Full Version: How to mark all movies as watched?
I've red somewhere on the forums that with version 12 you can mark all movies/shows as watched if you're in the parent directory. The thing is that I'm unable to do so with my movies. If I go to Videos and hover to the source, I can press 'c' to get the contextual menu, but I don't see the option to mark all watched. If I hit enter, I enter the movies library and there I can select 'Mark as watched' but one by one.
I've also seen the solution to manually edit the XBMC database (http://forum.xbmc.org/showthread.php?tid=140776), but I was wondering if theres a way to do so from XBMC instead of manually touch files.
Videos > Library > Movies > open context menu and select "Mark as watched"
open videos, go to the root of the library, select the movies node, have at it...
Thanks! That did it...
W key on the keyboard.
