Full Version: XBMC.Library.zip file wrong file structure won't install
I'm new to XBMC so please be gentle. I wanted to install the XBMC.library-1.4.3.zip file so I downloaded it from the repository and when I tried to install it through the program interface I got an error message. It said the file structure was incorrect. I'm using XP Pro. Any idea why it won't install properly automatically. Is there any way to install it manually then? I wanted to be able to watch NetFlix and Hulu. The file was in the .Zip format like it requires so I don't get it.
The very first line of the thread where you downloaded that says:
Please note: this program is not an XBMC Add-on. It is an external tool.
(2013-03-31, 04:41)Kibje Wrote: [ -> ]The very first line of the thread where you downloaded that says:
As I said I'm new to this program. Another website recommended this as one of the 10 best addons that you should get for XBMC. You are correct I need to do some more research.
