2013-03-31, 16:53
I feel like I have read 100 posts on this, went through all the settings, checked drivers, however I still can not get XBMC to run properly.
I am trying to play XBMC across HDMI from WindowsHomeServer>PioneerVSX-1022>VizioTV. The ONLY time I get get XBMC video to play properly is when I have a SPDIF option selected as the pass through. Doesn't work on analog, doesnt work on coax, only setting that makes the video play properly is when SPDIF is selected as pass through but then I obviously have no sound. The video basically pauses for a full second, then plays for equal time. I wouldn't consider this a jitter, just a complete malfunction. Since it does not seem to work even with Analog selected I am sure it has to be something with my system but I am at a loss. As I said, I believe I have ran through all the standard troubleshooting steps I could find on the issue, checked drivers, played with all the options within XBMC, none of which seemed to help.
Running a new build with i3-3225 Intel 4500 gpu w/ 8gb ram. Should be more the adequate to run XBMC. I can get a list of any other specs if needed.
Sorry to post on this again, I know there are a million posts out there about this but I just can't seem to find one that resolves my issue.
Any tips?
Any tips?
