.00 1440 1478 1602 1716 480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[351053.000] (II) intel(0): Modeline "1440x576i"x0.0 27.00 1440 1464 1590 1728 576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[351053.000] (II) intel(0): Modeline "1920x1080"x0.0 74.25 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (28.1 kHz e)
[351053.000] (II) intel(0): Modeline "1920x1080"x0.0 74.25 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[351053.000] (II) intel(0): Modeline "2880x480"x0.0 108.00 2880 2944 3192 3432 480 489 495 525 -hsync -vsync (31.5 kHz e)
[351053.000] (II) intel(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[351053.000] (II) intel(0): Modeline "2880x576"x0.0 108.00 2880 2928 3184 3456 576 581 586 625 -hsync -vsync (31.2 kHz e)
[351053.000] (II) intel(0): Modeline "1920x1080i"x0.0 72.00 1920 1952 2120 2304 1080 1126 1136 1250 interlace +hsync -vsync (31.2 kHz e)
[351231.740] (II) AIGLX: Suspending AIGLX clients for VT switch
[351473.736] (II) Open ACPI successful (/var/run/acpid.socket)
[351473.736] (II) AIGLX: Resuming AIGLX clients after VT switch
[351474.368] (II) Quirked EDID physical size to 0x0 cm
[351474.368] (II) intel(0): EDID vendor "ONK", prod id 2642
[351474.368] (II) intel(0): Using hsync ranges from config file
[351474.368] (II) intel(0): Using vrefresh ranges from config file
[351474.368] (II) intel(0): Printing DDC gathered Modelines:
[351474.368] (II) intel(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[351474.368] (II) intel(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[351474.368] (II) intel(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[351474.368] (II) intel(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[351474.368] (II) intel(0): Modeline "1920x1080i"x0.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[351474.368] (II) intel(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[351474.368] (II) intel(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[351474.368] (II) intel(0): Modeline "1920x1080"x0.0 74.25 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[351474.368] (II) intel(0): Modeline "1440x480i"x0.0 27.00 1440 1478 1602 1716 480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[351474.368] (II) intel(0): Modeline "1440x576i"x0.0 27.00 1440 1464 1590 1728 576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[351474.368] (II) intel(0): Modeline "1920x1080"x0.0 74.25 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (28.1 kHz e)
[351474.368] (II) intel(0): Modeline "1920x1080"x0.0 74.25 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[351474.368] (II) intel(0): Modeline "2880x480"x0.0 108.00 2880 2944 3192 3432 480 489 495 525 -hsync -vsync (31.5 kHz e)
[351474.368] (II) intel(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[351474.368] (II) intel(0): Modeline "2880x576"x0.0 108.00 2880 2928 3184 3456 576 581 586 625 -hsync -vsync (31.2 kHz e)
[351474.368] (II) intel(0): Modeline "1920x1080i"x0.0 72.00 1920 1952 2120 2304 1080 1126 1136 1250 interlace +hsync -vsync (31.2 kHz e)
[351574.468] (II) AIGLX: Suspending AIGLX clients for VT switch
[351816.445] (II) Open ACPI successful (/var/run/acpid.socket)
[351816.445] (II) AIGLX: Resuming AIGLX clients after VT switch
[351817.076] (II) Quirked EDID physical size to 0x0 cm
[351817.076] (II) intel(0): EDID vendor "ONK", prod id 2642
[351817.076] (II) intel(0): Using hsync ranges from config file
[351817.076] (II) intel(0): Using vrefresh ranges from config file
[351817.076] (II) intel(0): Printing DDC gathered Modelines:
