2013-03-31, 20:18
Is it possible to normalize the audio level of my videos using asoundrc file on Frodo?
Hello.
I want to play all my videos in the same audio range, because some have an audio too high and others too low. I found a solution on internet but doesn't appear to work, so I need your help.
This is my info:
My hardware:
XBMC log: http://tny.cz/407d14bb
aplay -L: http://tny.cz/de2867e6
aplay -l:
XBMC - System - Settings - audio output: http://imgur.com/8E2pstJ
Alsamixer: http://imgur.com/YX7md62
This is the solution that I found on internet.
~/.asoundrc: http://tny.cz/a7fdb980
I had to install swh-plugins. Also I purged pulseudio and libasound2-plugins.
If I play a video using mplayer, this solution works, but on XBMC doesn't. XBMC seems to ignore the .asoundrc file. I also tested using /etc/asound.conf instead of ~/.asoundrc and it's the same result.
Is it not possible what I want? Am I making a error? Is there another solution?
Thank you.
Hello.
This is my info:
- XBMCbuntu 12 fresh install. (Linux 3.5.0-26-generic #42-Ubuntu).
- i686 arquitecture.
- Manual installation.
- XBMC 12.0 Git: fb595f2 (Compiled: Jan 28 2013)
My hardware:
- Asrock NF6G-VSTA
- AMD Athlon64 X2 6000+
- 2GB RAM
aplay -l:
**** List of PLAYBACK Hardware Devices ****
card 0: NVidia [HDA NVidia], device 0: ALC888 Analog [ALC888 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
Thank you.
