Full Version: Possible to run vnsiserver3 and vnsiserver4 side by side
Hey,
Is it possible to run vnsiserver3 and vnsiserver4 side by side at the same time? Perhaps on different ports? Allowing me to run XBMC 12.1 and XBMC 13.0 on different computers?
Essentially I want to test out XBMC 13 before promoting it to the main computer connected to the main TV
Currently you can't change the port without recompiling.
You can use the vnsi addon from this branch: https://github.com/FernetMenta/xbmc-pvr-...tree/frodo
That's compatible with Frodo and you can use vnsi4 on the server.
Thanks - I think I tried to compile that add in but it failed when running ./bootstrap will take another look tonight.
I tried compiling it a week ago and it failed too, never got around to posting
Just worked for me to compile the add ins. Must have been doing something silly last time.
I pushes a fixed after you letting me know Smile
