Hi, I can't rip my audio CDs in XBMC, when I try to manually rip it in music-files-rip audio cd, it doesn't work . It did set XBMC up, to when a cd is inserted, it's going to be ripped. But none of them works...... It does however seem to that XBMC did try to rip them, as there are some small files with one or two tracks, but no sound, these files are about 50kb, so it's definitely not ripped ..... Any suggestions on what I'm doing wrong here
Please
Kindly
Well, I'll have to look up how to make a debug log then, I'll be back tomorrow ;) - thx
(2013-04-07, 00:30)runnernorth Wrote: [ -> ]Well, I'll have to look up how to make a debug log then, I'll be back tomorrow - thx
There were issues in the code, this has now been corrected and updated code has been pulled into the nightlies, try it out in tomorrows nightly.
Mysticpete, do you think it's "safe" to use the nightly builds....? I've never done that before, should I just install upon the old version as other upgrades...?
I've made a xbmc log file when trying to rip a cd, but the file is huuuuge I think......
(2013-04-13, 20:48)runnernorth Wrote: [ -> ]I've made this log file, can anyone please comment on what is wrong when I try to rip a CD....?
http://xbmclogs.com/show.php?id=11683
turn of library update and so on because it's making to much noise to see what is happening
Thx for your quick reply, I'll try doing that later, thx
I disabled all library updates, but still the file is huge, please have a look at the end of the file, there's something about the cd ripping, I think
http://xbmclogs.com/show.php?id=11754
(2013-04-13, 18:53)runnernorth Wrote: [ -> ]Mysticpete, do you think it's "safe" to use the nightly builds....? I've never done that before, should I just install upon the old version as other upgrades...?
I've used the nightly builds a lot and never experienced an issue, not to say there are none, it just still does what I need it to, as they say the risk is yours, But don't delete your user data when uninstalling the official version, you can always load it back in if you do get issues with a nightly, and I keep a copy of this elswhere
Thx
but if I look at the nightly builds, there are only win32 versions, can they be used on my win7/64 bit?
Ehhhhh, if I install the nightly build, would it then be possible to rip my CDs ? :-)
YES YES YES, im now able to rip my CDs, did as you said, installed the nightly build, and it works
You're a genius, and I'm so thankfull you helped me, thx.
(2013-04-14, 11:00)runnernorth Wrote: [ -> ]YES YES YES, im now able to rip my CDs, did as you said, installed the nightly build, and it works You're a genius, and I'm so thankfull you helped me, thx.
Good to hear, not had a chance to try myself, thanks again to the team for patching this issue Big Hi Fives !!!
Ohh, yes you're right, big thx to the XBMC team, without them we have not had this amazing software. :)
