Full Version: Global Playlist (Video+Mp3 for example)
hello,
i would like a global playlist. im listening to musicvideos and mp3s as well.
would be great if i can hear my mp3s while showing milddrop and if some songs are musicclips showing the clip.
if i add a folder in the video section its not available in die audio section anymore. so i cant mix them.
would also be great if the volume of video will be adjusted to the same level as the mp3s.
good work so far, its really great!
greetings from germany,
phantombrainm
definitely a needed feature. do you have a playlist format which supports video and audio? when you find that, its just a matter of making xbmc knowing what to do with it (ie porting it)
they can be mixed. you can manually create an m3u file with both music and video items, and it will play. the gui just doesnt allow you to do it when queuing items.
yes... and many thanks to kraqh3d for placing the playlist item on the music library view!
he is the man!
