I am very new to xbmc.I need some help,please. how can i setup nextpvr so that i get tv with egp please.What all do I need. How to get this to work please,step pleases.
OK. You don't give any details of your setup or what steps you have already taken regarding installing NextPVR but a simple guide is as follows.
1. Download NextPVR 2.6.2.
http://www.gbpvr.com/NPVRSetup_2_6_2.exe
2. Install NextPVR and setup your tuner. Use the wiki here if you need any help setting up the NextPVR software.
http://www.gbpvr.com/nwiki/pmwiki.php
3. Test NextPVR. Make sure that you can view channels in nextpvr.
4. Download XBMC Frodo.
http://xbmc.org/download/
5. Install XBMC Frodo, make sure that you install the PVR plugin for NextPVR in the install options.
5. Stop the NextPVR services using the shortcut in your start menu under nextpvr. Make sure the dialog box Stopped appears and click ok.
6. Download the updated dll file
http://forums.gbpvr.com/attachment.php?a...1364089755
7. Extract the nshared.dll file into the NextPVR folder in your Program Files.
8. Download the updated XBMC plugin from here.
http://forums.gbpvr.com/attachment.php?a...1364084249
9. Extract the dll file to the Program Files\XBMC\Addons\pvr.nextpvr
10. Start NextPVR services.
11. Go into XBMC, go into system\settings\live tv & enable, choose the nextpvr and click enable. Job done.
