Im trying to improve my movie set art work at the moment.
Currently Taken for example has Taken 1 artwork for the movie set, where is the best place to get the correct movie set art work and what is the best settings in nox to display a movie set?
I have seen some screen shots showing movie sets with the cd art on top, how do i do this?
N
If you are talking about this kind of screenshot (look at picture 7 in the slidehsow) :
http://forum.xbmc.org/showthread.php?tid=149698
You need to :
- install Aeon Nox 4.0.9
- use my mod
- disable cases for moviesets in viewtype settings
- create your own thumbnail with case, poste, discart, ... with GIMP or Photoshop
But with latest Aeon Nox 4.1.8 (available on GITHUB only ATM) and script script.extendedinfo
http://forum.xbmc.org/showthread.php?tid=160558, you will be able to discart and info from movieset out of the box.
Thanks Mike, your photo is exactly what im aiming for.
So does your case mode work with the current 4.1.8 on GIT?
Also, where do i drop the extendedinfo-master zip in XBMC folder?
N
No, my case mod work only with stable Aeon Nox (4.0.9) but I think that Phil and Big_Noid will release 4.1.8 very soon and, then, I will make a mod for this version.
For script.extendedinfo, just install it from XBMC (System -> Addons -> Install from ZIP file). But if you don't use Aeon Nox GITHUB release, you won't see the benefits :
Phil : You have limited discart number to 3 for moviesets ?
Thanks mike for the quick replies!
I have the latest GIT release (downloaded from last night) so I'll add the zip tonight.
I'm a little excited to test this now! Been trying for a while to make movie sets stand out!
Thanks n
Well done
Bad luck for Harry Potter with 7 discart
Wow. Now that looks nice!!!
N
(2013-04-02, 16:15)mikebzh44 Wrote: [ -> ]Bad luck for Harry Potter with 7 discart
You means 8 because of Harry Potter part 1 and part 2.
(2013-04-04, 05:32)SirKhalid Wrote: [ -> ] (2013-04-02, 16:15)mikebzh44 Wrote: [ -> ]Bad luck for Harry Potter with 7 discart
Lol starwars will be 9 sooner or later..
hehe - yeah I split star wars into 2 sets (the good ones and the not so good ones) I wonder what the third trilogy will be called LOL
