Full Version: Mirroring Stream?
If I have a centralized XBMC server, is it possible for two separate clients to pick up the stream simultaneously?
The plan, if you wanna call it that, is to set up a couple devices through out the house and I don't want to spend the money on an HDMI wifi repeater.
Keeping something like that timed up is tricky. However, playing them all at once can probably be done using some kind of script and JSON RPC (wiki). It would basically be like pressing play at the same time, hoping they start at the same time, and hoping they keep in sync as they play. Short videos might not be an issue if being played on similar hardware.