[351817.076] (II) intel(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[351817.076] (II) intel(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[351817.076] (II) intel(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[351817.076] (II) intel(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[351817.076] (II) intel(0): Modeline "1920x1080i"x0.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[351817.076] (II) intel(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[351817.076] (II) intel(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[351817.076] (II) intel(0): Modeline "1920x1080"x0.0 74.25 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[351817.076] (II) intel(0): Modeline "1440x480i"x0.0 27.00 1440 1478 1602 1716 480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[351817.076] (II) intel(0): Modeline "1440x576i"x0.0 27.00 1440 1464 1590 1728 576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[351817.076] (II) intel(0): Modeline "1920x1080"x0.0 74.25 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (28.1 kHz e)
[351817.076] (II) intel(0): Modeline "1920x1080"x0.0 74.25 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[351817.076] (II) intel(0): Modeline "2880x480"x0.0 108.00 2880 2944 3192 3432 480 489 495 525 -hsync -vsync (31.5 kHz e)
[351817.076] (II) intel(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[351817.076] (II) intel(0): Modeline "2880x576"x0.0 108.00 2880 2928 3184 3456 576 581 586 625 -hsync -vsync (31.2 kHz e)
[351817.076] (II) intel(0): Modeline "1920x1080i"x0.0 72.00 1920 1952 2120 2304 1080 1126 1136 1250 interlace +hsync -vsync (31.2 kHz e)
Seconde instance in the next post
And the second instance:
[code]
[351917.156]
[351917.157] X Protocol Version 11, Revision 0
[351917.157] Build Operating System: Linux 3.2.0-32-generic x86_64 Ubuntu
[351917.157] Current Operating System: Linux media 3.5.0-26-generic #42-Ubuntu SMP Fri Mar 8 23:18:20 UTC 2013 x86_64
[351917.157] Kernel command line: BOOT_IMAGE=/vmlinuz-3.5.0-26-generic root=/dev/mapper/media-root ro
[351917.157] Build Date: 27 November 2012 07:44:35AM
[351917.157] xorg-server 2:1.13.0-0ubuntu6.1 (For technical support please see
[351917.157] Current version of pixman: 0.26.0
[351917.157] Before reporting problems, check
http://wiki.x.org
[351917.157] Markers: (--) probed, (**) from config file, (==) default setting,
[351917.157] (==) Log file: "/var/log/Xorg.1.log", Time: Thu Apr 4 22:08:12 2013
[351917.157] (==) Using config file: "/etc/X11/xorg.conf"
[351917.157] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[351917.157] (==) No Layout section. Using the first Screen section.
[351917.158] (**) |-->Screen "Screen0" (0)
[351917.158] (**) | |-->Monitor "<default monitor>"
[351917.158] (**) | |-->Device "Device0"
[351917.158] (==) No monitor specified for screen "Screen0".
[351917.158] (**) Option "BlankTime" "0"
[351917.158] (**) Option "StandbyTime" "0"
[351917.158] (**) Option "SuspendTime" "0"
[351917.158] (**) Option "OffTime" "0"
[351917.158] (==) Automatically adding devices
[351917.158] (==) Automatically enabling devices
[351917.158] (==) Automatically adding GPU devices
[351917.158] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[351917.158] Entry deleted from font path.
[351917.158] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[351917.158] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[351917.158] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[351917.158] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[351917.158] (WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
[351917.158] (==) FontPath set to:
built-ins
[351917.158] (==) ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[351917.158] (**) Extension "Composite" is disabled
[351917.158] (II) The server relies on udev to provide the list of input devices.
