Full Version: Ace glass view mod
Couldn't help myself just a small view mod I love this skin but my wife wanted the glass view different on our openelec machine so I modded it a little thought i would post here seeing how no mods have popped up yet someone might want to have a play with it.
Ace glass view mod based on ACE 1.3.0 - 03/23/2012
This won't override your current Ace install as it has a different name but doesn't hurt to back up
MarcosQui once again fantastic work mate very stylish skin,a true work of art.
Hello Zombie my old friend. It's good to see you here.
I appreciate your words and thank you for sharing with us your MOD.
hi great mod!
is there a way to mod it that that the sidebar will be black ( a little transparent like ur white bg) with white text?
thx for ur mod!
So you modded just the Glass View?
How?
Can you Write a Short howto mod Other views?
(2013-05-03, 23:10)DerDon Wrote: [ -> ]So you modded just the Glass View?
How?
You can mod anything you like its all code you just have to learn it. you will need notepad++ or some other text editor and open up the skin .xml files and go from there.
Great Mod Zombie! Thanks for sharing.
I'm using this as my default view for TV shows. If I wanted to incorporate this into the latest MQ build, do I just need to replace the ViewsGlassList.xml?
