2013-04-02, 05:53
i've tried installing eden and frodo, but neither one will load on my new pc build.. frustrating, because scrolling thru a ton of media and watching thru vlc is getting old fast!
here's the log file that she spits out..
can anyone tell me what's going on?
if there's any more info needed, just let me know and i'll track it down
20:32:50 T:2604 NOTICE: -----------------------------------------------------------------------
20:32:50 T:2604 NOTICE: Starting XBMC (12.1 Git:20130317-0d373cc), Platform: Windows 7 SP1 64-bit, build 7601. Built on Mar 17 2013 (compiler 1600)
20:32:50 T:2604 NOTICE: AMD A4-5300 APU with Radeon(tm) HD Graphics
20:32:50 T:2604 NOTICE: Desktop Resolution: 1280x720 32Bit at 1Hz
20:32:50 T:2604 NOTICE: Running with administrator rights
20:32:50 T:2604 NOTICE: Aero is disabled
20:32:50 T:2604 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\XBMC
20:32:50 T:2604 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\XBMC
20:32:50 T:2604 NOTICE: special://masterprofile/ is mapped to: C:\Users\dad\AppData\Roaming\XBMC\userdata
20:32:50 T:2604 NOTICE: special://home/ is mapped to: C:\Users\dad\AppData\Roaming\XBMC\
20:32:50 T:2604 NOTICE: special://temp/ is mapped to: C:\Users\dad\AppData\Roaming\XBMC\cache
20:32:50 T:2604 NOTICE: The executable running is: C:\Program Files (x86)\XBMC\XBMC.exe
20:32:50 T:2604 NOTICE: Local hostname: bertha
20:32:50 T:2604 NOTICE: Log File is located: C:\Users\dad\AppData\Roaming\XBMC\xbmc.log
20:32:51 T:2604 NOTICE: Found 2 Lists of Devices
20:32:51 T:2604 NOTICE: Enumerated DirectSound devices:
20:32:51 T:2604 NOTICE: Device 1
20:32:51 T:2604 NOTICE: m_deviceName : {F8E14387-5593-46C3-96A1-D27D665FFE46}
20:32:51 T:2604 NOTICE: m_displayName : Speakers - Speakers (2- High Definition Audio Device)
20:32:51 T:2604 NOTICE: m_displayNameExtra: DirectSound: Speakers (2- High Definition Audio Device)
20:32:51 T:2604 NOTICE: m_deviceType : AE_DEVTYPE_PCM
20:32:51 T:2604 NOTICE: m_channels : FL,FR
20:32:51 T:2604 NOTICE: m_sampleRates : 44100
20:32:51 T:2604 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_AC3
20:32:51 T:2604 NOTICE: Device 2
20:32:51 T:2604 NOTICE: m_deviceName : {5A630300-490D-4790-8956-70D6AACCBF30}
20:32:51 T:2604 NOTICE: m_displayName : SPDIF - Digital Audio (S/PDIF) (2- High Definition Audio Device)
20:32:51 T:2604 NOTICE: m_displayNameExtra: DirectSound: Digital Audio (S/PDIF) (2- High Definition Audio Device)
20:32:51 T:2604 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
20:32:51 T:2604 NOTICE: Device 3
20:32:51 T:2604 NOTICE: m_deviceName : {92FE02B4-9023-4DC6-8849-7BA8C6B456EF}
20:32:51 T:2604 NOTICE: Enumerated WASAPI devices:
20:32:51 T:2604 NOTICE: m_displayNameExtra: WASAPI: Digital Audio (S/PDIF) (2- High Definition Audio Device)
20:32:51 T:2604 NOTICE: m_sampleRates : 192000,96000,88200,48000,44100,32000
20:32:51 T:2604 NOTICE: m_dataFormats : AE_FMT_DTS,AE_FMT_AC3,AE_FMT_AAC,AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
20:32:51 T:2604 NOTICE: m_displayNameExtra: WASAPI: Speakers (2- High Definition Audio Device)
20:32:51 T:2604 NOTICE: m_channels : FL,FR,FC,LFE,SL,SR,BL,BR
20:32:51 T:2604 NOTICE: m_sampleRates : 192000,96000,48000,44100
20:32:51 T:2604 NOTICE: m_dataFormats : AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_LPCM
20:32:51 T:2604 NOTICE: load settings...
20:32:51 T:2604 NOTICE: special://profile/ is mapped to: special://masterprofile/
20:32:51 T:2604 NOTICE: loading special://masterprofile/guisettings.xml
20:32:51 T:2604 ERROR: special://masterprofile/guisettings.xml, Line 0
Failed to open file
20:32:51 T:2604 ERROR: Unable to load special://masterprofile/guisettings.xml, creating new special://masterprofile/guisettings.xml with default values
20:32:51 T:2604 NOTICE: Getting hardware information now...
20:32:51 T:2604 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
20:32:51 T:2604 NOTICE: Loaded playercorefactory configuration
20:32:51 T:2604 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
20:32:51 T:2604 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
20:32:51 T:2604 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
20:32:51 T:2604 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
20:32:51 T:2604 NOTICE: Default DVD Player: dvdplayer
20:32:51 T:2604 NOTICE: Default Video Player: dvdplayer
20:32:51 T:2604 NOTICE: Default Audio Player: paplayer
20:32:51 T:2604 NOTICE: Disabled debug logging due to GUI setting. Level 0.
20:32:51 T:2604 NOTICE: Log level changed to 0
20:32:51 T:2604 NOTICE: Loading media sources from special://masterprofile/sources.xml
20:32:51 T:2740 NOTICE: Thread CSoftAE start, auto delete: false
20:32:51 T:3268 NOTICE: Thread XBMC Peripherals start, auto delete: false
20:32:51 T:3352 NOTICE: Previous line repeats 1 times.
20:32:51 T:3352 NOTICE: Thread CRemoteControl start, auto delete: false
20:32:51 T:2604 NOTICE: Found screen: Generic PnP Monitor on Standard VGA Graphics Adapter, adapter 0.
20:32:51 T:2604 NOTICE: Primary mode: 1280x720
20:32:51 T:2604 NOTICE: Additional mode: 640x480
20:32:51 T:2604 NOTICE: Additional mode: 800x600
20:32:51 T:2604 NOTICE: Additional mode: 1280x720
20:32:51 T:2604 NOTICE: Checking resolution 16
20:32:51 T:2604 WARNING: CRenderSystemDX::CreateDevice - initial wanted device config failed
20:32:51 T:2604 ERROR: CRenderSystemDX::CreateDevice - unable to create a device. 8876086A - D3DERR_NOTAVAILABLE (Not available)
20:32:51 T:2604 FATAL: CApplication::Create: Unable to init rendering system