[351917.158] (II) Loader magic: 0x7f0e5294bc40
[351917.158] (II) Module ABI versions:
[351917.158] X.Org ANSI C Emulation: 0.4
[351917.158] X.Org Video Driver: 13.0
[351917.158] X.Org XInput driver : 18.0
[351917.158] X.Org Server Extension : 7.0
[351917.159] (II) config/udev: Adding drm device (/dev/dri/card0)
[351917.160] setversion 1.4 failed
[351917.162] (--) PCI:*(0:0:2:0) 8086:0042:1458:d000 rev 24, Mem @ 0xfb800000/4194304, 0xe0000000/268435456, I/O @ 0x0000ff00/8
[351917.162] (II) Open ACPI successful (/var/run/acpid.socket)
[351917.162] Initializing built-in extension Generic Event Extension
[351917.162] Initializing built-in extension SHAPE
[351917.162] Initializing built-in extension MIT-SHM
[351917.162] Initializing built-in extension XInputExtension
[351917.162] Initializing built-in extension XTEST
[351917.162] Initializing built-in extension BIG-REQUESTS
[351917.162] Initializing built-in extension SYNC
[351917.162] Initializing built-in extension XKEYBOARD
[351917.162] Initializing built-in extension XC-MISC
[351917.162] Initializing built-in extension SECURITY
[351917.162] Initializing built-in extension XINERAMA
[351917.162] Initializing built-in extension XFIXES
[351917.162] Initializing built-in extension RENDER
[351917.162] Initializing built-in extension RANDR
[351917.162] Initializing built-in extension COMPOSITE
[351917.162] Initializing built-in extension DAMAGE
[351917.162] Initializing built-in extension MIT-SCREEN-SAVER
[351917.162] Initializing built-in extension DOUBLE-BUFFER
[351917.162] Initializing built-in extension RECORD
[351917.162] Initializing built-in extension DPMS
[351917.162] Initializing built-in extension X-Resource
[351917.162] Initializing built-in extension XVideo
[351917.162] Initializing built-in extension XVideo-MotionCompensation
[351917.162] Initializing built-in extension XFree86-VidModeExtension
[351917.162] Initializing built-in extension XFree86-DGA
[351917.162] Initializing built-in extension XFree86-DRI
[351917.162] Initializing built-in extension DRI2
[351917.162] (II) LoadModule: "glx"
[351917.163] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[351917.163] (II) Module glx: vendor="X.Org Foundation"
[351917.163] compiled for 1.13.0, module version = 1.0.0
[351917.163] ABI class: X.Org Server Extension, version 7.0
[351917.163] (==) AIGLX enabled
[351917.163] Loading extension GLX
[351917.163] (II) LoadModule: "intel"
[351917.163] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[351917.164] (II) Module intel: vendor="X.Org Foundation"
[351917.164] compiled for 1.13.0, module version = 2.20.9
[351917.164] Module class: X.Org Video Driver
[351917.164] ABI class: X.Org Video Driver, version 13.0
[351917.164] (II) intel: Driver for Intel Integrated Graphics Chipsets: i810,
ValleyView PO board
[351917.165] (--) using VT number 8
[351917.199] (**) intel(0): Depth 24, (--) framebuffer bpp 32
[351917.199] (==) intel(0): RGB weight 888
[351917.199] (==) intel(0): Default visual is TrueColor
[351917.199] (--) intel(0): Integrated Graphics Chipset: Intel® Clarkdale
[351917.199] (**) intel(0): Relaxed fencing enabled
[351917.199] (**) intel(0): Wait on SwapBuffers? enabled
[351917.199] (**) intel(0): Triple buffering? enabled
[351917.199] (**) intel(0): Framebuffer tiled
[351917.199] (**) intel(0): Pixmaps tiled
[351917.199] (**) intel(0): 3D buffers tiled
[351917.200] (**) intel(0): SwapBuffers wait enabled
[351917.200] (==) intel(0): video overlay key set to 0x101fe
[351917.200] (II) intel(0): Output VGA1 has no monitor section
[351917.200] (II) intel(0): Output HDMI1 has no monitor section
[351917.248] (II) intel(0): Output DP1 has no monitor section
[351917.824] (II) intel(0): Output HDMI2 has no monitor section
[351917.840] (II) intel(0): Output HDMI3 has no monitor section
[351917.888] (II) intel(0): Output DP2 has no monitor section
[351917.936] (II) intel(0): Output DP3 has no monitor section
[351917.936] (II) intel(0): EDID for output VGA1
[351917.936] (II) intel(0): EDID for output HDMI1
