Full Version: [FRODO] mp3s display wrong duration in xbmc (Length tag correct!)
Hello there! Big Grin
I recently upgraded to frodo and reinstalled xbmcbuntu. But now half of my music displays the wrong length in XBMC (arround 10x the actual duration). Theese files are self-converted from m4a to mp3 VBR with avconv. The files worked on Eden.
Here two files as a comparison:
FILE 1 - WORKING VBR MP3 BOUGHT ON AMAZON (shows correct duration)
mp3info output:
Media Type:  MPEG 1.0 Layer III
Audio:       Variable kbps, 44 kHz (joint stereo)
Emphasis:    none
CRC:         No
Copyright:   No
Original:    Yes
Padding:     No
Length:      3:39
mpck output:
version                       MPEG v1.0
    layer                         3
    average bitrate               257020 bps (VBR)
    samplerate                    44100 Hz
    frames                        8391
    time                          3:39.193
    unidentified                  0 b (0%)
    errors                        none
    result                        Ok
FILE TWO - SELF-CONVERTED (avconv -i "$i" -ab 256k -y "${i%m4a}mp3" {m4a files to mp3}):
mp3info:
Audio:       256 kbps, 44 kHz (joint stereo)
Emphasis:    none
CRC:         No
Copyright:   No
Original:    Yes
Padding:     Yes
Length:      4:51
mpck:
version                       MPEG v1.0
    layer                         3
    average bitrate               255948 bps (VBR)
    samplerate                    44100 Hz
    frames                        11159
    time                          4:51.500
    errors                        none
    result                        Ok
The only thing I can think of beeing the problem could be the following lines in mp3info:
FILE1:
FILE2:
XBMC could assume that the file is a 256kbps CBR file for the calculation of the duration. But I would not know how to easily solve this problem.
EDIT: It works fine in all other players. I post this to the general support forum because I don't think this is a problem with xbmcbuntu
