2013-04-03, 17:55
I have a custom skin that I use in which, when a TV Show is paused, the Logo.png file appears.
This works perfectly for my primary TV Show source which contains "actual" files organized by TV Show\Season\episode.files with logo.png in the TV Show folder. However, I also have a second TV Show source that contains Strm files generated by the Hulu plug in and are organized as TV Show\episode.strm.files with logo.png in the TV Show folder.
It is with these strm files that, when paused, the logo does not show up. Is there a way to somehow define the logo.png file in a NFO file or something so that it will still show when a strm file is paused? I am assuming the difference in behavior is due to the difference between an actual file and a strm file.
Excerpt from VideoFullScreen.xml where I defined the use of Logo.png is below
<control type="image" id="1">
<description>cover image</description>
<posx>20</posx>
<posy>260r</posy>
<width>300</width>
<height>230</height>
<texture>$INFO[Player.FolderPath]../logo.png</texture>
<aspectratio aligny="bottom">keep</aspectratio>
<visible>!VideoPlayer.Content(Movies)</visible>