[351917.984] (II) intel(0): EDID for output DP1
[351918.560] (II) Quirked EDID physical size to 0x0 cm
[351918.560] (II) intel(0): EDID for output HDMI2
[351918.560] (II) intel(0): Manufacturer: ONK Model: a52 Serial#: 0
[351918.560] (II) intel(0): Year: 2010 Week: 0
[351918.560] (II) intel(0): EDID Version: 1.3
[351918.560] (II) intel(0): Digital Display Input
[351918.560] (II) intel(0): Indeterminate output size
[351918.560] (II) intel(0): Gamma: 2.20
[351918.560] (II) intel(0): No DPMS capabilities specified
[351918.560] (II) intel(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[351918.560] (II) intel(0): First detailed timing is preferred mode
[351918.560] (II) intel(0): redX: 0.640 redY: 0.330 greenX: 0.300 greenY: 0.600
[351918.560] (II) intel(0): blueX: 0.150 blueY: 0.060 whiteX: 0.312 whiteY: 0.329
[351918.560] (II) intel(0): Supported established timings:
[351918.560] (II) intel(0): 640x480@60Hz
[351918.560] (II) intel(0): Manufacturer's mask: 0
[351918.560] (II) intel(0): Supported detailed timing:
[351918.560] (II) intel(0): clock: 148.5 MHz Image Size: 160 x 90 mm
[351918.560] (II) intel(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[351918.560] (II) intel(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[351918.560] (II) intel(0): clock: 74.2 MHz Image Size: 160 x 90 mm
[351918.560] (II) intel(0): h_active: 1280 h_sync: 1390 h_sync_end 1430 h_blank_end 1650 h_border: 0
[351918.560] (II) intel(0): v_active: 720 v_sync: 725 v_sync_end 730 v_blanking: 750 v_border: 0
[351918.560] (II) intel(0): Monitor name: TX-SR578
[351918.560] (II) intel(0): Ranges: V min: 23 V max: 61 Hz, H min: 26 H max: 68 kHz, PixClock max 175 MHz
[351918.560] (II) intel(0): h_active: 1280 h_sync: 1720 h_sync_end 1760 h_blank_end 1980 h_border: 0
[351918.560] (II) intel(0): v_active: 540 v_sync: 542 v_sync_end 547 v_blanking: 562 v_border: 0
[351918.560] (II) intel(0): h_active: 1920 h_sync: 2448 h_sync_end 2492 h_blank_end 2640 h_border: 0
[351918.560] (II) intel(0): Number of EDID sections to follow: 1
[351918.560] (II) intel(0): EDID (in hex):
[351918.560] (II) intel(0): 00ffffffffffff003dcb520a00000000
[351918.560] (II) intel(0): 00140103801009780aee91a3544c9926
[351918.560] (II) intel(0): 0f505420000001010101010101010101
[351918.560] (II) intel(0): 010101010101023a801871382d40582c
[351918.560] (II) intel(0): 4500a05a0000001e011d007251d01e20
[351918.560] (II) intel(0): 6e285500a05a0000001e000000fc0054
[351918.560] (II) intel(0): 582d53523537380a20202020000000fd
[351918.560] (II) intel(0): 00173d1a4411000a202020202020011b
[351918.560] (II) intel(0): 020345714f901f041305140312202122
[351918.560] (II) intel(0): 0f1e242638097f070f7f071707503f06
[351918.560] (II) intel(0): c04d02005706005f7e01675400834f00
[351918.560] (II) intel(0): 006c030c004100b82dc000000000e305
[351918.560] (II) intel(0): 0301e2000f011d00bc52d01e20b82855
[351918.561] (II) intel(0): 40a05a0000001e011d8018711c162058
[351918.561] (II) intel(0): 2c2500a05a0000009e011d80d0721c16
[351918.561] (II) intel(0): 20102c2580a05a0000009e00000000d8
[351918.561] (II) intel(0): Printing probed modes for output HDMI2
[351918.561] (II) intel(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[351918.561] (II) intel(0): Modeline "1920x1080"x60.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz eP)
[351918.561] (II) intel(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[351918.561] (II) intel(0): Modeline "1920x1080"x50.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[351918.561] (II) intel(0): Modeline "1920x1080"x30.0 74.25 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[351918.561] (II) intel(0): Modeline "1920x1080"x25.0 74.25 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (28.1 kHz e)
[351918.561] (II) intel(0): Modeline "1920x1080"x24.0 74.25 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[351918.561] (II) intel(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[351918.561] (II) intel(0): Modeline "2880x576"x50.0 108.00 2880 2928 3184 3456 576 581 586 625 -hsync -vsync (31.2 kHz e)
[351918.561] (II) intel(0): Modeline "1680x945"x60.0 131.48 1680 1784 1960 2240 945 946 949 978 -hsync +vsync (58.7 kHz)
[351918.561] (II) intel(0): Modeline "1400x1050"x59.9 101.00 1400 1448 1480 1560 1050 1053 1057 1080 +hsync -vsync (64.7 kHz e)
[351918.561] (II) intel(0): Modeline "1600x900"x60.0 118.96 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz)
[351918.561] (II) intel(0): Modeline "2880x480"x59.9 108.00 2880 2944 3192 3432 480 489 495 525 -hsync -vsync (31.5 kHz e)
[351918.561] (II) intel(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[351918.561] (II) intel(0): Modeline "1440x900"x59.9 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[351918.561] (II) intel(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[351918.561] (II) intel(0): Modeline "1366x768"x60.0 85.89 1366 1439 1583 1800 768 769 772 795 -hsync +vsync (47.7 kHz)
[351918.561] (II) intel(0): Modeline "1360x768"x60.0 85.50 1360 1424 1536 1792 768 771 777 795 +hsync +vsync (47.7 kHz e)
[351918.561] (II) intel(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz e)
[351918.561] (II) intel(0): Modeline "1280x768"x60.0 68.25 1280 1328 1360 1440 768 771 778 790 +hsync -vsync (47.4 kHz e)
[351918.561] (II) intel(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[351918.561] (II) intel(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[351918.561] (II) intel(0): Modeline "1440x576"x50.0 54.00 1440 1464 1592 1728 576 581 586 625 -hsync -vsync (31.2 kHz e)
[351918.561] (II) intel(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[351918.561] (II) intel(0): Modeline "1440x480"x59.9 54.00 1440 1472 1596 1716 480 489 495 525 -hsync -vsync (31.5 kHz e)
[351918.561] (II) intel(0): Modeline "1024x576"x60.0 46.97 1024 1064 1168 1312 576 577 580 597 -hsync +vsync (35.8 kHz)
[351918.561] (II) intel(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[351918.561] (II) intel(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[351918.561] (II) intel(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[351918.561] (II) intel(0): Modeline "848x480"x60.0 33.75 848 864 976 1088 480 486 494 517 +hsync +vsync (31.0 kHz e)
[351918.561] (II) intel(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[351918.561] (II) intel(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[351918.576] (II) intel(0): EDID for output HDMI3
[351918.624] (II) intel(0): EDID for output DP2
[351918.672] (II) intel(0): EDID for output DP3
[351918.672] (II) intel(0): Output VGA1 disconnected
[351918.672] (II) intel(0): Output HDMI1 disconnected
[351918.672] (II) intel(0): Output DP1 disconnected
[351918.672] (II) intel(0): Output HDMI2 connected
[351918.672] (II) intel(0): Output HDMI3 disconnected
[351918.672] (II) intel(0): Output DP2 disconnected
[351918.672] (II) intel(0): Output DP3 disconnected
[351918.672] (II) intel(0): Using exact sizes for initial modes
[351918.672] (II) intel(0): Output HDMI2 using initial mode 1920x1080
[351918.672] (II) intel(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[351918.672] (II) intel(0): Kernel page flipping support detected, enabling
[351918.672] (==) intel(0): DPI set to (96, 96)
[351918.672] (II) Loading sub module "fb"
[351918.672] (II) LoadModule: "fb"
[351918.672] (II) Loading /usr/lib/xorg/modules/libfb.so
[351918.672] (II) Module fb: vendor="X.Org Foundation"
[351918.672] compiled for 1.13.0, module version = 1.0.0
[351918.672] ABI class: X.Org ANSI C Emulation, version 0.4
[351918.672] (II) Loading sub module "dri2"
[351918.672] (II) LoadModule: "dri2"
[351918.672] (II) Module "dri2" already built-in
[351918.672] (==) Depth 24 pixmap format is 32 bpp
[351918.672] (II) intel(0): [DRI2] Setup complete
[351918.672] (II) intel(0): [DRI2] DRI driver: i965
[351918.673] (II) intel(0): Allocated new frame buffer 1920x1080 stride 7680, tiled
[351918.681] (II) UXA(0): Driver registered support for the following operations:
[351918.681] (II) solid
[351918.681] (II) copy
[351918.681] (I
